Old Oct 12, 2006, 06:11 AM
Flash
Flash
Guest
n/a Posts
Which is the best RC Flight Simulator
I am looking at purchasing an RC Flight Sim (figure it's cheaper option to
get the basics down).
In everyone's expert opinion, which is the best RC Flight Sim and why?
If I am going to part with some hard earned coin, want to be informed.
Troy
Troy
Guest
n/a Posts
Re: Which is the best RC Flight Simulator
Ive tried a few of them and Aerofly Pro + RealFlight G3 are my favourites.
Although, getting the basics down can be done with the free FMS sim and
a cable purchased from Ebay for $20 AU.
I used FMS for a while to get my head around which stick does what so I
never forget while flying the real thing. To do anything else remotely like
the
real thing (such as aerobatic manouvers) will require purchasing one of
programs mentioned
above.... FMS is only good for learning the sticks in my opinion.
Others will have there own opinions....
Regards,
Troy.
"Flash" <flashgdn@tpg.com.au> wrote in message
news:452e10cd$1@dnews.tpgi.com.au...
> Thanks
Flash
Flash
Guest
n/a Posts
Thanks for the info Troy,
I'll have to invest in the adaptor I think. Looks pretty good to get the
basics.
Regards,
David
"Troy" <acr45@bind.net> wrote in message
news:GNoXg.45995$rP1.31453@news-server.bigpond.net.au...
the
programs mentioned
Regards,
Troy.
> Thanks
Old Oct 12, 2006, 08:11 AM
funfly3
funfly3
Guest
n/a Posts
> basics.
> Regards,
> David
> the
> programs mentioned
> Regards,
> Troy.
>> Thanks
just remember to adjust the wind settings to make it a little harder
than the default zero wind zero gusts which is to easy
Kevin
Old Oct 12, 2006, 12:11 PM
Doug McLaren
Doug McLaren
Guest
n/a Posts
In article <GNoXg.45995$rP1.31453@news-server.bigpond.net.au>,
| favourites.
Me too. RFG2 is just fine too, though of course the graphics aren't
as good, things aren't as customizable and things don't explode nearly
as satisfyingly when you crash. So if you can find RFG2 cheap, don't
dismiss it out of hand.
I've not tried Reflex XTR, but it looks great too. And The FS One
that's due to come out soon is probably fine too.
| and a cable purchased from Ebay for $20 AU. I used FMS for a while
| to get my head around which stick does what so I never forget while
| flying the real thing. To do anything else remotely like the real
| programs mentioned above.... FMS is only good for learning the
Again, I concur.
To be more precise, FMS will simulate the best behaved helicopter (or
plane) ever -- perfectly stable, with the most magical gyro
imaginable, etc. Real helicopters don't fly nearly that well, and
much of the learning curve involves learning how to deal with little
things that your heli does that you didn't tell it to do.
RFG3 and Aerofly Pro will simulate a perfectly trimmed helicopter as
well, and they seem to give you an awesome HH gyro by default, so you
end up with a helicopter that's easier to fly than the real thing
unless you get something really good -- but even so, it's a lot more
realistic than FMS.
Don't get me wrong -- FMS is great, and in some areas it even competes
with the modern commercial offerings, but flight realism is not one of
those areas.
For learning, it's helpful to customize the helicopter you're flying
to turn the heading hold gyro into a rate gyro. You really need to
learn to keep control of that tail, and letting a HH gyro do that for
you while you're learning just means you won't be able to fly without
one. It's sort of like learning to drive on an automatic -- perhaps
it's easier, but if you never learn to drive a stick, you'll never be
able to. But it's worse, because only two sorts of helicopters have
heading hold gyros -- 1) expensive ones (i.e. not the low end, or even
the middle-end), and 2) ones you find on simulators.
Doug McLaren, dougmc@frenzied.us
An intelligent man is sometimes forced to be drunk to spend time with his
fools. --Ernest Hemingway
Old Oct 12, 2006, 02:11 PM
Gavin
Gavin
Guest
n/a Posts
On Thu, 12 Oct 2006 19:53:17 +1000, "Flash" <flashgdn@tpg.com.au>
>Thanks
People are different. Whats my best might not be anyone elses best,
and bear in ming the PC you are running it on will affect your choice.
