Old Oct 03, 2012, 02:22 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Hi Eloy,
Wow, talk about a resurrected thread
I did convert 4 old Airtronics 72Mhz receivers to work with the 9C I bought back in '06. They worked very well while I flew on 72Mhz. Since then I've converted to FASST and never looked back. My last flight on 72Mhz ended poorly, since I forgot to pull the antenna, big problem when you're switching back and forth, so I fiqured it'd be better to just keep going forth, rather than keep switching back
Cheers,
pete
pilotpete2 is offline Find More Posts by pilotpete2
Multiplex EVO and negative shift RX owners twohsieh Radios 84 Mar 27, 2004 09:27 AM
FS: Hitec 555 RX - Negative Shift cadconversions Aircraft - Electric - Airplanes (FS/W) 5 Feb 12, 2004 06:57 PM
FS: Hitec 555 rx - Negative shift - Save $17.50 + S&H now! cadconversions Aircraft - Electric - Airplanes (FS/W) 7 Feb 10, 2004 11:12 AM
WTB- negative shift RX butaford Aircraft - Electric - Airplanes (FS/W) 1 Nov 13, 2003 07:36 AM
WANTED: GWP-4P Rx, Negative (Hitec/Fut) Shift DaJudge Aircraft - Electric - Airplanes (FS/W) 2 Dec 17, 2001 12:05 PM
