THE BIGn KFm4 project
The idea is for an update for the basic propjet design.. A big build by Otto D has a couple of good ideas that I want to use.. First is the capability of sliding grass take offs and second is a sub rudder that works well on his bigger version.. He achieves his grass take offs by using a higher motor location, and a fair lot of power Ottos build.. http://www.rcgroups.com/forums/showthread.php?t=1504288 Ive been working on a generic propjet build to enable a change of shape to determine what you end up with.. As with my smaller models profile outlines are all that are needed... changing them to make what ever sorta jet you prefer.. So using a downloaded 3 view drawing I did a trace over for the basic shapes using sketchup and combine them with the drawings already made, using both my previous build and Ottos I am going with a sorta YF22 It will be 48" long x 36" span First powered by an emax 2215/20.. 3 cells.. 9x5 prop.....edit this flew but lacked power... It was replaced by a 35-36 1800 kv motor.. the 9x5 prop was cut to 8x5.. It needs a 60A ESC and 2200 30C 3cell lipos... now its well overpowered and goes superbly.. Note.. this is a powerfull setup, it takes the jet up to 60 MPH , its not running to get speed but for thrust.. vertical is at half power, full power takes it up like a rocket.. Cruise is at half power or under... The construction is basic... EDIT now recommended and because of the massive power is that the main wing and controll surfaces and fins all be made as a doubled layers, so any ailerons and elevons need to be removed prior to laminating these together.. cloth hinges for all the surfaces must be placed between the two layers as you laminate cut out 2x main layers and two front outer layers for the KFm4 section..laminate..dont forget the cloth hinges..then fix the ailerons and elevons in place... Note the pictures only show my single layer build , so they dont show any cloth hinges being fitted for elevons....because they weren't... The only cloth hinge I used in the prototype was in the sub rudder construction...see post 138 for the hinges construction.. Make up the sides and lower fuzz using two 6mm depron layers.. The sides and lower front are chamfered if you want angled sides or fixed in place vertically... depending on what you are building.. Make a sub-rudder to the depth of the fuz sides..This is made using a double layer fixed fin a cloth hinge and a double layer rudder see pic 3 below Later the bottom will be sheeted over the front fixed part of the rudder and forward of the prop slot, but first the servos have to be mounted Make a top fuzz shape again two layers of 6mm and fix/slot in the motor mount ... I used one of the square tube mounts (10mm sq), and cut it into a slot with 3 degrees of down thrust, no side thrust The mount was glued in place with cool melt glue and then some additional side cheeks , two on each side, were placed to further block in and reinforce the tube type mounting .. . .Further reinforcing using tapes and cool melt glue were used to strengthen the motor block for the high powered motor..I used small side cheeks.. longer ones would be better.. pic4 All joints are butt glued only using UHU por.. they are then beaded with a cool melt adhesive on both sides of the joint. Later tape covering will be added to the wing and fuz..this will be also lapped over the joints and the end result is well strong ..
Before fixing the top structures, it is easier to fit all the servos etc. in place.
The elevons and ailerons, should be fully tape covered, full tape covering makes them a lot stiffer for better results.. Fit horns and pushrods..pic 2 post 124, back linking the elevons to the ailerons The first 3 pictures below were taken with the smaller power system componants,, however the "big stuff" all goes in the same location, and the bigger battery has plenty of back and fore adjustment to sort out the COG.. the velcro holds it nice and firmly Velcro... on the fuz there are 4 strips ..two inners have hooks..two outers have loops... On the battery I fit loop strips along all 4 long sides. The battery then will grip the hooks on the fuz and wing.. I then use a loose hook strip tie down as security which will grip either side of the battery and onto the battery as well.. this is a good secure system that will only release in a hard crash, or when you pull the battery for a change over..
I maidened my 48" version but the power is only marginal.. on low power it is not so good so I need some sugestions as to a better motor..
At the moment I am using a 2215/20 on three cells with a 9x5 prop... Idealy I want to keep the prop and three cells and have a much higher reving motor.. this is what I am on http://www.giantshark.co.uk/epower-2...-p-403201.html what I need is twice the power...40A about 400W on 3 cells Ive gone for this one....pic below...which is overkill but should do the job... + a couple of 2200 x30c 3 cells and a 60A esc EDIT.. the big motor is well good see the video in post 132 and furhter on..... Flying yesterday was only just ok, with the low powered motor......it really needs more go to power it round the turns... problems at low power... trying to get it round it would go slow, nose going up ( thats the back end dropping when its on its side) and then get adverse yaw setting in, it would then turn tightly and quickly in the opposite direction, dropping the nose suddenly... Luckily it is a real slow flier when needed so I could just correct it and fly away..ok Banking...another pain, it was noticeably dropping its rear end in a bank, which to me means it has too much vertical area in a forward position, or the COG for the side area on is set too far back.. I was correcting for this with rudder, and I suspect with better speed it will not be a problem roll rate...for me much too slow, but this will improve at speed.. heres the poor video
The big motor looks good hobyking do a review here
http://www.hobbyking.com/hobbyking/s...b21fb20ae042c2 It looks like it will go well.. I will be using only 3 cells, and either a 9x5 or 8x4 prop, so my power and consumption will be well under the max 60A.. I should still get a 2:1 power weight but at a reduced top speed, better for my lighter weight model.. |
More power... wow... understatement....
Before this flight, I had done a bit of beefing up and added some wheels... Although these wheels works, I repositioned them more internal so they didnt show as much... Internal they work just as well, and its better than having no wheels at all.. |
Another fight set up as above is better for sound levels and much better for roll rate...
My next problem to sort is the performance of the sub rudder, which has little or no effect at all.. .. ideas for causes...so far, are, the flexibility of the rudder and the lack of rear box decking is letting the air escape .. so I will do both and hope its better... I then realised that the sides that extended along with the rudder were the problem,straightening out the airflow..Otto came up with the same answer.. http://www.rcgroups.com/forums/showt...504288&page=42 flying.... on linked elevons and ailerons is super, I just want a bit of yaw for high alpha and knife edging... this is an impressive model, as usual the KFm4 is making it a point and go steady flyer.. there is no worries about low passes its all very smooth.. Varying the power with the high mounted motor make no difference to the flight direction, it keeps level, and simply goes that much faster.. smooth big aerobatics are impressive, but slow it a bit and bank and yank will bring it about fast... do a loop at too low a power and it rights itself and flies off near the top... enough power and it cruises the loop like it cruises through it all |
| Thread Tools | |
| AKM 54.25" span SU27 Flanker-PWR setup? | delta400 | Pusher Prop Jet Models | 1 | Sep 14, 2005 04:07 AM |