G3 on mine ran but I had to turn most of the details options down to
make it run at a reasonably true to life speed.
I had Reflex XTR, and Aerofly Pro Deluxe, and borrowed someones
Realflight G2 and G3
My views were..
I started wtih FMS like most people try, but soon moved on, it's good
for the basics but doesn't offer much fine control.
Reflex is good, but a IMHO bit more fiddly than anything else I tried.
Realflight (and please excuse this comment)I got annoyed by the inane
american voice making comments can jokes, I know I can turn them off
but it was just another thing that made me feel this was more of a
game than a simulator. It works as a sim but feels more gamey to me.
Aerofly was what I got and use now, This is my preferred choice
One of the reason I like Aerofly is it has my plane in it (Hype 3d),
so it behaves in the sim as the field (or as well as possible,) none
of them seem to handle wind well it tens to be varying on a angle
whereas out at the field gusts can be in different directions at
different hights.
Something to bear in mind is Realflight g2 (not sure about G3) you
cannot add in planes other than buying addons (and they were pretty
much the Great PLanes range) Reflex and Aerofly you can download
other peoples planes and sceneries without restriction.
Old Oct 12, 2006, 10:11 PM
rich
rich
Guest
n/a Posts
> Thanks
For what it's worth, I used Realflight G2, and still do for a brushup
of the finger skills. I think any sim where you can crank in some wind
and turb is good. I learned on the G2, and when I solo'd, I found the
real plane with real wind was much easier than the poor trainer and
high winds in the sim.
You can change the planes in G2 to fit (somewhat) your own plane. I
downloaded an Avistar 40 to mine, and it flew "close" to the actual
plane. The graphics are not the greatest, and the perspective sucks,
but I see it as a trainer, not a cool video game. I use it as a tool,
I don't play games on it. ..... Well, sometimes after some serious
training time. Then I use the P-51 to strafe the countryside! Many
crashes, much destruction!
Hope this helps.....
Old Oct 13, 2006, 06:11 AM
The Natural Philosopher
Guest
n/a Posts
>> Thanks
I have similar experience with G2.
You an modify the planes they give you in terms of size trim and
wingloading and power units..and even generate new color schemes for them.
I've got a speed 400 'ultimate' in WWI camouflage adjusted to fly like a
balsa sopwith camel.
The only thing you can't change is the visible outline. I tried making
the twin thing into a mosquito, but it was never very convincing.
Old Oct 13, 2006, 10:11 PM
Hugh Prescott
Hugh Prescott
Guest
n/a Posts
FS One arrived Tuesday at our shop. The no controller version. S 179.99
stree price
Used a P-4 3.2 Ghz 2 Gb RAM Asus motherboard with a PCI 16X NVIDIA 6600
GeForce video card running XP Pro Corp.
The install takes up to an hour to load the 4 CD's and 4 Gb of HD
space. Min equipment is a 1.8 Ghz 512 RAM NVIDIA GeForce 5200 with 2.8
Ghz P-4 and 1GB of RAM with NVIDIA 6600 GeForce or better recommended.
It installed cleanly the first time.
I used a JRP XP7202 TX as the controller. First attempt to calibrate
the TX resulted in total chaos of the calibration and no control over
the plane.
Three hours of calls to tech support and fumbling on my own finally got
it working. The transmitter setup is probably the worst example of human
interface programing I have seen. Horizon support did not seem to really
have any experience rather he got a transmitter and we both walked the
problem until we got it working.
Am told that the version with the dummey transmitter is the default
setup and works out of the box according to Horizon.
One complaint, they used a straight out plug on the cable to the
transmitter so with most transmitters having their slave cables on the
back the cable is folded over when you lay the TX down.
If you have a programable radio best to copy a model and then change th
copy to PPM modulation and no servo reversing etc.
Once working its a decent flight sim, Almost all the planes are related
to planes and helo's they sell. Have not had any time to play after I
got it running.
