Old Aug 23, 2002, 08:51 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
OK, wizards, need ideas for prop/batt with GWS 100 in Pitts
Hi, guys,
I got the GWS 100 with the 3.22 gear in the Pitts and am trolling for suggestions for prop/batt combo. I am using QC830's and have tried:
Hand launching--
8x6 slow descent to the ground
9x7 flys ok, slow, not much climb. Forget aerobatics'
10x4.7 about the same as 9x7, slower though.
The thing weighs 9.5 oz. and has 210 sq in wing area. Any suggestions would be appreciated.
Chuck is offline Find More Posts by Chuck
Old Aug 23, 2002, 10:20 PM
Spaulding is offline
Find More Posts by Spaulding
Dangerous
Spaulding's Avatar
LA
Joined Nov 2001
Well, the gws 100 is pretty much the same weight as the gws 300 powerplant but is about half as powerful. You are better off using an M100 or a gws dual IPS if you want to stay light. Otherwise you need the 300. Ground clearance might hinder your decision because the dual IPS needs a large prop. The 300c takes a 10x8, which might barely make it with the stock LG. Let us know what you decide.
Spaulding is offline Find More Posts by Spaulding
Old Aug 23, 2002, 10:29 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
To echo what Spaulding said, I've not had much luck with the EPS 100, nor have I seen any rave rewiews here... I have had very good luck with the MiniMax motor/gearbox, which is very similar in power and ratio / prop size to the M100.
You may want to try the EDF hybrid thing on the IPS box. It'd keep the weight down.
Personally, I like the TigerShark hybrid. I have not done it with stock gears, but the 180 Egull motor with 4.8:1 gearing turning an 8x6 on QC830's is pretty good. It's a good 50% more power and speed than the IPS. It is a kludge job, though, so the MiniMax motor or the M100 are cleaner choices.
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 24, 2002, 08:12 AM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Thanks, where can I find the Tigershark and Egull motors? I really need to stay with a 9" or smaller prop because of the LG height. What about a 9x7 3-blade? Anyone try one of those on this type motor?
Chuck
Old Aug 24, 2002, 10:19 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Here's the motor: http://www.toytx.com/egullmotor.html
The problem with the stic DX-A gears is that this motor is a little larger in diameter. The shaft is also larger, so the pinion would need drilled.
You can shim the motor from the side with some balsa an a little strapping tape to fit, though.
Here's how I did it with some other gears that I got from Bleriot. He wouldn't say where he found them
He may still have some motors and gears, but haven't seen him around in a while,
Old Aug 24, 2002, 10:33 AM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Try an APC 8x6 SF prop. I recently changed the motor on my Mini Tornado wing to an EPS100 s1 #.22 like yours and a 8xs GWS prop, would hardly fly! Cut the shaft and mounted a 3mm collett adaptor an an APC 8x6 SF and it flys great, what a difference!! Using 8 cell 720 AAA NiMH don't bother with 7 cells.
Pete
peterv is offline Find More Posts by peterv
Question Need ideas for GWS IPS gear drive Tr0gTX Foamies (Kits) 6 Dec 29, 2004 03:44 PM
I need some ideas for things to do with the SS. Rolliedog12 GWS (Grand Wing Servo) 11 Oct 30, 2004 01:59 PM
Pitts Special with GWS 100-C motor Chuck Parkflyers 3 Aug 06, 2002 03:47 PM
Help! Need ideas for 010 flyer! Tres Wright Parkflyers 14 Jun 11, 2002 04:14 PM
Sig Rascal-need ideas for floats or skis cloudhopper Electric Plane Talk 2 Nov 25, 2001 02:21 PM
