Espritmodel.com Heli Air
Old Oct 11, 2006, 07:09 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
The packing tape comes from staples in the UK and you can buy a pack with several colours in it.
If you use the reflex xtr sim the su27 shocky and the estratos delta design can be downloaded from
http://www.rc-sim.de/index_en.htm ...downloads reflex planes
the delta weighs in at 12.5 oz..cheapo bell motor,8x4prop,1000mA 11.1v lipo,
usual stuff, slightly larger span. less flight time as the bells are a bit more power hungry at 7-8A full power with this prop.
davereap is offline Find More Posts by davereap
Old Oct 12, 2006, 01:22 PM
Hack of all trades...
Smooth Spanky's Avatar
Detroit, Michigan
Dave: Thanks for the setup info. I guess maybe next time I should actually look at the material before I start firing out questions! The Estratos is also on my never-ending list of things to try.
Smooth Spanky is offline Find More Posts by Smooth Spanky
Old Oct 13, 2006, 08:19 AM
davereap's Avatar
Joined Feb 2005
Of the two the su is prefered for its longer flight times.. ive been too lazy to try the cdrom motor on the estratos, but I must give it a go.
Old Oct 14, 2006, 11:47 AM
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Hi Dave thanks for the email --- tracked it down to here but I cant dowmload dwg can you repost plans in pdf
Also that little cd rom motor is available from united hobbies for about £6.00 regards
Upup is offline Find More Posts by Upup
Old Oct 14, 2006, 04:04 PM
Ontario Canada
Joined Aug 2003
Davereap,
Could your plans be posted again, but in PDF as I can't open these ones.
Bob
boberos is offline Find More Posts by boberos
Old Oct 16, 2006, 07:21 AM
davereap's Avatar
Joined Feb 2005
will try...
....the converter has given some slightly odd results
some of the curves are now made from straight line sections, but you will see that easy enough.
Ive been using velcro to hold on my batteries... be warned the self adhesive tape type needs to be stuck to the depron with uhu por, (it does stick to the battery covering ok)
It will come away eventually under the stresses in flight and the plane will go haywire, mine just ended up in the top of a 40' tree
I found out that I can still climb trees at 57 and poked it free with a fishing rod.. should have sent the boy up there...must have been mad
Old Oct 16, 2006, 07:43 AM
davereap's Avatar
Joined Feb 2005
For comparison here is the 24" version of the su by stringfly...in case you havn,t seen it.
this is an enlargement of the ikarus shock flyer
and DepronDaves version of the f15
Old Oct 16, 2006, 07:53 AM
davereap's Avatar
Joined Feb 2005
Strange you cant download the drawing files...I just left clicked on one then saved it to my docs, then extracted it ok with winzip....dave
Old Oct 16, 2006, 02:14 PM
Ontario Canada
Joined Aug 2003
Some zip files open for me & others do not. Can't explain it.
Perhaps poor computer skills.
Thanks much for the pdf's. I'm sure others will appreciate them as well.
Bob
Old Oct 19, 2006, 01:25 AM
huntington beach
Joined Oct 2006
would like to see more of the f-15 please
supisdonk is offline Find More Posts by supisdonk
Old Oct 20, 2006, 02:54 AM
huntington beach
Joined Oct 2006
ya I was able to save it. but was not able to print it
I was realy looking foward to making one.
Old Oct 20, 2006, 01:25 PM
davereap's Avatar
Joined Feb 2005
Download and Use the free "adobe reader" to open the 3-pdf files, print from there, the outlines in red are the shape variation for the f15. The shapes are kept simple to let you measure and draw it out, rather than needing a full size plan. As long as you keep the topview the same the cog will not need changing.. you can mod the side view to get a better representation of you choice of aircraft if you want.
Old Oct 21, 2006, 12:53 AM
huntington beach
Joined Oct 2006
amazing how well that worked. I got my plans printed out and ready to start cuting some foam. My next speed bump is figuring out how to poast the pics o well i'll fig that one out soon enough
Old Oct 21, 2006, 09:56 AM
davereap's Avatar
Joined Feb 2005
1..take your pics
2..use a photo editor to make the pics size smaller about 800x 600 ( less time to upload)and save the files as .jpg
3..in the reply go advanced
4..click on manage attachments
5..browse to where you saved your images, select your image or images, click on upload
6..when upload done..click on submit your reply
Old Oct 24, 2006, 11:37 AM
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Dave..... can we have a close up of the dual control rod linkage on the su... did you have any problems getting it set up I can't see any adjusters how did you do it.
PS ..... A good photo converter is picassa and its free..... it also finds every image on your computer ( were did I save that photo of when I was young and handsome) and displays thumbnails into date order
AKM 54.25" span SU27 Flanker-PWR setup? delta400 Pusher Prop Jet Models 1 Sep 14, 2005 04:07 AM
