Old Jun 30, 2001, 11:30 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Amp -Versus - Milliamp, How do I convert?
I'm considering buying a Duratrax Intellepeak charger. This charger has variable charge rated of 0.5 AMP to 5.0 AMP.
Whats the difference between Amps & Milliamps? if i'm charging 270 Mah Nicads for my Litestick which charge rate should I use? 0.5 Amps = ? Milliamps
mrebman is offline Find More Posts by mrebman
Old Jun 30, 2001, 11:42 PM
razzor7 is offline
Find More Posts by razzor7
Burnsville, MN, USA
Joined Oct 2000
1000 millamps = 1 amp
270 milliamps = .27 amp
Regards,
- Razz
razzor7 is offline Find More Posts by razzor7
Old Jun 30, 2001, 11:43 PM
procrastination inc is offline
Find More Posts by procrastination inc
Adelaide,Australia
Joined Apr 2001
metric system pretty straight forward
They all have standard prefixes for units to change their magnitude
The unit of current is Amperes, A. often shortened to amps
M=mega=X1000
k=kilo=x100
d=deci=x10
m=milli=/10
"mu"symbol=micro=/1000
p=pico=/1,000,000
n=nano=/1,000,000,000
convert from A -> mA= x1000
0.5A = 500mA
Don't you charge those batts at about 50 mA?
You'll need some else to answer that.
[This message has been edited by procrastination inc (edited 06-30-2001).]
procrastination inc is offline Find More Posts by procrastination inc
Old Jun 30, 2001, 11:55 PM
Adelaide,Australia
Joined Apr 2001
razzor, the batts are 270mAh. Amp Hours are a measure of stored energy, the number of anps that 1.2v cell can deliver for 1 hour.
That's a lot more info than just current, A. The way that figure is generated, I'm not sure of. I think it's able to deliver 27mA continuously for 10 hrs, but I might have that wrong.
Old Jul 01, 2001, 12:48 AM
mrebman is offline
Joined Nov 2000
Will that 0.5 Amp charge rate be too high for my 110 Mah & 270 Mah Litestick Batteries?
Old Jul 01, 2001, 03:01 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Yes. You'll kill 110 especially at that rate. If you want to charge such small batteries look for a charger that goes down to 0.1A (100mA).
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jul 01, 2001, 04:25 AM
WilliamSettle is offline
Find More Posts by WilliamSettle
Triad of Fun
WilliamSettle's Avatar
Little Rock, AR Triad: Windy, ECO 8 and E3D
Joined Nov 2000
procrastination,
I believe the correct units are:
milli (m) = 1/1,000 = .001
micro (u) = 1/1,000,000 = .000,001
nano (n) = 1/1,000,000,000 = .000,000,001
pico (p) = 1/1,000,000,000,000 = .000,000,000,001
WilliamSettle is offline Find More Posts by WilliamSettle
Old Jul 01, 2001, 04:28 AM
Adelaide,Australia
Joined Apr 2001
I stand corrected.
What was I thinking?
Got it right in the calc. though
From now on, I'll post script with.
P.S. I could be COMPLETELY wrong!
Old Jul 01, 2001, 04:40 AM
cwatters is offline
Find More Posts by cwatters
Somewhere in England
Joined Apr 2001
..snip.. Whats the difference between Amps & Milliamps? if i'm charging 270 Mah Nicads for my Litestick which charge rate should I use? 0.5 Amps = ? Milliamps
A 270mAH hour cell can in theory deliver:
270mAH for 1 hour
27mAH for 10 hours
2.7mAH for 100 hours
27A for 1/10 hour (=6mins)
270A for 1/100 hour (=0.6mins = 36 sec)
in theory, but in practice cells are not efficient at high curents and other things impose lower limits (like the thickness of metal in the cells internal construction/wiring.
The amount of current a cell can deliver for 1 hour is known as the C rating.
The standard charge current for most cells is usually 1/10th C which in your case is 27mA or 0.027A it's the same thing. It theory it should take 10 hours to charge your cell at 1/10th C but because the charge process is also inefficient it normally takes about 14 hours.
Fast charging is usually defined as anything over about 1C or 2C eg 270mA (=0.27A) or 540mA (=0.54A) in your case.
If your cells are designed for fast charging then you should be ok at 0.5A and possibly more.
