Old Jan 30, 2012, 05:44 PM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Mike The Snake posted this in another thread & figured it's such useful advice it ought to live here too.
(I know he posted something similar long ago, but it's almost lost in this huge thread)
"One of the things I did when I was building Opuses for people was wicking thin CA all along all the hinges, then cracking them loose.
I found that the Opus MC3/V wing skins delammed very easily, and after just a short time of flying, even without any hard landings, that the delams formed.
Wicking the thin CA into the hinges effectively solved this issue. I did it to every plane I built.
The hinge material, sandwiched into the skins, forms a weak area, right where it needs to be even stronger. The thin CA wicks into this area through capilary action and makes it rock solid."
dsman is offline Find More Posts by dsman
Old Jan 30, 2012, 06:38 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
On my double glass Opus at least, The cores are not tapered down to the hinge line so the two sandwich halves are not joined. I can definiely see how this could be a delam point. Good tip!
josh18 is offline Find More Posts by josh18
Old Jan 21, 2013, 08:15 PM
LVSloper is offline
Find More Posts by LVSloper
LVSloper's Avatar
Las Vegas
Joined Mar 2009
opus build reference.
LVSloper is offline Find More Posts by LVSloper
Old Jan 22, 2013, 12:32 PM
Jason Lilly is offline
Find More Posts by Jason Lilly
Go Faster!!
Jason Lilly's Avatar
San Diego, CA
Joined Apr 2004
Opus fuses for sale Check it out!
http://www.rcgroups.com/forums/showthread.php?t=1814311
Jason Lilly is offline Find More Posts by Jason Lilly
Old Jan 27, 2013, 10:24 PM
LVSloper is offline
LVSloper's Avatar
Las Vegas
Joined Mar 2009
Opus MCT
just finished up my opus MCT, all up weight is 108 ounces. Looking forward to the spring winds at Weldon and Norco, can't wait to put her to the test. I left room for an additional 30 oz. Of ballast for the 45mph winds at Weldon. This one has an all black bottom wing; anyone seen one like this before?
Best,
Old Jan 28, 2013, 12:58 PM
Big Gas is offline
Find More Posts by Big Gas
Semper Fidelis
Big Gas's Avatar
United States, CA, Redlands
Joined Jul 2005
Looks good Mike. I met you a few weeks ago at Norco. Just acquired a new to me MCT. It's about 85oz. Empty. Got a maiden on it yesterday at Little Mountain. Note the 2.4 install. Quad ant. We had the logger on it yesterday. Zero holds and some normal fades from the front antennas. Install is solid. Thanks James.
Description:
John
Big Gas is offline Find More Posts by Big Gas
Old Jan 28, 2013, 01:20 PM
LVSloper is offline
LVSloper's Avatar
Las Vegas
Joined Mar 2009
John, maybe we will get some good winds soon for Norco and we can have a Opus fest. Nice flying with you too.
Old Jan 28, 2013, 04:38 PM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Attachment 5488539
John
John. Are u using jr/spektrum? Can u post some Pictues of the radio install?
Are u running a legerton tray?
My mct is the last plane I have on 72. I've got some carbon fuse jr receivers with remotes that I plan on installing.
rockbus is offline Find More Posts by rockbus
Old Jan 29, 2013, 03:38 PM
Redfarren is offline
Find More Posts by Redfarren
foam is fun, but glass is fast
Redfarren's Avatar
United States, CA, Goleta
Joined Apr 2010
Hi rockbus, I did the install of ant exits, John did the tidying up of the loose wires and such. The logger was a huge relief to know the install is good, highest fade count was just over a hundred on one of the fronts, rears were less then 40. We flew little mountain and has a radio tower to the right and it kills the guys on airtronics big time, I have seen spectrum planes take hit on park flier Rx's as well.
Redfarren is offline Find More Posts by Redfarren
Old Jan 29, 2013, 03:49 PM
Redfarren's Avatar
Joined Apr 2010
Another pic. I used a pin vice (handheld drill thingy) to make the holes and a tiny hacksaw blade to make the slot. I didn't open the fuse enough to fit the whole fin on ant exit piece, cut it short on back end. Used an extension on a thin ca to make sure everything is solid from inside fuse at the exit holes I made. Going to do an install on the mct I picked last weekend tonight, thank you Tony!
Old Jan 29, 2013, 06:53 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Redfarren,
Thanks for the pics. It looks like you're using JR/Spektrum equipement. I'm going to do the same. I like like the logger, That way you know for sure how each receiver is working. Too bad they dont have a telemetry setup to tell you how the receiver is receiveing real time.
Ray
Old Feb 08, 2013, 11:03 AM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Redfarren,
i see that your antennas installation is in the right position, 90 degrees between each one...
but, I see your antennas going paralellal to the fuse when the plane is flying, duo to huge wind, the antennas will tend to be in the horizontal position which is not good since all antennas will be running in the same position.
I use some linkage plastic tubes on the antennas exits, so, it'll avoid flexing when flying...
I know that carbon will cause the shaodow, any other thing will do it? like the lead on the nose,.. or... electronics.. batteries???
John, very nice plane BTW - take it to Weldon in April and we can flight together, see yaaa..
Andre
decones is offline Find More Posts by decones
Build Log >> Successful PicooZ 3 Channel Mod(s)!!!<<(SORRY FOR DELAY) Corbin_Dallas Micro Ready-to-Fly 83 Apr 04, 2008 11:26 PM
Discussion E-Flite J-3 Cub Mod's Bcruiser Scale Kit/Scratch Built 0 Feb 03, 2007 01:53 PM
3 Airtronic's Radio's combi Aircraft - Electric - Airplanes (FS/W) 7 Mar 09, 2002 01:12 AM
Zagi Mod's SteveC Foamies (Kits) 1 Jan 28, 2002 12:11 PM
3-view's and cross sections Kerberos Electric Ducted Fan Jet Talk 8 Dec 05, 2001 01:37 AM
