Old Oct 22, 2006, 12:28 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Alert
E-Max 2210/25 and 2210/30
Do not try this at home!
The prop recommendations and associated data sheets for these two E-max motors (as published on the XUS Hobby website - http://www.xushobby.com/servlet/Detail?no=199) are dangerously incorrect.
For the 2210/25, the performance figures given are for use of the 10x5 APC E prop on 2s - indicating an amp draw of 13A. For the 2210/25 just an 8x4 GWS HD on 2s voltage (6.9v) drew 14.80A! This prop (and a 7x5 APC E, which draws 15.00A @ 6.9v) are about as much as this motor can handle on 2s. I found that excellent props for this motor, on 3s, were the 5.1x4.9 Zagi Carbon: 10.9v, 13.45A, 147W, 18150rpm, 84.2mph, 477g, 16.80oz, 3.24g/W or the 7x3.5 GWS HD: 10.9v, 16.70A, 180W, 17190rpm, 57.0mph, 794g, 27.96oz, 4.41g/W. With neither of these props, did the motor temperature, at the end of a standard series of bursts to WOT, exceed 44C.
For the 2210/30, the performance figures given are again for use of the 10x5 APC E prop, but on 3s - indicating an amp draw of 17A. For the 2210/30 the 8x4 GWS HD on 3s voltage (10.9v) drew 15.50A, and a 10x5 APC E at only 7.8A drew 15.70A [imagine what it would try to pull on 3s (10.9v)]. In both cases, after very short runs, the motor temperature had soared to over 70C. A good, if conservative, prop for this motor is again the 7x3.5 GWS HD: 10.9v, 9.40A, 102W, 14400rpm, 47.7mph, 529g, 18.63oz, 5.19g/W. [the motor temperature rose only 1C - from 36C to 37C - during the series!] The 7x5 APC E is a possibility: 10.9v, 16.00A, 171W, 11250rpm, 53.3mph, 625g, 22.01oz, 3.66g/W - but the motor temperature was over 60C at the end of the series. I am sure that the stated 17A max is unreasonable for this motor.
It seems illogical that the higher Kv motor - 2210/25 (2100Kv) - should have a lower max amp rating (13A) than has the lower Kv 2210/30 (1400Kv) motor (17A). Perhaps these max amp ratings, like the ridiculous prop sizes, are simply typographical errors.
Be careful out there!
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Max Amps for a Jeti 30/3 Flyguy55 Power Systems 12 Feb 08, 2003 07:19 PM
E-Flite Maxx 25 ESC how many servos can this thing handle KenP Power Systems 2 Jan 30, 2003 06:02 PM
What prop for crazy max 4.25 gearing? alvinm Parkflyers 8 Jan 19, 2003 11:02 PM
E-Streak on Mega 22/30/3 (it will fly, just a question of when...) CrazyMike Sport Planes 35 Dec 18, 2002 02:56 PM
e-flight maxx 25 speed controller help WickedFunRC Foamies (Kits) 0 Jul 24, 2002 10:09 PM