At 2C your cells should take about 1/2 hour to charge. At 3C its 1/3rd hour = 20mins etc
[This message has been edited by cwatters (edited 07-01-2001).]
cwatters is offline Find More Posts by cwatters
Old Jul 01, 2001, 02:25 PM
MrBungle is offline
Find More Posts by MrBungle
rebmeM roineS
MrBungle's Avatar
Rockingham, Perth - Western Australia
Joined Apr 2001
procrastination inc ya got deci right the others though:
M=mega=X1000
k=kilo=x100
d=deci=x10
should be:
Mega=1x1,000,000
Kilo=1x1,000
Deci=1x10
each step is a division or multiplication of one thousand(with the exception of deci...a non SI unit)
As for mAh capacity, im not sure how Sanyo work their ratings but lead acid batteries made by Yuasa etc. are worked over a 20 hour period, then the Ah rating worked from that, for example a 7Ah lead-acid will deliver 350mAh for 20hours(.35x20=7) but draw 7A and the battery wont last an hour(about 30mins)
Maybe Sanyo do measure them over an hour, not sure.
[This message has been edited by MrBungle (edited 07-01-2001).]
MrBungle is offline Find More Posts by MrBungle
Old Jul 01, 2001, 03:06 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi,
sorry folks, still not correct. So here is some help from good ol' Europe
Tera : 10^12 = 1,000,000,000,000
Giga : 10^9 = 1,000,000,000
Mega : 10^6 = 1,000,000
Kilo : 10^3 = 1,000
Hekto: 10^2 = 100
Deka : 10^1 = 10
deci : 1/(10^1) = 0.1
centi : 1/(10^2) = 0.01
milli : 1/(10^3) = 0.001
micro : 1/(10^6) = 0.000,001
nano : 1/(10^9) = 0.000,000,001
pico : 1/(10^12) = 0.000,000,000,001
Yes, the ISO system is straightforward. And yes, I love it. I think I will never really understand why some countries are stuck to lb/sqr.in, gallons, feet, inch, yards, HP and so on if you can have meters, Newtons, kg's, Watt's and all this nice stuff where you can use every physical law as it is. Just put in your data and it works. It is so easy.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Jul 01, 2001, 05:08 PM
gdb1973 is offline
Find More Posts by gdb1973
Senior Member
Oxford(ish), England
Joined Feb 2001
Well, be carefull. A LOT of people have managed to confuse;
AMPERE for AMP-HOUR (Amp Hour!)
AMPERE is Olde Englishe for "Amp" (which is it's short-form) ie a measurement of power. AMP-HOUR is one amp for an hour, Ie a measurement of energy. 1 Amphour is.. one amp for one hour or six amps for ten minutes! or Sixty amps for 1 minute. Easy, but they sound similar! 2000Mah is just two thousand milli amps (thousanths of an amp) for an hour... Or 2 amps for an hour. OR 120 amps for a minute! etc etc etc.
gdb1973 is offline Find More Posts by gdb1973
Old Jul 01, 2001, 05:39 PM
jberg is offline
jberg's Avatar
Joined Feb 2001
Hi,
Originally posted by gdb1973:
[B]Well, be carefull. A LOT of people have managed to confuse;
yes, you should watch for that.
my dictionary says:
Ampere, Andre Marie, born 1775, died 1836, FRENCH mathematician and physician, discovered magnetic fields around electric current ...
Regards, Jochen
Old Jul 02, 2001, 04:03 AM
Adelaide,Australia
Joined Apr 2001
I must have been REALLY tired that night, I use thes conversions EVERYDAY! Better go check what I did at work that day.
Old Jul 02, 2001, 08:56 AM
berniep1 is offline
Find More Posts by berniep1
Vacaville, CA USA
Joined Nov 2000
I need those cells...a dream come true!!!
berniep1 is offline Find More Posts by berniep1
Question !Help¡ How do i convert scanned files to Autocad format? sshelge The Builders Workshop 12 Jan 25, 2016 02:51 PM
Question How Do I Convert A Small Servo Into An Actuator??? cubaniton DIY Electronics 2 Oct 18, 2004 05:35 PM
Question How Do I Convert A Small Servo Into An Actuator??? cubaniton Scratchbuilt Indoor and Micro Models 13 Oct 18, 2004 11:10 AM
How do i convert a DEAN to JST on lipoly pack? tekforce Micro Helis 12 Feb 17, 2004 03:45 PM
How do I convert my A-10 to a pusher? Jeremy_D Parkflyers 7 Nov 18, 2003 08:29 PM
