Old Oct 11, 2006, 07:03 PM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
less amps with more lipos for a given RPM at partial throttle?
I was pondering the brushless motor equations, looking at the 'power required' to turn a prop at a given RPM. This was suggesting to me that for a higher voltage, less amps were needed.
However, for a given motor there's a certain Kv which dictates the speed it will turn with a given voltage potential.
So, I ask the question, how does 'partial throttle' work with ESC?
If I have a situation with a given motor and a 3S lipo and it requires 10amps to turn a given prop at 6421 rpm. and Now, if I replace the 3S lipo with a 4S lipo, but 'throttle' the beast so that I still get 6421 rpm. Will it still require 10 amps (plus or minus a minutia for the difference in resistance of the batteries)?
If that's the case, then does it suggest that increasing the number of lipos in series, and decreasing the throttle (to match original rpm) does not provide any advantages in terms of amp draw on the battery.
Conversely, does that suggest, if I drop to a 2S lipo, and can still make the required RPM from the voltage in the battery, that the same 10 amps (+-) will be all that is required?
Nethole is offline Find More Posts by Nethole
Old Oct 11, 2006, 07:16 PM
9LIVES1968 is offline
Find More Posts by 9LIVES1968
Titanium Has My Back!!
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
delete
9LIVES1968 is offline Find More Posts by 9LIVES1968
Old Oct 11, 2006, 07:18 PM
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
Also, if you drop to 2s to make the same rpm, you are going to really have to reduce the prop size to turn the same rpms and you wont be pulling anywhere near the 10 amps. Probably around 4-5 amps
Old Oct 11, 2006, 07:26 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
No, you didn't answer the question I posed. I'm not talking about full throttle. I'm specifically talking about partial throttle WITH the same prop AND at the same RPM. Please address this question, do not create your own question. I worded it this way for a reason.
Old Oct 11, 2006, 07:30 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Yes, it will generally draw less amps to turn the same speed for a given controller. How much less depends greatly on the partial throttle efficiency of the controller. Partial throttle efficiency is governed by a whole host of things, and most ESC manufacturers don't consider it a major design consideration (its expensive to do well, and increases the weight of the controller without increasing the current rating of the controller)
Comatose is offline Find More Posts by Comatose
Old Oct 11, 2006, 07:36 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Simple answer no.
Volts times amps . equals watts. Watts is the unit or power. Watts are what turns props. It takes X number of watts to turn any give prop. at a given RPM.
Real life data.
IKARUS 2023011 motor. GWS DD 9050 prop at 5000r RPM.
2S 6.9 volt , 3.7 amps. 27 watts
3S 10.8 volts ,2.8 amps. 30 watts
Note these are number obtained two years ago with LiPolys that dropped volts a lot more than the ones of today. Also note that reading vary a little and these are averages.
And yes the ESC and battery needs to be able to handle the max. amps at WOT even if using at reduced throttle according to the ESC experts. I have never fully agreed with them but it is not worth the aggravation to argue the point.e
Old Oct 11, 2006, 07:38 PM
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
Doing like you outlined in you question is going to cause excess heat in your esc. Even though you are "throttling back" to your given rpm, the esc is switching harder to maintain the throttle setting. It is still seeing full voltage from the battery and the setting of the throttle. If you are using a 10 amp esc and do like you outlines, you are going to overheat your esc. There are plenty examples of this in the power system forum which is where this needs to go.
Old Oct 11, 2006, 07:52 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
Originally Posted by everydayflyer
Simple answer no.
Real life data.
Note these are number obtained two years ago with LiPolys that droped volts a lot more than the ones of today. Also note that reading vary a little and these are averages.
Charles
Ok, this is sounding more like a powersystem question now (I concur with the commonsense guy's comment). I have no objections if an admin moves this to powersystems instead.
Now, perhaps the previous individual answered the question of how (his answer was 'switching'), but I'm curious how 'less volts' are provided to the motor for 'less than full' throttle. Or is it the 'max voltage' for less time.
Meaning that for a given motor with a specified Kv, it's supposed to spin at a given rpm when that potential difference is applied. Does this suggest that the motor is in a more-or-less constant state of acceleration/deceleration from the 'full battery voltage' being applied and disconnected repeatedly? I know it's a three phase motor so there's more to it than that. But I'm still trying to grasp how the ESC funtions in 'throttling down' a particular battery/motor configuation.
