Old Aug 25, 2002, 04:10 PM
Salin is online now
Find More Posts by Salin
Heath
Appleton, Wisconsin
Joined Aug 2002
Power Supply Transformer, for hot wire cutter, or flight pack charging
I have read a bunch of posts about the best way to power a hot wire cutter or a convenient way to charge flight packs at home. I just started using a computer power supply.
The one I am using was pulled from an old 486 I had laying around. The drives in computers run at 12 volts DC. And the supply is rated at 8 amp. max current. So its just right for powering your flight pack quick charger. You could even power several chargers off of one supply. It's already in a nice box so you don't have to do any circuits work like some of the posts tell you to do to build Radio Shack transformer. All you needs is a wire striper.
For hot wire cutting I use my charger to regulate the current to the cutting wire. So powering my cutter is just like charging flight packs. Any supply from a 486 or pentium computer will work. Don't buy or make a transformer, when you may have one laying around!
Salin is online now Find More Posts by Salin
Old Aug 25, 2002, 04:38 PM
My Fault is offline
Find More Posts by My Fault
Joined Aug 2002
Yeah, I had an old hobbico charger lying around and it works fantastically on my hot wire cutter.
I still can't get over how easy it was to put one of these together!
My Fault is offline Find More Posts by My Fault
Discussion power supply for hot wire cutter splitesse Slope 3 Apr 30, 2006 06:27 PM
griddle heater for a hot wire cutter???????? new flyer Foamies (Kits) 3 Oct 27, 2004 02:29 AM
Batt charger as power/thermal source for hot wire foam wing cutting bow? - UK Steve Wrona Foamies (Kits) 3 Feb 29, 2004 04:07 PM
Cheap power supply for hot wire cutter ferradas Hand Launch 23 Feb 04, 2003 08:25 PM
