E-Flite's 25 Electric J-3 Cub 25 ARF Review
With the introduction of their 25-size J-3 Cub ARF, E-Flite again gives us a beautifully designed and detailed electric model...complete with scale ailerons! But it gets even better! Read on as Ronnie Pope provides us an in-depth look at this new release.
Wingspan:62"
Wing Area:550 sq. in.
Weight:4.0-4.25 lbs.
Length:35.5"
Wing Loading:17.27 oz/sq. ft.
Servos:four JR Sport MN-48
Transmitter:Hitec Optic 6
Receiver:JR RS600
Battery:EE-flite 10-cell 12V 1800mAh Ni-MH (EFLB4010) or Thunder Power 3-cell 4200mAh Li-Po (THP42003S2PPL)
Motor:E-flite Power 25 Outrunner (EFLM4025A)
ESC:E-Flite: 40 amp brushless
Prop:12X6 E
Manufacturer:E-Flite
Available From:Horizon Hobby
The Piper Cub, one of the most popular and influential light aircraft ever manufactured, is still synonymous with general aviation in the United States, even more than 80 years after its introduction. Initially powered by a 40-horsepower engine and selling for $1,300, the uniform color for the Cub was bright yellow, trimmed in black. Lilliputian by today's standards, the two-seat J-3 Cub was only 22 feet 2 inches long, stood 80 inches high, and had a wingspan of 35 feet 2 inches. Later powered by the Lycoming 65-horsepower engine, the J-3 Cub attained a maximum speed of 85 miles per hour with a ceiling of 9,300 feet. Even more remarkable, the fuel tank held only 12 gallons, sufficient to fly about 190 miles. Compare this to your modern automobile! Although Piper Aircraft ceased production of the venerable Cub after WWII, there are many still in use today, and it has become a staple aircraft in many an r/c enthusiast's fleet.
Unlike nearly every modeler I've ever met, I had never owned a Cub, so upon hearing that Horizon Hobby was introducing a 25-size electric model, I knew I wanted one!
Kit Contains:
  • 2-piece wing w/pre-applied decals
  • Fuselage w/pre-installed pushrod tubes
  • Tail group w/pre-applied decals
  • Pre-painted landing gear
  • All necessary hardware
Kit Requires:
  • Power 25 brushless motor
  • E-Flite 40 amp ESC
  • 4 -JR MN-48 servos
  • 2 - 12" servo extensions
  • 2 - JRPA212 long servo arms
  • Thunder Power 3S2P 4200 Lipo battery or E-Flite 1800 Nimh battery
As always, E-Flite's instructions are excellent, and I won't rewrite them here. Instead, lets look at an overview of the build, and a few tips, highlights, and one "oops", which has been fixed in later production kits.
The entire assembly was simple and straight forward. For the wing -- install the wing joiner, CA hinges, servo blocks and mount servos to the doors. Extra-long JRPA212 servo arms were used to allow clearance and control throw for the aileron servos.
TIP: It is always best to have an extra set of hands when gluing wing halves together, especially a wing of this size. This helps allow for proper alignment and makes removing the excess epoxy much easier.
The 30" fuselage was extremely light and very strong. The pushrod tubing, motor mounting holes, and a cooling system were factory mounted.
I used the recommended Expert (EXRB100) 4-cell, 4.8v, 720mAh AAA NiMH receiver pack to eliminate the need for the BEC feature on the E-flite 40amp ESC. The fuselage windshield comes pre-trimmed and painted. I used canopy glue and painter's tape on the canopy and windows.
I did have to cut back the covering before mounting the tail. Upon careful checking, I found the alignment of the tail was perfect!
I installed the Expert receiver battery just behind the windshield with velcro. The fuselage even included a tube for routing the receiver antenna out the bottom!
A Motor Mounting Oops -- Fixed in Later Kits
I was surprised to find that the pre-mounted blind nuts in MY J-3 Cub 25 firewall were a different size than the included hex screws that came with the motor. Although the correct matching screws for the pre-mounted blind nuts were included with the J3 Cub kit, they were too large for the holes on the motor's firewall X-mount, requiring they be drilled out. Just be sure to drill the holes out before you attach the X mount to the motor, such as on a drill press.
NOTE: Horizon Hobby has corrected this issue between the Power 25 motor screws and the J3 Cub 25 pre-mounted blind nuts, so your J-3 Cub 25 ARF will likely not need this modification be done.
Ready to Fly
All that was left to do was to install the wing by plugging the aileron y-harness into the receiver, bolting the wing down with the supplied bolts into the pre-installed blind nuts, connect the battery to the ESC, secured it inside the battery compartment with velcro and install the battery door.
