Old Oct 14, 2006, 12:43 PM
firetrappe is offline
Find More Posts by firetrappe
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Mini-HowTo
Detailing Slofly's EPP Foamies With Decal Paper
A number of people have expressed an interest in the method I used to detail my Slofly kits. I have never been very successful with spraying, so I decided to try using inkjet printable waterslide transfer paper. Credit for the idea goes to RCAV8R13 who used a similar method last year for his scratchbuilt Sirocco 2 Bipe (possibly the best looking foamie I have ever seen!). The difference being that I cover the airframe after the build is complete rather than before cutting the parts out of foam.
The decal paper used below was sourced from BelDecal.com. Four sheets of 11"x17" Clear were used for the Mini 3D 28", and three sheets for the Micro 3D 22".
Due to my models already being built and covered, the instructions below were done using a separate Mini 28" horizontal stab and elevator. The same method is used on a completed model.
I hope some of you find this useful.
Si.
firetrappe is offline Find More Posts by firetrappe
Old Oct 14, 2006, 02:13 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
VERY Cool! I've thought about trying the same thing but with self-adhesive vinyl decals. Problem is, I can't seem to find a source for clear vinyl ink-jet printable self adhesive sheets. Would you know of a source?
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Oct 14, 2006, 05:11 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Thanks DT. I also looking into using adhesive labels, but the biggest size I could find were 8 1/2" x 11" which was too restrictive. They would also be heavier, and need covercoating with a clear laquer to make them waterproof. If you fancy giving them a try, they can be purchased from Amazon.com here
Si.
Old Oct 15, 2006, 07:35 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Another good one! I'm adding this to my "tips and tricks" post, firetrappe.
http://www.rcgroups.com/forums/showp...7&postcount=32
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Oct 16, 2006, 03:53 AM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Cheers Brad, glad you likey
Si.
Old Oct 17, 2006, 07:31 PM
Joined Dec 2003
I likey the fact that this is easy and light. I don't think you can get this light using an airbrush (I know I couldn't - or as nice ). It must be a pain for you, but it's nice to have that decal manufacturer over here on this side of the Atlantic.
Old Oct 18, 2006, 11:27 AM
MrFlash is offline
Find More Posts by MrFlash
Flashmeister Aviation Inc
MrFlash's Avatar
Joined Aug 2005
I'd forgotten about Brads super dooper links, this is deffo a keeper and Im bound to forget how FT did it. Add that link in there dude
Thanks again Si, Awesome grafix
MrFlash is offline Find More Posts by MrFlash
Old Dec 14, 2006, 07:59 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I've got some inkjet waterslide transfer paper. I'll give that a try. Thanks firetrappe
abenn is offline Find More Posts by abenn
Old Dec 15, 2006, 05:46 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
A friend of mine is into rubber powered indoor stuff. He prints graphics directly onto Japanes tissue. He does this by taping the tissue to a sheet of printer paper to help it through the printer. he also sets his printer on the lowest ink values to prevent bleeding. The reuts are very good.
This tissue idea could possibly be used to make a decal to apply over foam I think.
BTW where do you get the decal paper?
Dan
leadfeather is offline Find More Posts by leadfeather
Old Jan 10, 2007, 08:51 PM
sloper steve is offline
Find More Posts by sloper steve
sloper steve's Avatar
America the ruling country
Joined Dec 2003
I tried thin tissue taped around the sides on paper and it turned into a mess.
How do you tape it on?
The decal paper is waterproof and at beldecal.com
I've ordered 50 sheets and have some 5 packs if interested here:
http://slofly.com/cart/product_info....oducts_id=1326
sloper steve is offline Find More Posts by sloper steve
Old Feb 15, 2007, 03:41 PM
Joined Dec 2003
Thanks Fire!!
This is so easy I only need to worry about what to put on the decal.
If you have any graphic files to post please do.
Any links to stuff to print on decal paper for the plane would be great!
Old Feb 15, 2007, 03:57 PM
Joined Dec 2003
http://www.rcgroups.com/forums/showthread.php?t=483664
Old Jun 29, 2007, 12:43 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Wow this stuff keeps getting better!
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old Sep 06, 2007, 11:08 PM
Joined Dec 2003
Decals rip and I mean it not literally!
1*0=0 and boolean logic says that 1+1=1 because + is inclusive or.
A Karnauff map deduces this to the most simple terms.
To ask what this means is to use reason to ask about the algorithms of reason.
If this does not tickle you sky blue study inductive, deductive logic, Socrates, Boolean Algebra and Karnauff Maps. All directly related to RC
Google.com is the oracle of 70's TV use it!
Now that we are clear where is all the decal talk taking place?
Oh I can just google it....
Old Sep 07, 2007, 12:44 AM
tallflyer's Avatar
Joined Jul 2002
waterslide decals
Discussion What's your best source for waterslide decal paper? crxmanpat Hot Online Deals 2 Sep 07, 2006 03:48 PM
Need help with White Decal Paper CUBANO8 Parkflyers 0 Apr 23, 2004 09:28 PM
Question S-PCM transmitter with FM micro receiver ? Willy Parkflyers 4 Dec 09, 2001 05:08 AM
EPP repairs with Automotive Goop look promising Al P Foamies (Kits) 6 Jun 27, 2001 06:09 PM
Anyone flying S&B Foamies ? Al P Foamies (Kits) 11 May 09, 2001 09:51 PM
