Old Oct 12, 2006, 06:20 PM
Jerambis is offline
Find More Posts by Jerambis
Joined Oct 2006
Bungee launching...
So I have the bungee and pedal release, what now? What should I use to hook the bungee to my FA-18? Should I buy rails? What are my options? Thanks in advance.
Jerambis is offline Find More Posts by Jerambis
Old Oct 12, 2006, 07:08 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
What bungee and pedal release did you buy?
Is it a JePe dolly style for example?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Oct 12, 2006, 08:48 PM
Jerambis is offline
Joined Oct 2006
It is the one on www.warbirds-rc.com site.
Old Oct 12, 2006, 09:00 PM
Operator 88-94 is offline
Find More Posts by Operator 88-94
Plover WI
Joined Sep 2006
I feel Danger
Operator 88-94 is offline Find More Posts by Operator 88-94
Old Oct 12, 2006, 09:44 PM
Jerambis is offline
Joined Oct 2006
Originally Posted by Operator 88-94
I feel Danger
Thanks for the input, that really helped me with my question.
Old Oct 12, 2006, 10:35 PM
Willmsy is offline
Find More Posts by Willmsy
I am the BBQ Ninja
Willmsy's Avatar
United States, MN, Woodbury
Joined Jan 2003
go to this thread, it will help...
http://www.rcgroups.com/forums/showt...ungee+launcher
Willmsy is offline Find More Posts by Willmsy
Old Oct 12, 2006, 11:38 PM
Plover WI
Joined Sep 2006
Sorry if u take it that way ive seen to many people hurt someone or trash there planes without finding out all the input's such as making a ramp and what to set the ramp at as far as degree's and other things before they buy but on the rc forums just type it in and find all kinds of usefull stuff such as ramp or just winginging it off the ground or you will find alot of usefull info on the het f-18 where alot of them can handlaunch it if its setup correctly.
Scott
Old Oct 12, 2006, 11:53 PM
Jerambis is offline
Joined Oct 2006
Scott
That is exactly why I am asking on the forums. Finding out how to setup the bungee launch BEFORE I go out to the field.
Thanks for that link that was very helpful.
Old Oct 13, 2006, 12:28 AM
demetrius is offline
Find More Posts by demetrius
demetrius's Avatar
Van Nuys
Joined Mar 2004
The most important thing to remember is no mater what ramp or launcher you use you must be prepaired to "FLY IT OFF"! Don't think that it will come off correctly each time! I have 400+ maybe a lot more launches then i can remember! I've lauched with and without a ramp and even no bungie just straight power up from ground! (no gear!) Just pay attention to the plane to correct any errors that you may encounter weither it's weather related(wind changing direction) or if for some unknown reason the cord snags on something be prepaired to fly it down to safety! After your hook has released from your plane power up to full throttle and keep her straight gaining altitude and speed!
Good luck and here's my panther without bungie! It's the grey & yellow one after the blue one!
http://www.rcgroups.com/forums/showp...&postcount=505
demetrius is offline Find More Posts by demetrius
Old Oct 22, 2006, 11:22 PM
NCC-1701 is offline
Find More Posts by NCC-1701
Joined Oct 2002
Here what I've learned that works for me. I built a rail launcher like the one shown on yourzagi.com. It's also the same type sold by Classic Flying Machines. I like this particular set-up as there is no trailing release line and ring to snag on the jet after launch.
First, with the set-up, I drive the bungee stake in the ground first and then stretch it out using a fish scale to set the correct tension. I then position the rail launcher and stake it only at the back. I don't stake the front until I have a straight line down the center of the launcher, along the bungee, to the stake.
When I'm readu to go, I:
1. Set the model on the rails.
1.A. If the model has an easy access hatch, I connect the battery now.
2. Test the radio, all controls and the motor.
3. I stretch the bungee cord to the release bolt and set it in place,
4. I now attach the ring on the leader line to the tow hook.
5. I now inspect the underside of the airplane to ensure the leader line is straight and not wrapped on the tow hook.
6. I now hold the release ring down, to prevent accidental launch, while I take the slack out of the leader line. and ensure the jet is positioned for a straight launch.
7. I now move behind the launcher ( and chase the lookie-loo's behind me, if necessary)
8. I call the launch.
9. I start my timer.
10. I feed in a little up elevator (1/8th to 1/4 stick throw).
11. I simultaneously step on the release pedal and jam the throttle full forward.
On maidens, I generally only have to correct a little with ailerons during the launch. I trim as necessary and enjoy the rest of the flight.
