This thread is privately moderated by Doug Sipprell, who may elect to delete unwanted replies.
Old Oct 09, 2006, 05:19 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
T-Hawk Trainer System Notification
I recently purchased the T-Hawk 3Ch RFT Trainer system, for use at our flying field when teaching new flyers. Nice package, transmitters are 72 Mhz based, and the "trainer" T-Hawk has a longer boom for more stable flight. The boom is also carbon fiber versus the standard and shorter fiberglass tube boom.
In experiementing with the two transmitters, connected via the included buddy cord, I noticed the following:
1.) Both Instructor and Student transmitter/consoles MUST have batteries in them. One console does NOT power the other.
2.) The student transmitter MUST be turned ON.
3.) The Instructor transmitter MUST have the same channel as the plane's
receiver, common sense dictates this, and the only way the student
transmitter/console can "communicate" with the plane is through the
Instructor's console, on the frequency or channel installed on the
instructor's console.
3.) If there is a crystal installed in the Student transmitter/console, the
transmitter will be transmitting on that channel, regardless of the position
of the trainer switch on the Instructor's transmitter/console. Therefore,
if the Student transmitter is on a different channel (frequency), and common
sense dictates it should be, than there is the real possibility of the
Student transmitter causing interference with another plane, and both the
student and the instructor would not be aware of this.
4.) If the crystal is removed from the Student transmitter, there is no
signal produced by the Student transmitter. Therefore, when using this
buddy system, it will be imperative that the crystal is first removed from
the Student transmitter/console BEFORE powering up the Student transmitter.
5.) If the Student transmitter/console has the SAME channel/crystal as the
Instructor's transmitter, there will be interference generated by the
Student transmitter as soon as both Student and Instructor transmitters are
powered up. In essence, you cannot fly/control the plane if BOTH
transmitters are on the same channel.
6.) With the crystal removed from the Student Transmitter, I can see no
reason why the Student transmitter would need to have the antenna extended. I need to check this out at our flying site.
Thus, I offer the following recommendation to those using or considering the use of the T-Hawk trainer/buddy system:
"Remove crystal from student transmitter/console before powering up
transmitters. This is important to prevent interference with another model
plane or with the T-Hawk itself. Only one transmitter, the Instructor's
transmitter, should have a crystal installed, and it must be the same
channel as the receiver in the T-Hawk."
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Found Looking for a T-Hawk trainer SpltdBalsa Aircraft - Electric - Airplanes (FS/W) 0 Nov 18, 2006 04:13 PM
For Sale T Hawk RTF Great Shape Great Trainer $100 or trade Buzz Bomb Aircraft - Electric - Airplanes (FS/W) 1 Aug 11, 2006 05:24 AM
For Sale T-Hawk trainer Lvacgar Aircraft - Electric - Airplanes (FS/W) 1 Sep 21, 2005 04:15 PM
Yippee! Black widow AV system on a T-Hawk: Hauntme13 Aerial Photography 4 May 24, 2004 10:14 PM
T-hawk (great trainer) Mac8 Aircraft - Electric - Airplanes (FS/W) 0 Mar 31, 2004 10:14 AM