The AUW range with the two battery configurations: 60oz with the 3S2P 4200 Lipo and receiver pack, and 63oz with 1800 NiMh pack and receiver battery. As you will read, both packs worked very well!
Is there anything cooler than a Cub on floats?
Along with the Cub 25 ARF, Horizon Hobby sent their optional float kit (part#EFLA500), which also fits their Ultra Stick 25. Made of painted fiberglass and sporting a functional water rudder, the floats can be mounted at the field in about 5 minutes! Designed for easy assembly, I had the floats completed and ready to attach in just over an hour.
All that needed to be done was:
  • unscrew the four landing gear straps,
  • remove the landing gear,
  • attach the floats in their place,
  • connect the flexible water rudder cable to the connector on the rudder control horn.
NOTE: A removable ventral fin mounts under the tail to help stabilize the Cub in flight.
Floats AND the NiMH Pack
Now for the biggest surprise. On the day of the "Cub on floats" maiden flight, I arrived at my club field and realized I hadn't recharged the TP 3S2P 4200 Lipo battery, but I HAD charged the E-Flite 1800 mAh NiMh. Would it provide enough power to fly the Cub off the water? Only one way to find out, so I put the 1800 NiMh on the charger to "warm it up", and in five minutes it was ready. I checked the CG(perfect) and headed to the nearby boat ramp. Keep in mind as you watch the video that it IS the maiden flight on the floats!
As I taxied out to take off, I eased the throttle forward with full up-elevator until the Cub 25 came up "on step", then backed off the elevator and eased into it again. As the Cub gently lifted off the water and into a nice, gradual climb, I was simply amazed at the power the 1800 NiMh battery produced. The Cub 25 seemed unaffected by the extra weight of the floats and slightly heavier battery, and what a beautiful flier on floats she is (you can hear my friend and fellow photographer Johnathan's reaction on the video).
As expected, the J3 Cub 25 flew wonderfully! The maiden was done on an unexpectedly windy day, 8-10mph, with gusts up to 14mph. Needless to say, I was a bit nervous, so I chose the Thunder Power 3S2P lipo pack for extra power, less weight and longer flight time. The J-3 Cub was more than up to the task and handled the wind without any problem, and the E-flite 25 outrunner is a perfect match to this plane, providing terrific power with excellent thrust, swinging the 12 X 6 prop easily. Just like it's full-scale counterpart, the E-Flite J-3 Cub is no speed demon, but I was surprised at the speeds I could attain with full power.
I first practiced taxiing, and this proved extremely easy, thanks to the steerable tail-wheel. The wind was fairly steady at an angle to the runway, but the 60-63oz flying weight proved to be a big advantage in ground handling and gave the Cub a very stable presence.
As a flying friend described, all Cubs "fly on the wing" and after a few passes over the field I immediately understood what he meant, as the Cub lifted off and climbed steadily under full power. Even with the stiff winds, the Cub 25 was rock-solid in the air and flew very scale-like, especially at half-throttle.
As I lined up on the center of the runway, the wind picked up a bit while I slowly throttled to full power. The E-Flite Cub 25 gently lifted off in less than 15 feet and climbed out at a nice shallow angle. Landings were easy and predictable. Be sure to read the sidebar on flying off floats!
Loops
Big, smooth, scale loops are easily accomplished by simply applying full power, entering a shallow dive, and applying about a half stick of up elevator. They are a thing of beauty with the E-Flite 25 Cub.
Rolls
I was very surprised at how axial the rolls were! Just start with some throttle, a little nose-up attitude and full left aileron for a nice, crisp roll. Even with the floats attached, the Cub still rolls nicely.
Hammerheads
Thanks to its large rudder, the Cub will perform nice, smooth hammerheads!
Inverted flight
The Cub will fly inverted fairly well but a good amount of down elevator is needed to keep the nose up.
Stalls
I took her up to a safe altitude and eased back on the throttle to induce a stall, which was very mushy and predictable. The Cub 25 recovers very quickly when throttle is applied.
I would have to say the Cub is not a beginner's plane, but for a pilot with some 3-channel rudder/elevator experience, the E-Flite 25 Cub would make an excellent aileron trainer.
Plusses:
  • Beautifully executed scale design and markings
  • Fast and easy to build
  • Excellent instruction manual
  • Smooth predictable flight manners make it a joy to fly, whether off land or water
  • A great value for the price
Minuses:
  • The minor issue of the mounting bolts, corrected on future kits.
  • Otherwise, the Cub 25 really has none that I can think of!
The E-Flite Cub 25 was an absolute blast to build and fly, and to my surprise, whether you choose the TP 3S2p 4200 Lipoly or 1800 NiMh battery, whether flying off grass, pavement or water, the Cub will reward you with it's wonderful flight characteristics!
