Old Oct 17, 2006, 04:07 PM
Water Boy is offline
Find More Posts by Water Boy
Water Boy's Avatar
Greenview,IL
Joined Feb 2006
Question
New to SPAD need some help with Coroplast.
I'm new to this forum and to building with CP. Theres a company in my town that can get me some 4mm coroplast. Is this a good size to build with? The only other size they can get is 10mm. Also what price range should I look at for a 4'X8' sheet in white. They are gonna charge me around $18 for a sheet. Is this a good deal or can I get it cheaper?
Thanks Harry
Water Boy is offline Find More Posts by Water Boy
Old Oct 17, 2006, 06:58 PM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
I usually pay about $15cdn a sheet and $18 for colors, you can always check out a local sign shop, they should have some.
Wayne V is offline Find More Posts by Wayne V
Old Oct 27, 2006, 03:32 PM
Water Boy's Avatar
Greenview,IL
Joined Feb 2006
Well I picked up the sheet of coroplast today. I have expieremented with this stuff a little and came out ok. One problem I encountered was cutting the plastic at an angle to the flutes. Is there a trick to this or should I just cut it like any other direction?
Not sure what I want to build first but its gotta be electric. Any ideas?
Harry
Old Oct 28, 2006, 10:25 AM
Smooth Spanky is offline
Find More Posts by Smooth Spanky
Hack of all trades...
Smooth Spanky's Avatar
Detroit, Michigan
Water boy:
Cutting diagonally across coro is always a bit of a challenge for me. The trick is to have very firm pressure on your straight edge, if using one, and cut on a mat or something that isn't a completely hard surface. I also try to do follow a path where if the blade slips it will go outside, not inside of the pattern I'm trying to cut.
Good luck.
SS
Smooth Spanky is offline Find More Posts by Smooth Spanky
Old Oct 28, 2006, 04:05 PM
Steve-S63 is offline
Find More Posts by Steve-S63
Steve-S63's Avatar
Houston TX. (Friendswood actually)
Joined Jul 2004
When cutting at an angle to the flutes you need to make sure the flutes are pulling the blade into the straight edge and not away from it. I've also found that the cutting mats for sewing, from Wal-Mart etc., are a great backing for cutting on.
Steve-S
Steve-S63 is offline Find More Posts by Steve-S63
Old Oct 29, 2006, 10:29 AM
Water Boy's Avatar
Greenview,IL
Joined Feb 2006
First Wing..
Here is my first attempt at a Coro wing. W.S. is 30", Chord is 5.75" w/o ailerons. Used a 3/8 dowl for the spar. Coro is 4mm (all I have).
The airfoil is pretty thin so it should be fairly fast? Think on this build I will keep it simple and do an ugly stickish type fuse. Not sure if the ailerons are to long or not, they are 1 3/4" thick, if anything should be a little more responsive. Any comments feel free to post.
Harry
Old Oct 30, 2006, 11:53 AM
StrangeGager is offline
Find More Posts by StrangeGager
United States, MI, South Lyon
Joined Aug 2004
I think a wing that small needs 2mm coro. I used to buy mine from harborsales.co(i think). Don't be surprised if you end up with a brick.
StrangeGager is offline Find More Posts by StrangeGager
Old Oct 30, 2006, 11:56 AM
Joined Aug 2004
go here:
http://www.harborsales.net/fullsheet...ts#productview
Old Oct 30, 2006, 03:12 PM
John Palica is offline
Find More Posts by John Palica
Vernon, Connecticut
Joined Oct 2003
Have Harbor Sales cut the 4' by 8' sheet to 2' by 4' pieces with the flutes running in the 2' direction. If you ask for a full sheet, the shipping will drain your bank account. The 4X8 ships for $98.00. If you have them cut it, you'll pay $2+ for cutting and the shipping will be about $4.50 (depending on your zip code). That has been my experience with shipping to the North East. They have 2, 4 and 10MM in many colors.
John Palica is offline Find More Posts by John Palica
Discussion I need some help with my BCX2 and new Microheli CNC RotorReaper Coaxial Helicopters 14 Jan 14, 2007 06:05 PM
i need some help with designing a new type of ducted fan thailandboy2 Foamies (Kits) 16 Jun 07, 2005 05:59 PM
need some help with new hanger 9 electric sailplane Bodydir Beginner Training Area (Aircraft-Electric) 3 Sep 30, 2004 09:45 PM
Iím new and need some help with micro helis HomerHriss Electric Heli Talk 17 Aug 01, 2002 11:00 AM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
