Old Oct 13, 2006, 09:59 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
LIPO Trick 2: Setting Up a LIPO VOLTAGE CLAMP
Find the best swithcing regulator power supplies with the best wide range adjustment regulator board that has a ten-turn pot voltage adjust, most will only have a single turn pot adjustment
I use the 400W QUALIDYNE model no: 02003 F becuz it has a dualie 12V output at 7 amps and 15 amps monitored with whattmeters so I can read the ZERO charge current when done. I use this to charge 8 packs sometimes setup for 2S and 3S packs
I also found a 24V 4.2 amp switcher for a 6S pack ( 25.2V )
Using them is pretty simple: fly your lipo packs only ~70% duty cycle ( example, 40 amps instead of 56 amps on a TP 8000 7C gen 1 pack ) and charge them back up when the pack voltge is high, if U fly them too low then U will have to precharge them back up ~ 4V per cell using any charger with a CURRENT adjust
The output of a VOLTAGE CLAMP is set open circuit with no-load connected using a DVM or whattmeter
I would to hear about any other brands of swithchers like the QUALIDYNE made by Lamda
hall woo is offline Find More Posts by hall woo
Discussion LIPO Trick #5: Slow Charging Using Voltage Clamps hall woo Batteries and Chargers 33 Oct 26, 2006 07:47 PM
ICE charger with lipo balancers (up/down voltage/current) Nethole Batteries and Chargers 3 Apr 02, 2005 07:03 PM
Question LVC setting for LiPo's AND NiMH dissimilar voltage packs? jbrundt Batteries and Chargers 1 May 06, 2004 07:59 AM
one slightly puffed up lipo in a 3 cell pack fwilly Batteries and Chargers 7 Jul 14, 2003 01:06 PM
Logo 10 Still setting it up after 2 months! Lv2Fly Electric Heli Talk 22 Oct 07, 2002 06:20 PM
