Old Jun 29, 2001, 06:57 PM
bluex is offline
Find More Posts by bluex
Atlanta, Ga
Joined Jun 2001
Any problems using a 4 channel receiver with a 7 channel radio?
If I want to bite the bullet and get a 7 channel Hitec transmitter, will I still be able to use it with their 4 channel feather receivers?
bluex is offline Find More Posts by bluex
Old Jun 29, 2001, 07:07 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Yep - no worries.
Channel 5-7 in your case will just do nothing.
Haldor is offline Find More Posts by Haldor
Old Jun 29, 2001, 09:09 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
That just about covers it!
Bluex - you gonna come out to Fayette Flyers field tomorrow and meet a bunch of e-flyers?
..a
Old Jun 29, 2001, 11:10 PM
Erik Johansson is offline
Find More Posts by Erik Johansson
Gothenburg, Sweden
Joined Jan 2001
No problems here with a 9 channel radio using a 7 channel receiver
/Erik
Erik Johansson is offline Find More Posts by Erik Johansson
Old Jul 03, 2001, 10:35 AM
Flying is offline
Find More Posts by Flying
Northants UK
Joined Jun 2001
In theory there should be no problem but I have heard it said that in marginal conditions the receiver is more susceptible to interference during the period of the unused channels while waiting for the sync pulse to reset the pulse counter.
Sorry - dont know any more than that
I'm Flying
Flying is offline Find More Posts by Flying
Old Jul 04, 2001, 05:46 PM
Keithw is offline
Find More Posts by Keithw
Keithw's Avatar
Auckland New Zealand
Joined Mar 2001
You can even use the mixing functions to mix channels 5,6,or 7 down to the other channels.
eg on a 2 servo wing, the second servo is channel 6 on a JR set.
Mix this down to channel 4 (assuming you are not using it for rudder) & with a bit of other mixing you can get flaps & spoilers as well as ailerons- all on a 4 channel receiver.
Haven't worked out how to get aileron differential tho.
Keithw is offline Find More Posts by Keithw
Old Jul 06, 2001, 12:23 AM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
As Keithw notes, using the programable mixes, you can move some functions around. The built-in mixes are usually easier to use, but if you're trying to do something goofy, you can usually accomplish by using a couple of the programable mixes. Unfortunately, I haven't found a really clear book or manual on the subject (Edberg's books and the manufacturer's manuals are a good starting point, but I've rerely gotten a direct answer from them - only hints on how to do something). What I know I've gleened from others and by hacking around on my own.
I once had a 4 Ch Rx with a broken pin on the Ch-1 connector. As a field fix, used two programmable mixes on a Futaba 6AX to move the aileron channel to the rudder servo output. I set one programable mix to mix Ch-1 100% to Ch-4 (which wasn't in use) and a second mix to mix Ch-4 -100% to Ch-4. The first mix duplicated channel 1 on channel 4's output. The second mix disabled the rudder stick from affecting the servo.
While I haven't tried it, I'll bet you could get two servo differential by the following. Set the two servo aileron mix (or program it manually to Ch-4). Set the Ch-1 ATV (or ATV's equivalent on your Tx) to the reducted down deflection you want on the aileron connected to the Ch-1 servo. Then set the ATV on Ch-6 (or Ch-4 if you've used a programmable mix to move the second servo to Ch-4) to the reduced down deflection you want on the other aileron. You may have to re-adjust the subtrims on each channel slightly but this should work to give more up deflection on each aileron and less down.
- Roger
Oh, yeah! Bluex: Get the Eclipse, you won't be disappointed.
gnofliwr is offline Find More Posts by gnofliwr
Any problems using a square prop on a sport plane ? Al P Sport Planes 15 Jan 18, 2005 05:34 PM
Powering a 8.4 V motor with 7.4 V Lipo Pack pellowe Power Systems 6 Nov 20, 2004 08:32 AM
Any one using the 4/5 AUP 1950 nimh cells for F5F/F5B type currents? bfraser Batteries and Chargers 28 Mar 31, 2003 12:09 PM
Can I charge a 4.8v pack with a 7.2v charger? webnetxpress Batteries and Chargers 5 Jan 07, 2003 05:40 PM
Any problems using a GWR 4P receiver i a Zagi ? Al P Electric Plane Talk 5 May 01, 2002 09:05 AM