Rob
NCC-1701 is offline Find More Posts by NCC-1701
Old Oct 23, 2006, 07:50 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
About the only comments I can make is make sure you are not standing on the antenna After stretching out the cord, give it some room to contract if either of the anchors lets go.
Bungee launches, for the most part, are safe and a sure way of getting your plane airborne. Just make sure the plane is balanced per the plans and you should have no problems. I use a ramp made of wood and the rails are covered with 3/4" pipe insullation. Using a fish scale I set the tension to 5 times the AUW of the plane. I launch with power off and apply power only after the hook drops away.
The launch hook is located between the CoG and the nose. Closer to the CoG results in a high, low velocity launch. Locate the hook farther forward results in a lower, flatter launch trajectory with more velocity. This is my preference.
The elapsed time between pedal release and cord fall-away is about 1.25 seconds. So you have little time to react to a bad launch.
Good luck with the maiden.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Oct 23, 2006, 08:24 AM
Speed is Life is offline
Find More Posts by Speed is Life
Speed is Life's Avatar
FREE Gene!!! Get Banned!!!
Joined Jun 2005
[QUOTE]About the only comments I can make is make sure you are not standing on the antenna[QUOTE]
Larry,
I KNOW that you weren't there when I did that very thing with my F-104 late last winter
Makes them glitch pretty badly with only 2" of antenna.........
-Mike
Speed is Life is offline Find More Posts by Speed is Life
Old Oct 23, 2006, 11:18 AM
CTulanko is offline
Find More Posts by CTulanko
CTulanko's Avatar
Cincinnati, Ohio
Joined Mar 2004
Larry and others have made some very good suggestions and while it was subtly noted, there were one or two not mentioned. I have used several different types of launchers over the years...wood, shortened Zagi PVC with a ramp, pvc with padded rails, pvc with slick low friction rails, ground drag and the dolly system and they all work well, some better than others, but each one serves a purpose.
The Zagi was shortened to 4' for easier transport. The ramp launcher, made from a 1' x 4' white coated shelfboard worked well for flat bottom models like the HET-RC FA-18, where putting it on a rail launcher would have had the rails resting on the tailerons instead of the wings and causing excess stress to these control surfaces and servos.
The rail launchers worked better for models with bottom mounted wings, like the F-4D Skyray, Sniper, F-20 etc... and the wood launcher worked well with narrow or bottom humped fuselages like the F-4D Skyray or F-16. Ramp launchers would not work as well here because they would lean to one side on the flat table. As you can see, each one works best for a specific aircraft, so I would suggest you figure what you want to fly now and in the future and go from there. If you have the time, build and try them all as that is half the fun!
Lately I am using the Dolly system that agustapower Bob referenced and it is pretty much all I use now. There is less equipment to haul around as that got real old after a while, it is easy to set up, it works with any model (it got to be a pain switching the ramp to a rail to a ramp again every time), it buffers the ride with wheels, it has a better release system and it's more like a landing gear takeoff. It is also very low profile and less distracting to other fliers on the field. The only disadvantage is the possibility of the release cord tangling with the rear of the aircraft, but if you adjust the loop so it protrudes just past the rear of the aircraft, it will eliminate this issue. I forgot to mention, it is cheap to build as you probably already have some of the hardware in your hangar.
So for the most part, any of the methods mentioned will work well and you just have to decide which one you want to try first. No matter what you do though, just be sure to keep it fun!
Carl
CTulanko is offline Find More Posts by CTulanko
Old Oct 23, 2006, 06:37 PM
Joined Sep 2000
Mike,
I think you are the first bungee launcher ever to admit to stepping on the antenna...but I suspect you are not alone in this...
Old Oct 23, 2006, 07:15 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
hi demetrius;
in the second part of the video, did your father's panther
take of from grass? very impressive performance.
Do you happen to know
the thrust/ weight ratio of that panther?
something like 250 watt/lb???
thanks.
rcguy01 is offline Find More Posts by rcguy01
Bungee launching bmwbob Foamies (Kits) 15 Oct 04, 2002 09:01 AM
has anyone tried bungee launching with a winch avie Electric Plane Talk 5 Jan 15, 2002 08:42 PM
Bungee launching kscheck Electric Ducted Fan Jet Talk 16 Sep 22, 2001 06:55 PM
Bungee Launching a TwinJet James Frolik Foamies (Kits) 1 Aug 08, 2001 12:40 AM
bungee launching troubles max z Electric Ducted Fan Jet Talk 34 May 27, 2001 07:31 AM
