Old Nov 06, 2006, 12:27 PM
supisdonk is offline
Find More Posts by supisdonk
huntington beach
Joined Oct 2006
Glad to hear that you tamed the beast. Its nice to hear that the f-15 flies as well as it looks
p.s. im still working on my mini su27.this is my first foame atempt. Learning alot as I go.
i'll try to get some pics up soon.
supisdonk is offline Find More Posts by supisdonk
Old Nov 07, 2006, 02:21 PM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
I have reduced yet again the rate for low settings and increased the expo to -45%. Very much easier now with plenty of control, low rates give a good roll high rates and it flashes round..
I am now going to move the COG back in steps as the specified cog is too far forward.
nice and safe though.. With the cog too forward as it is, the inverted flight is not easy, the nose drops very quickly and it requires a lot of down to keep it level.
As it is the model is flying well, it is comfortable with a bit more speed than the SU version, but this is probably due to the cog position
New project on the table an Avro vulcan, test flight spot on, flown so far on 2 cells well underpowered, too slow a climb, but still superb. Flys like a trainer, self righting, and glides better than anything else ive got. Not my design ( shame ) but when the drawings are done I will post them, as my friend is not pc literate....dave
davereap is offline Find More Posts by davereap
Old Nov 07, 2006, 03:16 PM
boberos is offline
Find More Posts by boberos
Ontario Canada
Joined Aug 2003
When you finish your test flight program, please let us know your final C of G position.
Do you find much difference between the 2 models in their flight characteristics?
Thanks.
boberos is offline Find More Posts by boberos
Old Nov 11, 2006, 03:39 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
The main difference is the extra response resulting from extending the elevators more towards the centre and directly into the props airflow. Now I have dialed this down to my liking, both planes are flying much the same..except when going downwind, the one with the extended elevators will now turn better..
This is not depending on it being the su or f15, both models will fly the same, as there are very little actual physical differences between the two designs.
Old Nov 12, 2006, 10:34 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Heres a link to the vulcan...another nice simple design
http://www.rcgroups.com/forums/showt...06#post6374108
Old Nov 12, 2006, 10:48 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Heres a link to my estratos plans
http://www.rcgroups.com/forums/showt...t=434265&pp=15
Old Dec 07, 2006, 02:25 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Just an FYI...... I downloaded the plans for the F-15 and it crashed my laptop with an accompanying virus. Grrrr....
Joe 1320 is offline Find More Posts by Joe 1320
Old Dec 07, 2006, 04:05 PM
totalywicked is offline
Find More Posts by totalywicked
Insert comment here:
totalywicked's Avatar
Placentia, CA
Joined Feb 2006
davereap:
Why are there 2 pilots in Su-27???
Is in it a single pilot jet???
Unless itís a Su-27KUB(trainer)
totalywicked is offline Find More Posts by totalywicked
Old Dec 20, 2006, 01:16 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
two pilots because that the only cockpit pic I had...
virus????????? dont know where that came from.. I use mcCafee and that should check for viruses..
I will download the plans now and see if there is a problem....dave
Old Dec 20, 2006, 01:24 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
Ive downloaded the zips and pdf's and no virus was picked up...dave
Old Oct 03, 2007, 01:47 PM
teched88 is offline
Find More Posts by teched88
teched88
SW PA
Joined Feb 2007
Is the slot for the prop bigger on this plane?
DepronDave's F-15 has a 6 inch slot. It looks like this could be set up for an 8" prop, Which suits my current setups much better. I have DepDavs plane, but no luck with my current motor prop combos.
teched88 is offline Find More Posts by teched88
Old Dec 11, 2007, 07:47 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Yes the slot is for an 8" prop... cheated a bit on the fuz width to suit my motor setup. it works ok
Old Jan 30, 2008, 08:01 AM
CrocEnd is online now
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
Dave where's the video then
Thanx
CrocEnd is online now Find More Posts by CrocEnd
Old Jan 31, 2008, 04:31 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
sorry no videos, the planes have been recycled now due to lack of room. For similar performance check out the large icarus su27, its much the same....dave
Old Apr 13, 2008, 03:09 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Thought I'd update this thread with an f22 based model
Built with all 6mm depron
The span is 27" .... length 36".... body section 10" width
I used parts of plans from dekan and stringfly to give rough shapes then made some additional mods of my own
The fus. width was increased to 10" which lets you fit bigger props in.
The elevators were reshaped by moving the jet exhausts back a bit, to bring them fully into the props wash, giving more thrust vectoring.
The nose was shortened a bit.
AUW is 12.5oz with a 1350..11.1v lipo
the model has some more work to do then I will get a video
AKM 54.25" span SU27 Flanker-PWR setup? delta400 Pusher Prop Jet Models 1 Sep 14, 2005 04:07 AM
