FPV project: Adding an altimeter onboard my Easystar (remake)
I use the ZLOG altimeter (mod3) as a cheap way to know my altitude while flying using video goggle. The ZLOG is light, well made and work very well. I walk from one floor to the other in my house and I see 8-9 feets of denivelation.
I removed the LCD display, add wires and install it on the dashboard of my Easystar, in front of the cam so it look realistic. The display have it own light soure. A led is install on the ZLOG pcb, I leave the led there and install another one on the display backside. I want to do night flight just to try it, the lightning display will help me to see the nose. I added a plug to be able to disconnect the display from the ZLOG. The display is available from Hexpert system and not expensive. http://www.hexpertsystems.com/zlog/index.html My idea is to eventually install another display in a futur planes. The ZLOG alone with the display is very light, ideal for light planes like the Easystar. I want also to evaluate the Vision video OSD. The Vision is an On Screen Display that plug into the ZLOG and overlay data on the picture. I see altitude, voltage, current draw, lost of radio signal, call sign, timer directly inside my google incrusted on the video. The Vision & ZLOG module will then go in my Cap 232, next summer. For this purpose, no display will be connect, only essential data like altitude, voltage, lost of radio signal will be display. |
I cut a dashboard in black cardboard and also cut decorative display contour that I painted gray. I glue also on the dashboard my fake tachymeter, hummmmm I will need a real one...
The second part of my project is to evaluate the Vision Video OSD for futur use on my Cap 232 planes.
I replaced the video wires with my own pugs. I also put a drop of 5 min epoxy to hold firmly the wire in place.
And now the result...
You can see a short video in my house taken from the cockpit camera: http://video.google.fr/videoplay?doc...27087442&hl=fr A second video in flight. The Archos AV500 recorder was wrongly setted, upper and lower part of the picture is missing. For the first part, you will not see the display... be patient you will see it. I will make another one when sun will come back ! (link to come later) My opinion: I'm satisfy of the dashboard altimeter, it work well, I can see it easily in my goggle most of the time. If the glare reflect on the display, I tilt my head to see the display. The Vision OSD is deceiving, I was barely able to see the data in my goggle. I can relocate data in the bottom of the picture, it's the only places I will see something. Above that, the OSD work well, voltage current data etc are usefull. I will use it in my Cap Maniac, it will work fine. |
Thank you VRflier.
I guess the altimeter is next. I've had my plane all set up for three weeks or so and have not had a chance to fly, but at least I keep adding things. Pete |
Latest blog entry: A WASP named Brownie
Automaic zero, WOW, I do not read the programmation function because I was thinking I will found nothing for me... I will remove my button. Yeah I see that, only four wire was neccessary, I will cut one. Thank for info. |
MX |
I modified my modified ZLOG today
![]() The ZLOG is a piece of electronic art. It's so well design. The only thing I not liked was to need to push button at power up... Now this problem is gone... We can also shut down the led in the pogrammation, kmowing that I would not removed the led resistor... For the price the ZLOG have a lot to offer and have an amazing accuracy. This mod is easy to do and it work very well on the planes as dashboard display. I forget to say, I use wide angle lens, 80 deg. If you use 45 deg lens like on most of the cam on the market, the result will not be the same, evidently. You will see the display, but it will out of focus. I'm still not able to upload to Goggle video, I had no problem to upload to Youtube, but the quality is not good at all. I will try again tonight and try with another video. http://www.youtube.com/my_videos (I'm not sure if this link work, can you tell me) |
| Thread Tools | |
| Discussion Hello again! :-) And an Update on my UAV Project. Any Thoughts Welcome... | FirmamentFX | UAV - Unmanned Aerial Vehicles | 7 | May 17, 2007 04:31 PM |
| Cool FPV project: Adding digital altimeter on the dashboard of my Easystar | VRflyer | Video Piloting (FPV/RPV) | 0 | Jan 05, 2007 01:14 PM |
| I see an E3D in my future | Kosh | Sport Planes | 17 | Jul 01, 2003 02:21 AM |
| Information needed for adding an electric motor to my plane | Biggles604 | Sailplane Talk | 1 | Oct 24, 2002 02:39 PM |
| I need an upgrade on my zagi esc and motor | thor4944 | Aircraft - Electric - Airplanes (FS/W) | 15 | Aug 28, 2002 06:43 AM |
