Old Nov 18, 2008, 09:23 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Heres the F15 eagle lines
davereap is online now Find More Posts by davereap
Old Nov 18, 2008, 09:31 AM
davereap's Avatar
Joined Feb 2005
since these are just sorta-scale feel free to get creative...modify the fuz shape (most needed on the SU),and the wing shape to get it closer to the real thing..
How close you go depends on you... use the cog positions from the start of the post, just adjust/scale them for the size you builld
heres a couple of pics for shape and color..just ignore the canards on this f15 version
Old May 01, 2009, 11:07 AM
spiral_72 is offline
Find More Posts by spiral_72
Joined Mar 2008
SU-27 built!
Hey, I built one of your SU-27 foamies!
My final weight was 10.1oz
2.75oz - plane assembled (foam only)
0.55oz - two HS-55
1.60oz - 1300kV CD motor, mount and wires, GWS 8x4 prop and prop mount
0.18oz - Rx LiteFlight 4ch
0.50oz - 12A ESC
4.30oz - 1300mA 3cell Lipo
0.30oz - pushrods, control horns, velcro
Included in there is 0.3oz of hot glue (3 sticks at 0.1oz each)
I'll be running a 8x4 GWS prop. I could probably use a much smaller motor and battery, but I'll use what I got. For the moment I only have the elevons hooked up. I'll try to fly it this weekend. I might hook up the ailerons later, it depends how the first flight goes.
spiral_72 is offline Find More Posts by spiral_72
Old May 05, 2009, 08:18 AM
Joined Mar 2008
Wow! It (SU-27) flies great! More than that it looks awesome in the air!
Cut the ailerons. Elevons only do not seem to work on this model.
IMO the CG of 4.5" ahead of the horizontal fuse split it way off. Start with 4.0" ahead....... just my opinion.
Old Jul 05, 2009, 04:28 AM
davereap's Avatar
Joined Feb 2005
the best response is using the aileron and elevator linked as on the original ikarus version ...
it seems weird having both go up or down on the same side at the same time, but it works well
cog location is variable, best for a safe foward location on its first flights then move it back to suit your preferences
Old Dec 02, 2009, 09:09 PM
Mifoamflyer is offline
Find More Posts by Mifoamflyer
Mifoamflyer's Avatar
Michigan
Joined Nov 2009
Gundy Please contact me
Gundy please email me ref your 48" SU-27
thanks in advance
Al
Mifoamflyer is offline Find More Posts by Mifoamflyer
Old Dec 02, 2009, 09:13 PM
Michigan
Joined Nov 2009
Gundy Please contact me ref 48" SU-27
Thank you
Al
Old Dec 22, 2009, 04:53 AM
nenomart is offline
Find More Posts by nenomart
Joined Dec 2009
hi to all
check this out, is very interesting
http://depronmodel.blogspot.com/
nenomart is offline Find More Posts by nenomart
Old Jun 02, 2010, 04:35 AM
davereap's Avatar
Joined Feb 2005
Here are some construction views with a rough model to show how the thing is put together... obviously the shapes are only rough here, but they can be modified for any jet profiles
the sketchup file is included for your use
Old Jan 21, 2011, 08:13 AM
kokynator is offline
Find More Posts by kokynator
Joined Apr 2010
I'm going to build SU-27, thank you for your plans!
kokynator is offline Find More Posts by kokynator
Old Jan 21, 2011, 08:47 AM
Joined Apr 2010
Did you use 3mm or 6mm depron?
Old Jan 23, 2011, 09:16 AM
Joined Apr 2010
OK, I completed the build and I must say IT IS AWESOME! Thank you again for your plans!
Old Mar 13, 2011, 03:24 PM
Joined Apr 2010
Finished
Old Mar 14, 2011, 11:11 AM
Gundy is offline
Find More Posts by Gundy
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
This is a fun plane to fly.
I used a "pool noodle" for the nose, in one i built. it just bounced when it hits the ground.LOL
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Mar 28, 2011, 02:37 AM
tubeman is offline
Find More Posts by tubeman
Joined Mar 2008
cg for the su-24 24 inch
hi, im looking for the cg for the su-27 24inch wingspan ? what is it ?
Dan
tubeman is offline Find More Posts by tubeman
AKM 54.25" span SU27 Flanker-PWR setup? delta400 Pusher Prop Jet Models 1 Sep 14, 2005 04:07 AM
