Old Apr 13, 2008, 06:50 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
now made some decals which go nice on the dark depron
davereap is offline Find More Posts by davereap
Old Apr 14, 2008, 07:02 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
heres a top view for cutting
construction is as previous but uses all 6mm dark grey depron
use stringflys plans for top fuz shape ...length from aileron hinge line to the nose...make x2 and glue together
use stringflys design for the tails x2
bottom fuzes are mostly made with parallel edges... decide the depth depending on your batteries...give yourself an extra 1/4" or so
( mine were 40mm)
make 2 centre fuzes and glue together...length is from the aileron hinge line to the nose.
make 2 side fuses, these go from the elevator hinge line to the front (intake) shoulder...and are set parallel, the outside edges are 10" apart..
my side fuzes were glued vertical to the main wing surfaces..to allow a larger prop cut out if needed...and all the fuzes were the same depth.
(On the motor setup ive put in, I didnt need a bigger slot so I didnt need to glue them vertical)
..AS the raptor has angled sides, and if you decide go that way remember to allow a lot more depth on these outside fuzes to get the angles needed for the champher, whilst keeping the overall depth the same.
In addition there are a couple of lower cross pieces for strength...one at front across intakes...one at rear over the motor mount fixings.
I used a tube motor mount held in a depron sandwich....it lets me change motors easy..
motor used.....Emax 2212....approx1500Kv....11.1v ....draws 15A at full power using a GWS 9x5 cut to 6 3/4"x5.......loads of power!!!
I have replaced the prop with a cut down 8x4....cut to 6.5... this has dropped the full power to draw only 10A which is the max recommended for this motor
flying..... ....fast on 1/2 power...much faster than what I enjoy, still I expect I will get used to it..It can be slowed to a crawl at high alpha for landing
Old Apr 16, 2008, 11:19 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
finished pics....fair bit of artistic licence here..with the camo and the colours below for orientation
Old Apr 29, 2008, 05:47 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
I made a few mods to the nose shape as it was looking too short, and now I have done some decor for the design
Old Aug 30, 2008, 03:07 PM
nickrage is offline
Find More Posts by nickrage
Strathmore, Alberta Canada
Joined Jan 2004
K going to do the f-15 I have 3cell 1000 mah packs and either a himax 2808 0860 or a e-flight 370 1360kv outrunner any recomedations for which motor and prop?
nickrage is offline Find More Posts by nickrage
Old Aug 31, 2008, 03:07 AM
appa609 is offline
Find More Posts by appa609
made of foam
appa609's Avatar
Ontario, Canada.
Joined Aug 2008
Originally Posted by davereap
Tapeing, decoration and finally the radio gear all fitted.
for a change I used a camo paint scheme on the f15, I did the top in it, didnt like it much, and so did the bottom with the 2" coloured packing tape as I normally would.
anyone got a good colour scheme for the f15...best ive found which would suit the tape method is the NASA one ...see pics
all up weight 6 1/4 oz (no battery)
revised COG for first safe flight...4 1/2 inches, measured forward from the aileron hinge line/ CF mian spar
just buy duct tape and tape it all gray. paint also works.
appa609 is offline Find More Posts by appa609
Old Sep 20, 2008, 09:48 AM
nickrage is offline
Joined Jan 2004
done
this is our testing area su-27 with greyson hobby motor 6-4 prop
auw 11.1 oz he he
We may have been sniffing the CA glue a bit
http://www3.telus.net/public/jay_sam/skunkworks.wmv
Old Sep 24, 2008, 05:13 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
NICE
thats a different way of checking it out, must be good for getting the cog and lateral ballance correct
why dont you post the videos to youtube your link will play that much faster.
Old Oct 07, 2008, 02:44 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
this is what ive used on a 3mm depron model
http://robotbirds.com/catalog/produc...oducts_id=1787
with gws8x4 prop on 11.1v
and this on a 6mm depron version
http://www.brchobbies.co.uk/?page=sh...ditem&item=476
with the 8x4 cut to 6x4
a faster higher powered job
Old Oct 09, 2008, 11:08 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
do you even know the shape of a f22?!
starscream4002
starscream4002 is offline Find More Posts by starscream4002
Old Oct 13, 2008, 04:56 PM
Gundy is offline
Find More Posts by Gundy
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
looks good to me
Looks good to me
Later,
GUndy
Gundy is offline Find More Posts by Gundy
Old Oct 13, 2008, 05:20 PM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
Starscream, all of your posts are useless. Shhh!!!
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Oct 14, 2008, 08:37 AM
Gundy is offline
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
feeding the trolls
ya, I looked at his posts as well... I hate feeding the trolls, but I have built a bunch of davereap's ideas. I still fly my 48" SU27, it looks great in the air!
Later,
Gundy
- Jeff
Old Nov 11, 2008, 04:15 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
thanks Gundy..
check these out for great flyers
Nutball.. http://www.rcgroups.com/forums/showthread.php?t=836389
Superfly clone... http://www.rcgroups.com/forums/showt...=592883&page=3 post 44 on
youve probably seen them but dont miss out on the nutball... ive built mine from depron at 32" span and its a must have..
With all my designs the idea is simplicity and ease of build...fun scale, not real scale... you can adjust the shape to get as close to the real thing as you like...and add in as much as you like to get the realism..If you want scale models there are some great builders out there and the plans are available.
try here.. http://www.parkjets.com/free-plans.html
I like quick and simple builds that look sorta like the real thing. check out my vulcan
http://www.rcgroups.com/forums/showthread.php?t=595706
to me it looks ok...and it builds easy and flys a treat
from non aeromodellers the comment is usually...is that an army plane then? can I have a go?..etc..
Old Nov 18, 2008, 08:04 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Here are some revised plans/drawings using the google sketchup program
these are for the SU version
please note that whatever size you build the lower fuz depth should be made to suit your electrics and battery, dont scale it!..Ive found 1.5 inches to be good..and keep it flat then the lower cross braces will fit ok
ive also included the skp.zip so you can load it and modify for yourself
AKM 54.25" span SU27 Flanker-PWR setup? delta400 Pusher Prop Jet Models 1 Sep 14, 2005 04:07 AM
