Old Aug 24, 2002, 01:42 AM
Heli Slime is offline
Find More Posts by Heli Slime
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
Here is the component weights for my Venus out of the box
Someone asked, well here it is. The weight for every part out of the Venus box:
Fuse and belly pan - 13.4/381
left wing - 5.7/163
right wing - 5.6/160
stab and elevators together - 2.5/71
fin and rudder - 1.0/29
ailerons(each) - .5/16
canopy - 1.4/40
hinge material - .1/3
dihedral brace - .2/8
hardware bag - .5/14
wingbolt plate - .2/7
wing dowels - .0/1
tail wheel conponents - .4/11
servo tray .4/11
fiberglass cowl - 2.0/58
wheel pants - 1.5/42
foam wheels - .8/24
landing gear - 1.8/51
spinner - .7/22
control rods - 2.9/85
Grand total is 42.1 oz/1213g
There it is.... I've heard of building inconsistancys(sp?) of up to 8 oz. ,so if there is anyone else who wants to weigh all their components then let me know
Heli Slime is offline Find More Posts by Heli Slime
Old Aug 24, 2002, 02:22 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Well,
Than you add:
Hacker B50 13S+6.7:1 GB = 255 gm
Aero-Model Mount = 85 gm
Hacker 70-3P Controller = 52 gm
Futaba R127DF receiver = 40 gm
(4) Futaba S3102 servos =100 gm
Graupner prop adapter
and spinner = 25 gm
APC 15x10 "E" prop = 38 gm
16 Panasonic HV 3000's = 960 gm
UBEC = 20 gm
1575 gm
3.47 lbs or 55.5 oz
Add the airframe weight supplied by Black96Z above and you have 97.6 oz total. By the time you add glue and a battery retaining system 102-105 oz AUW seems about right.
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Aug 24, 2002, 08:56 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
spinner is included in the first weight.... plus I think you could shave an ounce off that motor weight. I don;t think that at 100 ox you would tell a diffrance between a few oz. though.
David
Old Aug 24, 2002, 09:12 PM
Ed Lyerly's Avatar
Joined Apr 2001
Sorry I missed the spinner @ 22 grams....so that's another .7 oz off.
You won't shave an ounce off the B50 13S+6.7:1 GB.....cause that's what it weighs. You might use another motor and save an ounce , but I doubt it would perform as well. You could definitely shave an ounce or two off the motor mount by using an Aero-Vee or fabricating something lighter.
So, 100 oz is doeable, but I agree ....don't think you could tell the difference +/- 3 oz. This is a GREAT flying airplane with this setup !
Ed
Old Aug 24, 2002, 09:22 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
I just got my b50 today and i am going to try a Velkon mount. It looks like this.
Old Aug 24, 2002, 09:23 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
on the motor it looks like this:
Old Aug 24, 2002, 09:24 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
there are pins to suport the back of the mount, and its zipties and sticky tape to hold the motor in.
here is the weight of the mount
Old Aug 24, 2002, 09:25 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
try this
Old Aug 24, 2002, 09:27 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
and the motor
Old Aug 24, 2002, 09:33 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
all my electronics weigh 224g including Ubec, reciever, servos, extensions, and speed control
Old Aug 24, 2002, 09:41 PM
Ed Lyerly's Avatar
Joined Apr 2001
The Aero-Vee mount weighs practically the same as your Velkom mount (saves about 2 oz) but has the same problem.
I've been warned that these geared Hacker motors need to be mounted by the gearbox instead of leaving the gearbox unsupported. I am told that in the case of a hard prop strike or poor landing the gearbox can act as a lever and pull the pressed in endbell right out of the motor
As a result of those warnings (which seem reasonable to me) I'll be mounting mine by the gearbox in the future.
Ed
Old Aug 24, 2002, 09:46 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
Hmmm, thanks for the advise. I think that I will make a mount monday at work then.
I'll try to keep it under 3 oz or so.
Old Aug 24, 2002, 10:20 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Venus Conversion
Well thats good to know that the Venus is that light. I wish my Extra was that light, but you know I never really took all the parts out of the box and weighed them!? I wonder if I could make it come in at less than 8 pounds? The Venus is cool but I just like Extras have ever since I saw a full scale one close up.
Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Aug 26, 2002, 11:19 PM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
I have used the mount that you have in your pics and can tell you it definately would not work on that much power.
It flexes quite a bit....I would not use it on anything over 400 watts.
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Aug 26, 2002, 11:38 PM
SheldonYoung is offline
Find More Posts by SheldonYoung
SheldonYoung's Avatar
Vernon, BC, Canada
Joined Jan 2001
Here are my weights in grams using the same model Sunbeam scale. Most of the weights are very close. Mine list is 100 g heavier, but it includes some items I won't use (throttle pushrod, etc). It's nice to see the consistency.
Mine will be powered by a Mega 30/3, MEC 3:1 Superbox with a Castle Creations Pheonix 35 ESC with an Ultimate BEC providing receiver power.
Belly pan 24
Fuselage 347
Rudder 21
Fin 12
Left elevator 12
Right elevator 10
Stabilizer 45
Left aileron 22
Right aileron 15
Left wing 161
Right wing 167
Fuel tank 57
Wheels 22
Landing gear 47
Bag of plastic 14
Bag of misc 61
Bag of metal 59
Wheel pants 38
Cowl 56
Rods and tubes 85
Canopy 39
Total: 1314 grams
SheldonYoung is offline Find More Posts by SheldonYoung
Discussion Just got my cx2 out of the box :) googlymoogly Coaxial Helicopters 27 May 10, 2007 08:01 PM
Rave New Canopy For My Tripped Out Corona mikefaith Electric Heli Talk 22 Sep 11, 2005 05:27 AM
My PolyQuest PCM break-out box for cell measuring and charging. LexTalionis Batteries and Chargers 9 Nov 16, 2004 07:33 AM
My new canopy for my Hybrid micro--check it out Eco8gator Micro Helis 5 Dec 12, 2002 11:42 PM
What gear box for my 1406/2Y Joe Elston Power Systems 16 May 24, 2002 09:09 AM
