Old Oct 21, 2006, 09:04 PM
wolfpack72 is offline
Find More Posts by wolfpack72
wolfpack72's Avatar
Texas
Joined Jul 2006
Yippee!
Maiden flight G P ElectriFly F4U-1A Corsair
Flew my new Corsair today for the first time! This thing scoots! I didn't use the stock motor instead I installed the GWS GWBLM002 along with a 25 amp GWS ESC and a tenergy 11.1 800 mah lipo battery. These motors are great you can get motor and ESC for 45 bucks total. Any way back to the plane flight, todays conditions were 12 MPH winds with 22 MPH Gust and this plane wasn't phased a bit by the wind.
At first I was a bit scared to fly it due to the wind conditions as lite as the plane is so I first brought out the old trusty E-Flite Jug. After flying this one ok it was time for the Corsair. With the motor setup in it this thing, it took off like a rocket and was up high in the sky in a few seconds. I was doing inverted loops nice soft loops nice rolls and some more inverted flight. all I can say is this thing ROCKS! Sorry E-Flite but I now have a new favorite war bird. Not bad for a 33.00 dollar plane! P.S. it looks really cool too LOL
wolfpack72 is offline Find More Posts by wolfpack72
Old Oct 21, 2006, 09:23 PM
wolfpack72's Avatar
Texas
Joined Jul 2006
New Electrifly F-4u Corsair pics
Old Oct 21, 2006, 09:53 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
How did the alieron linkage go on yours? I wound up with a servo in each wing and it still leaves a bit to be desired. I installed a Typhoon micro-6/20 brushless that has been gathering dust for a couple of years.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Oct 22, 2006, 12:59 AM
wolfpack72's Avatar
Texas
Joined Jul 2006
It worked out good it was a little tuff trying to get both wires thru the hole w/ my big fingers but it worked good. The wires now come preinstalled for the Ailerons. I had read links on it where the holes were plugged when they tried to push the control wires through, so I guess they listened and fixed the problem.
Old Oct 22, 2006, 09:23 AM
Tim Wolff's Avatar
Joined Sep 2002
Yep. The pushrods are factory installed. The alierons were really giving the HS-55 a workout. I think it was a combination of the severe angle of the pushrods to the connector and the stiffness of the alieron "hinges". I didn't see that poor servo lasting long and I wasn't getting much throw at all either.
Old Oct 22, 2006, 12:30 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
Do not fly with stock aileron setup using stock servo position and stock "easy connector". That combination results in a too sharp angle at the clamp point you can barely get any "up aileron" throw. I tried it and the aileron response is like you max out the expo setting and the plane respond to full left or right stick with almost several seconds of delay. Too dangerous to fly like that.
Either switch to a Dubro "easy connector", which is shorter, or try mounting the servo from the bottom. That would get you much better "up aileron" throw.
shschon is offline Find More Posts by shschon
Old Oct 22, 2006, 12:58 PM
wolfpack72's Avatar
Texas
Joined Jul 2006
I have some of those I'll give it a try. Does it make it better cuz its not as tall as the stock connector? Thats the only difference I see that and the screw in bottom VS the rubber holder.
Old Oct 22, 2006, 02:37 PM
alienx is offline
Find More Posts by alienx
alienx's Avatar
Union County, New Jersey
Joined Apr 2006
Congratualtions on the good flight!
alienx is offline Find More Posts by alienx
Old Oct 22, 2006, 03:04 PM
Tim Wolff's Avatar
Joined Sep 2002
I went straight to the Dubro micro connector, but the servo was buzzing and the output arm bent, even at neutral. I finally broke down and cut holes for servos in each wing for a couple of Blue Arrow 3.6g servos. Still not the best, but light years ahead of the stock setup. I'm still considering cutting the alierons free and using some real hinges. Just getting the gear in final positions. Flying weight is going to be about 14.5 oz. (what a pig).
Old Oct 22, 2006, 09:54 PM
wolfpack72's Avatar
Texas
Joined Jul 2006
Have y'all ever used a three blade prop on this plane?
Old Oct 22, 2006, 10:56 PM
shschon is offline
shschon's Avatar
Joined Aug 2004
Yes. I have used FSK 3 blade 9x7 prop on 3 different power systems. All work great for this plane.
The stock power system with FSK 3 blade use 2 cell LiPo drawing 9~10Amp full throttle, thrust around 14~15 oz.
MPJet Red 2 cell draws around 12 Amp and crazy amount of thrust.
400XT 2 cell draws around 8+ Amp and thrust slightly better than stock but hold on to load much better than stock.
Old Oct 23, 2006, 08:00 PM
wolfpack72's Avatar
Texas
Joined Jul 2006
I put the dubro connectors on today and they doo work alot better. Seemed like less stress on the servo with it. Thanks for the help.
Old Oct 23, 2006, 10:49 PM
miljnor is offline
Find More Posts by miljnor
hammer slammer
miljnor's Avatar
huntington beach, CA
Joined Sep 2005
hey, where do you get those FSK props???
miljnor is offline Find More Posts by miljnor
Old Oct 24, 2006, 12:19 AM
shschon is offline
shschon's Avatar
Joined Aug 2004
http://www.hobby-lobby.com/slowprop.htm
Hobby-Lobby sells them. Stock number FS200, FS300, FS400 and FS305. You can also get individual blades for $1 each.
Old Oct 25, 2006, 06:17 PM
Tim Wolff's Avatar
Joined Sep 2002
Just got back from my madien flight. It's a fairly smooth plane that goes where you point it. The Typhoon 6/20 hauls it quite well (esp. for an unused motor that pratically fell apart while in storage). Low passes look great. Loops as big as you want. Does a typical Corsair barrel roll. Dosen't feel like the floaty planes in the GP video. But, does slow down nicely for landing.
BTW: wolfpack72, take a closer look at that first pic. and put your pants back on
Sold Great Planes ElectriFly F4U-1A Corsair EP ARF 32.5" FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 5 Oct 18, 2006 01:34 AM
Sold Great Planes ElectriFly F4U-1A Corsair RTF FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 0 Oct 07, 2006 01:45 AM
Sold Great Planes ElectriFly F4U-1A Corsair RTF FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 28, 2006 02:17 AM
Discussion Great Planes ElectriFly F4U-1A Corsair nelsonmay10 Electric Plane Talk 1 Jul 20, 2006 11:40 AM
Discussion Does anyone own a Great Planes ElectriFly F4U-1A Corsair EP ARF 32.5" ace128 Electric Warbirds 5 Apr 26, 2006 10:28 AM
