Old Nov 20, 2006, 10:38 AM
LARMARK is offline
Find More Posts by LARMARK
Michigan
Joined Sep 2002
I have tested and used the Dymond 4.7. I forgot to put it in my post. It was the best sub 5 gram servo. Actually it was the only sub 5 gram servo that had acceptable resolution and centering. The best overall was the E-Flite S-60 which is 5 grams without the lower servo case and no servo arm. I wish they were not out of stock for the next couple of months.
Larry
LARMARK is offline Find More Posts by LARMARK
Old Nov 20, 2006, 08:31 PM
KatManDEW is offline
Find More Posts by KatManDEW
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
I tested the following servos: Futaba 3110, HS 55, Futaba 3108, Airtronics 94091, Eflight 75, Saturn 4.4, HS-50, GWS Pico, GWS Naro, Interflight 4.3, JR241, FMA PS 20, Saturn 5.4, Bluebird 303, Cirrus CS 101, Eflight S-60 and Waypoint 60.
I would be interested to hear how these compare to the Dymond 4.7's. I got some Dymonds a few weeks ago and I'm stunned by how much better they feel flying than what I've used before (several of the above).
KatManDEW is offline Find More Posts by KatManDEW
Old Nov 20, 2006, 09:37 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
I hear ya Kat, the Dymonds have won me over. I just ordered a half dozen more. Not only do they feel better in the air, they are very fast and did you notice the construction? For a $20.00 servo there was a lot of attention to quality.
Until someone can produce another servo with this quality,speed,weight, centering,and what is often over looked, "current draw". I see no reason to spend $5.00 to $7.00 less on lower quality. The Dymonds are going to be very hard to beat
power is offline Find More Posts by power
Old Aug 22, 2007, 11:22 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
I just received two new Hitec HS-55 today, and they came with different servo arms:
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Aug 22, 2007, 01:44 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
That's good. I once spent about an hour making those long ones out of plywood.
Tom
Trisquire is offline Find More Posts by Trisquire
Old Aug 22, 2007, 03:40 PM
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
I just ordered another dozen Dymond 4.7's. I wish there were bigger arms available for them.
Old Aug 22, 2007, 06:26 PM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
From where,plz? I am looking for them.
Malves is offline Find More Posts by Malves
Old Aug 22, 2007, 07:23 PM
WingsWest328 is offline
Find More Posts by WingsWest328
Ritewinger
WingsWest328's Avatar
Jacksonville, Florida
Joined Dec 2005
http://www.rc-dymond.com/order_servo_dymond.htm
WingsWest328 is offline Find More Posts by WingsWest328
Old Aug 22, 2007, 08:46 PM
Malves is offline
Joined Jun 2004
I thought they were out of stock.
Old Aug 22, 2007, 09:08 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
You really don't need long servo arms, just use shorter control horns on the surface. I use mostly D-47's on indoor planes and have over 60 degrees of throw on a few using stock arms.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Aug 22, 2007, 10:16 PM
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
That's what I've been doing. But it doesn't work quite as well as I would like with the stock control horns on some "ARF" foamies, which can't be shortened.
Old Aug 23, 2007, 09:00 AM
Joined Sep 2000
Originally Posted by hpapilot
You really don't need long servo arms, just use shorter control horns on the surface. ...
RJ
Longer arms provide more precision.
Jürgen
Old Aug 23, 2007, 09:41 AM
RCAV8R13 is offline
Find More Posts by RCAV8R13
I'm goin' Falcon nuts
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
Jürgen
How do you figure that?
Longer control horns at the control surface with a short arm at the servo will produce more precision. Is that what you meant?
RCA
RCAV8R13 is offline Find More Posts by RCAV8R13
Old Aug 23, 2007, 10:22 AM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
I like long arms/horns.
Long arms AND control horns give you bigger arm/horn movement for a given angle of control surface movement. This larger movement is a good thing... making up for some of the slop in your linkage and/or hinges. It also seems is easier to get rid of the "slack" in pull-pull controls... it does feel more precise.
RCA
dawsonh is offline Find More Posts by dawsonh
Old Aug 23, 2007, 08:14 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Haha oh great, what a debate I sparked.
Obviously with short servo arms and long control horns, you gain precision and torque, but loose speed and surface movement, and vice versa.
But yes, linkages tend to suffer less slop when BOTH the servo arms and control horns are longer. You get the same amount of throw with less slop...
RJ
FS:New Hitec Servos, 555 receiver, RX battery.. ScottsdaleFlyer Aircraft - Electric - Airplanes (FS/W) 22 Oct 07, 2002 10:38 PM
FS: HL Jerry Hotliner New Wing servos installed Atindra Aircraft - Electric - Airplanes (FS/W) 5 Sep 27, 2002 03:18 PM
FS Price reduced 4 new standard servos and rx battery hnearnest Aircraft - Electric - Airplanes (FS/W) 0 Apr 10, 2002 06:59 PM
New Jr Batt, New Jr Servos, Hitec Rx W/xtl, Electronic Mixer saint152 Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2002 12:26 PM
WTB new 148 servos fourstarforty Aircraft - Electric - Airplanes (FS/W) 6 Jan 14, 2002 12:44 PM