The only transmitter listed by model is the JR 9303 the rest are all
generic more or less.
Set it up on a Compaq 2.5 Ghz laptop with ATI rage video. Some pauses
but OK for a demo in shop use.
Appears to be lots of customizing you can do.
Hugh
Old Oct 14, 2006, 06:11 PM
Flash
Flash
Guest
n/a Posts
Thank you all for taking the time to contribute to my request.
I have not made a decision as yet. It's a toss up between G3 and Aerofly
Pro. Having a look at the respective web sites there appears to be more
support for Aerofly from Ikarus and more from the greater community, so I am
leaning this way at the moment.
Regards,
David
Old Oct 15, 2006, 12:11 AM
quietguy
quietguy
Guest
n/a Posts
I suppose you know you can download a free trial version of G3 - not sure if
there is one for aerofly pro
David
> Regards,
> David
Old Oct 15, 2006, 06:11 AM
Flash
Flash
Guest
n/a Posts
Yup, thanks for this. I have just spent the good part of four hours taking
it in turns with my father to destroy the test aircraft. It's good as a
guide, but without the sticks, it's really just a game, but a good one.
"quietguy" <quietguy@REMOVE-TO-REPLYconfidential-counselling.com> wrote in
message
news:4531B17C.D4990B07@REMOVE-TO-REPLYconfidential-counselling.com...
David
am
> Regards,
> David
Old Oct 16, 2006, 02:11 AM
Ken Day
Ken Day
Guest
n/a Posts
>Thanks
After owning a number of flight sims going back as far as the Dave
Brown sim for a Commodore 64 ( whew.....telling my age here)
and as new as the Real FLight G2 and G3 , my vote goes for the
Reflex XTR.
I like many things about Real Flight and it would be my second choice.
I especially like the web site where you can download many different
aircraft , color schemes and flying fields. Also many different add
on's which aren't terribly expensive.
There are some free ones available for Reflex but not as many as
RealFlight, or , I just haven't found them yet.
Getting too early in the morning for me to go into detail about all
the features I like and dislike Hard to keep my eyes open. Maybe do
that tomorrow.
Ken
Old Oct 16, 2006, 08:11 PM
news.zen.co.uk
news.zen.co.uk
Guest
n/a Posts
"Ken Day" <kd1942@aol.com> wrote in message
news:eu86j29qcgu7q3hk40tg53406tec6br2m6@4ax.com...
>>Thanks
> Reflex XTR.
> that tomorrow.
> Ken
Hi all my first post :-)
I have just got myself phoenix sim and find it better that G2 or G3
and for a beginer it has training modes for planes and helis
http://www.phoenix-sim.com/
Review
http://www.trextuning.com/phoenix.php
If you can`t be botherd to read the review then this was the
outcome........................
Phoenix have clearly taken stock of what simulators are available on the
market and analysed their strengths and weaknesses. In this regard Phoenix
has improved on the other simulators in various different areas. When
reviewing a simulator the easy thing to do is just to look at the flight
model. If you take this approach with Phoenix then you can see that Phoenix
have probably got the best flight model available. The difference between it
and the next best simulator (if you are just comparing flight models) is not
huge. However, just taking this approach does not do justice to the other
improvements that Phoenix brings.
Phoenix to me represents the best simulator on the market. This is not just
down to the flight model, if it were then owners of simulators like Reflex
XTR would not have a compelling reason to buy Phoenix. When you consider the
whole package, the excellent user interface, the ability to simulate
helicopters and fixed wing extremely well, the training and competition
modes, multiplayer features, model editing interface, in-flight model
parameter changing, then you start to see why the simulator is a cut above
the rest. Lastly Phoenix is two thirds of the price of its closest rival. If
the features and flight model was not a compelling reason for placing
Phoenix on your shopping list then the price tag should be.
Phoenix comes highly recommended by TrexTuning and my old faithful copy of
Reflex XTR has been marked for an appearance on eBay.
Ripmax RC Flight Simulator. mc-lite Simulators 0 Jul 16, 2003 07:55 PM
