Old Oct 17, 2006, 08:12 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Build Log
36 inch ritewing DEMON
Welp i guess i should have had this done a few days ago but here goes. Pictures with sub titles to help define what im doing.
But it will be a basic
36 inch demon kit
2 x hs255mg servos
Double komodo 7 turn 5 starnd 30g 12 magnet
Battery;'s still not sure about but thinking 4s 3300 20c (I have those)
lest see as time goes on what i wind up doing.
Here are the pic's
PaulVi is offline Find More Posts by PaulVi
Old Oct 17, 2006, 08:14 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Next steps will begin the covering I have been give a large roll of henrys like cloth, It is the same product just comertial sized for larger jobs
This will help in not having as much overlap and may help keep the over all weight down on this one..
Lets see how it goes..
More to come later..
Old Oct 17, 2006, 08:30 PM
PlusRC is offline
Find More Posts by PlusRC
aka WarpedWingNut
USA, MI, Caledonia
Joined Dec 2004
Looking good Paul.....................I like the thin layer of goop in battery bay idea !
36" with 4S, talk about "pucker power" !!!!!!!!!!
PlusRC is offline Find More Posts by PlusRC
Old Oct 17, 2006, 09:35 PM
Douglas Cheatwo is offline
Find More Posts by Douglas Cheatwo
junkman
United States, AL, Madison
Joined May 2004
I have a wonder cutter. Never thought of using it to cut carbon fiber grooves the way you are using it. Great idea! I will try that.
Douglas Cheatwo is offline Find More Posts by Douglas Cheatwo
Old Oct 18, 2006, 12:35 AM
junkman
Joined May 2004
Paul
What is the name and type of cloth you are using. Where can it be found and the name of the mfg. It looks like fiberglass but much wider than Henry's.
Old Oct 18, 2006, 12:36 AM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
All Up weight before glassing begins.. This includes the 2 servos
That glass was a find at a buddies house who was moving out i saw it while helping, it is designed for roof repair but on a large scale and is a comertial product. I asked him where he got it and it was too long ago fror him to remember.. I am on the hunt for it if it works well for this it may work well for others.
This is on a large cardboard spool like wraping paper..
I will attemp to get more info on it, the guy next door does all kinds of repairs with highrises and roofing he may know a source for it next time i see him i will show him and ask..
Old Oct 18, 2006, 12:50 AM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Something else..
when im working on one of these wings i always keep them in the saddles so that no worps crrep into the cores during the building process it just helps when things are setting up..
So each night or if im not going to work on it a while i load it into the cores and put the weights onto it so force it to hold its shape..
Old Oct 18, 2006, 11:12 AM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
where do you guys buy ritewings at?
web?
store?
punkrockd is offline Find More Posts by punkrockd
Old Oct 18, 2006, 01:27 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I have been getting mine from monsoonrc.com but a few other web sites carry them as well..
Old Oct 18, 2006, 01:31 PM
Pezzer is offline
Find More Posts by Pezzer
The Original Slacker
Pezzer's Avatar
Bristol, TN
Joined Apr 2005
GREAT looking start Paul! Wish I could have seen that one fly before I left reno. Oh well.
Hey CK I want some stickers also. Do you sent them to exsisting customers?
Good luck on the rest of the build Paul...
-Dave
Pezzer is offline Find More Posts by Pezzer
Old Oct 18, 2006, 01:32 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Well it looks like I'll have to add in some pics myself of my Demon
and mini-me Demon build.
I'm thinking of cutting all the way through for the battery bay to make
more room for the lipos.
Should be a screamer!!!
One question Paul - you went with PU instead of the CK way of joining
the two halves with the 90. One better than the other? I don't think so since
it will be glassed in the end.
fly_boy99 is offline Find More Posts by fly_boy99
Old Oct 18, 2006, 01:41 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Let me clarify that
I used PU in the spar holes for the center spar followed by a spray of water and then ran the CF tube in and out to mix it up.
Did that for both halves
Then to save time i used Hot glue to join the halves togeter and let the mess set up over night in the saddles till the PU cured.
The super 90 works well and is lighter but I like using the hot glue and i have had fair results with it.. Althoug when cutting the bays out the hot glue does not cut as well as the Super 90..
As a sid not i use Hot type hot glue to join the halves but am carfule not to get it so hot that it melts the foam
Old Oct 18, 2006, 02:19 PM
fly_boy99's Avatar
Thanks good to know...
Old Oct 18, 2006, 07:45 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Mystery solved.
The yellow cloth i have is called Yello Jacket Guess what?
Its made by henrys..
http://www.whitecapdirect.com/store/...h=8&text=113YJ
CK you might be able to use a 150 foot roll HAHAHA
Sold 36" Ritewing Demon, RTF!! chuckand Aircraft - Electric - Airplanes (FS/W) 3 Nov 06, 2006 08:37 AM
Build Log When less is more (36" Ritewing Demon Project) chuckand Flying Wings 24 Nov 04, 2006 09:42 AM
Best Price On 36 inch EPP Wing Cores? 7thSon Foamies (Kits) 9 Apr 29, 2004 05:45 PM
Tigermoth Kits larger than 36 inch span? windsurfer Scale Kit/Scratch Built 6 Feb 17, 2004 08:41 PM
36 Inch Wingspan Zagnutz jerbear Foamies (Kits) 2 Apr 17, 2003 03:29 PM