Thanks, Charles, for providing reallife numbers. This points out that my understanding of the powersystem with 'partial throttle' settings is incomplete.
ham2405 is offline
Find More Posts by ham2405
KC5UH transmits -------->
ham2405's Avatar
Arlington, Texas
Joined Aug 2002
This means that you still do not understand how the esc controls motor speed .
David
ham2405 is offline Find More Posts by ham2405
Old Oct 11, 2006, 08:03 PM
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
Think of the esc as being a gatekeeper. Inside the are 10 gates, with each gate representing 1 amp of power being handled.Obviously I am describing a 10 amp esc. When full throttle is applied, all 10 gates are open. Now say that you only want 1/4 throttle. 3 or 4 gates stay open, and the remaining gates switch open and shut very fast to limit the current and amperage being delivered to the motor. All 10 gates are still seeing 1 amp each, but now each of the switching gates are working harder to open and shut to maintain the lower output. 3/4 throttle, 6-7 gates are fully opened and the remaining ones are switching rapidily to lower their share of the amp load in order to lower the overall voltage to the motor. That is why an esc will run cooler at full throttle versus partial since less heat is generated from staying "open versus switching" Now realize this is a very simplistic explanation as there are other factors, but this is the easiest to understand. I hope this helps. Dave
Old Oct 11, 2006, 08:13 PM
Southern Pride
David
I fully understand how ESC work. It is a switch which is either on or off. Sometimes on more sometime off more. Thing is that It is more complicated than the simple partial throttle explanations given by most.
The worst throttle position is at approx. 65-75 % throttle. At less than 60% or more than 80% it is not nearly s bad as most would lead you to believe.
I have owed Bob Boucher's Electric Motor Handbook since it was first published and I have read it many times and understand most of it.
I have flown electrics since a two minute flight reaching 100 foot elevation was a feat.
A snip from a post of Astro bob's
on iron motors my measurements indicates that maximum heat in the
speed control occurs at between 85 and 90 percent throttle.
so the 10 amps control gets the hottest if the motor is propped for
10 amps and run at 9 amps.
for basket motors like the hacker and chinese hacker clones the
lower inductance makes for more current ripple so max temp
may occur at 70 to 80 percent throttle.
in all cases 50% throttle will be cooler than 100 percent.
so even the type of motor makes a difference.
Charles
Old Oct 11, 2006, 08:16 PM
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
I was waiting for that reply with baited breath!lol. Dont mess with our resident battery guru! Dave
Old Oct 11, 2006, 08:21 PM
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
Nethole, if you have a 3s setup with a given prop and esc at partial throttle and take its amp reading and then change to a 4s with everything else being the same(esc, prop, motor), at the same partial throttle setting, you will have a higher amp draw usually. It doesnt matter if it is at full thottle or partial throttle, amp draw will be higher with the added cell if you dont change the prop size. Conversely, if you drop down a cell, then your amp draw will be the lower with everything being constant. What I had written earlier still applies whether wot or partial.
Old Oct 11, 2006, 08:33 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
You're going to suggest that with a 4S lipo to provide 6000 rpm will require more amps, than is required with a 3S lipo?
again, you're answering a different question than I asked, I didn't say for a 'same throttle' setting for each lipo case, I said for the SAME RPM for each lipo case.
From the FIRST SENTENCE IN THIS THREAD
Old Oct 11, 2006, 08:42 PM
Southern Pride
http://www.astroflight.com/store/sto...ZltntAgUw476E5
Read page five here
http://www.castlecreations.com/media...02-Nov2005.pdf
Sold More Lipos for sale SammyB Aircraft - Electric - Batteries & Chargers (FS/W) 12 Mar 17, 2006 03:27 PM
Need help with motor choice for my Herr AT-6 Texan nakman8 Glow to Electric Conversions 7 Dec 18, 2005 11:07 AM
Need help with motor choice for my Herr AT-6 Texan nakman8 Beginner Training Area (Aircraft-Electric) 3 Dec 06, 2005 07:26 PM
For Sale gws pizza with three lipos for gyro and servo 007 Aircraft - Electric - Helis (FS/W) 0 Nov 25, 2005 06:55 PM
What is the formula for calculating RPM at given Amps austinflyer Power Systems 2 Jan 24, 2004 04:13 AM