In conclusion, I must to say that E-Flite have hit a grand slam with the Cub 25 ARF!
Old Jan 15, 2007, 01:25 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Great review Ronnie - still have a soft spot in my heart for Cubs......miss my 1/4 scale version!
Old Jan 15, 2007, 01:40 PM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Thanks Mike, we sure had fun on the day of the maiden(s)!
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old Jan 15, 2007, 01:58 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Indeed - mine was faster than yours!
Doctor Who is offline
Find More Posts by Doctor Who
Timelord
Doctor Who's Avatar
USA, IN, Muncie
Joined Mar 2002
Ronnie,
Nice video's. Did it seem much harder to fly/control with the extra weight and drag of the floats?
Doctor Who is offline Find More Posts by Doctor Who
Old Jan 15, 2007, 02:27 PM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Hi DW,
Honestly, I could hardly tell any difference, the Cub tracks so well with the floats or without. Maybe a little difference when making a turn, but never unstable.
Ronnie
Old Jan 15, 2007, 04:15 PM
Dora Nine is online now
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Awesome thanks! This may be a good alternative to putting floats on my 40 size H9 Cub. Thanks!
Dora Nine is online now Find More Posts by Dora Nine
Old Jan 15, 2007, 06:20 PM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Dora Nine,
Thanks glad you liked the review! You will be VERY happy with the E-Flite 25 Cub.
Ronnie
Old Jan 16, 2007, 11:56 AM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
Wow, made me miss my 1/3 scale a lot...
Trikster is offline Find More Posts by Trikster
Old Jan 16, 2007, 05:20 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
You lied Ronnie. I have never had a Cub.
Great review though.
feathermerchant is offline Find More Posts by feathermerchant
Old Jan 16, 2007, 05:28 PM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Thanks James I sure thought you did! Maybe it was Kirby
Trikster, thanks. This Cub really does fly like a much larger aircraft.
Ronnie
Old Jan 16, 2007, 09:48 PM
weekending is offline
Find More Posts by weekending
Fish Whisperer
Holland, MI
Joined Sep 2006
Great review and I loved the videos! I am assembling mine right now and it also has the mounting bolt problem, but everything else is on track. Did you notice any bad habbits during takeoff? Some have suggested that the cub is tricky to take off and while I am a marginaly competent pilot, good rudder control abilities seem to elude me. A bit nervous about the pending maiden
Zack
weekending is offline Find More Posts by weekending
Old Jan 17, 2007, 01:05 AM
Trikster is offline
Zoom, zoom...
Trikster's Avatar
Joined May 2003
From the looks of things in the video, you may be able to compensate with the lack of rudder skills by giving it more throttle, take off runs seem short as it is.
Old Jan 17, 2007, 06:02 AM
Taylorman is offline
Find More Posts by Taylorman
Taylorman's Avatar
Cleveland, Ohio
Joined Jul 2006
Weekending,
You have to stay on top of the rudder. My field is grass consequently I have longer take off rolls. I find that 3/4 throttle and staying on top of the rudder with up elevator until you build up speed, then neutral elevator until the tail lifts then slight up elevator is the trick (my cub ground loops to the right if I go immediately to full throttle.) Once in the air, it's a beauty.
Taylorman is offline Find More Posts by Taylorman
Old Jan 17, 2007, 07:56 AM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
That is exactly right! I didn't mention this, but we did three maidens that day, the Cub 25, the E-Flite Super Airliner and Keith Sparks' 757. It was fairly windy at a shallow angle to the runway, which actually helped keep the Cub's tail straight on takeoff.
And as I mentioned before, it handles wind really well!
Ronnie
Originally Posted by Taylorman
Weekending,
For Sale NIB Piper J-3 Cub 40 ARF underh2o2long Aircraft - Fuel - Airplanes (FS/W) 0 Jun 21, 2007 08:34 PM
Wanted Wanted E-Flite J-3 Cub 25 ARF smileyz Aircraft - Electric - Airplanes (FS/W) 0 Sep 18, 2006 04:12 PM
Discussion NEW E-flite J-3 Cub 25 ARF PLUS 25-Size Fiberglass ARF Floats Jim T. Graham Product Announcements 0 Apr 11, 2006 09:00 AM
Electric J-3 Cub problems, Help please. Longarm Scale Kit/Scratch Built 39 Sep 14, 2004 12:25 PM
F/S NEW Hanger 9 J-3 CUB .40 ARF with New Saito FA-56 Golden Knight Slavetonone Aircraft - Fuel - Airplanes (FS/W) 1 Nov 04, 2003 09:26 PM
