Espritmodel.com Heli Air
Old Oct 12, 2006, 12:14 AM
Joined Oct 2006
Does a 3 channel micro RTF exist?
I recently got hooked on flying with an Aero Ace I bought on a whim. However, I see it's limitations. I need an elevator.
Ideally, my dream plane right now would be an Aero Ace with an elevator and rudder. Does something like this exist? Would it be possible to mod an existing micro RTF off the shelf to three channels?
wanderingjew is offline Find More Posts by wanderingjew
Old Oct 12, 2006, 01:43 AM
certified n00b
San Diego, CA
Joined Jul 2006
Are you limiting the modding to using the existing gear that's in the plane? If not, I don't see any reason why you couldn't use a micro rx, a few actuators, and a different tx and just make the AA a 3channel craft. If you check through the forums, a few people have already done it.
If you want to use the existing hardware in a plane, the closest I've seen was the throttle/rudder AA here: http://www.falcon1.net/~ars/rcmodels.html
Considering it's only a few dollars worth of parts, it's probably the best you have, for the money. As long as you stay in range, you should be able to turn your way out of most bad things that would happen.
-Jef
nocjef is offline Find More Posts by nocjef
Old Oct 12, 2006, 02:20 AM
Joined Sep 2006
i think these are ARTF, check em out anyway:
http://www.plantraco.com/hobbies/pro...icroscout.html
http://www.plantraco.com/hobbies/pro...ro_racers.html
you can also buy parts there to make your own 3ch stuff
13BT is offline Find More Posts by 13BT
Old Oct 12, 2006, 09:29 AM
Joined Apr 2006
If you are flying the AA biplane, give the AA Jet a try. It does not have an elevator, but it is more dynamic than the biplane and you can get it to do some cool dives, zooms, something like a hammerhead, and a high-speed low pass. The Plantraco gear is cool if you are willing to invest some real money in it.
Barry2 is offline Find More Posts by Barry2
Old Oct 12, 2006, 11:33 AM
bEbOp ¿?'s Avatar
Mile High City
Joined Dec 2004
Cox warbirds.. http://www.rcgroups.com/forums/showt...t=438256&pp=15
Stay away from the Corsair from what I've read. There is a frame ver. aswell as an ARF ver. ( simple build )
bEbOp ¿? is offline Find More Posts by bEbOp ¿?
Old Oct 12, 2006, 11:48 AM
Texas, Plano, USA
Joined Jan 2005
You can do it with several RTF receivers (Micro Invent, minor, plantraco, etc..) but you will need a computer radio to mix differential thrust, unless you wire it for traditional 1 motor, elevator, rudder type.
anestho is offline Find More Posts by anestho
Old Oct 12, 2006, 12:09 PM
RNAF's Avatar
The Netherlands
Joined Dec 2003
Joe on the Indoor and Micro Models section makes custom made micro RTF's. His latest example was a sweet Zero that weighs less than 4 grams. I suggest you check the last few pages of that forum.
RNAF is offline Find More Posts by RNAF
Old Oct 12, 2006, 06:35 PM
shawn595's Avatar
United States, VA, Bedford
Joined Sep 2006
Those cox planes would be pretty tough to fly for someone that's never flown more than an AA. I've heard they're great for experienced pilots though.
shawn595 is offline Find More Posts by shawn595
Old Oct 12, 2006, 10:47 PM
Joined Oct 2006
Well, that's kinda what I'm looking for; something that flys like a real plane. Looks like it may be worth the investment.
Discussion 3-Channel RTF micro coming....:) SmoothCruizer Micro RTF 1 Feb 09, 2007 04:17 AM
Sold Futaba R133 FM 3-channel Micro Receiver Dynomike Cars - Cars and Parts (FS/W) 0 Dec 26, 2006 08:55 AM
Wanted Futaba PCM 3 channel micro Rx 75MHz Speedo125 Aircraft - General - Radio Equipment (FS/W) 0 Feb 09, 2006 05:47 PM
Budget 3 Channel Micro Bipe... ndflicks Indoor and Micro Models 4 Jan 31, 2004 09:14 PM
New RTF 3 channel jandirks Parkflyers 3 Apr 18, 2003 09:03 AM
