Old Oct 21, 2006, 02:04 AM
CurtissP40 is offline
Find More Posts by CurtissP40
Bona Fide Cub Nut
CurtissP40's Avatar
Northwest Oregon
Joined Jan 2006
Question about brushless motors, props, and programmable ESC's
I am considering building a semi-scale motor-glider with a cowl that may be too wide to permit a folding prop. Is there a way to allow the prop to spin with the wind without using power?
At this point in the project, I am open to any number of solutions - including the use of one of those variable pitch prop & motor combinations.
Thoughts?
P.S. If this is an inappropriate forum for this question, PM me, and I will move it.
CurtissP40 is offline Find More Posts by CurtissP40
Old Oct 21, 2006, 02:17 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Unless you activate the break feature, the prop will spin with the wind anyway.
A spinning prop will actually add more aerodynamic drag than a stopped prop tho. Is that what you want?
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Oct 21, 2006, 02:20 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Free spinning props are very draggy.
If you can't get the prop to fold you are better off with a strong brake.
Several ESCs, including Castle, give you the option of brake or no brake.
If you choose a higher rpm, smaller diameter prop instead of a bigger slower turning one drag in glide mode will be reduced at the expense of some climb performance.
A folder is the best option if possible.
Pat Mackenzie
pmackenzie is online now Find More Posts by pmackenzie
Question Quick question about brushless motors davidg2 Power Systems 3 Apr 25, 2007 09:33 PM
Sold NEW 60Amp Brushless Fully Programmable ESC's $45 ndflicks Aircraft - Electric - Power Systems (FS/W) 10 Apr 27, 2006 05:37 AM
Sold 2 Brushless motors and 3 BL ESC`s mlehman Aircraft - Electric - Power Systems (FS/W) 4 Feb 23, 2006 11:50 PM
quick question about brushless esc w/ lipos buffpants24 Power Systems 5 Jul 19, 2005 05:40 PM
RX Interference with Brushless Motors and Castle Creation ESC's PaddyinDublin GWS (Grand Wing Servo) 2 Jun 11, 2004 05:21 PM
