Old Oct 09, 2006, 02:13 AM
jphong is offline
Find More Posts by jphong
BUILDnFLY
jphong's Avatar
Edmonton, Alberta, Canada
Joined Apr 2006
Energizer lawn and garden battery
Hey guys, just wondering if any of you know the capacity of the Engergizer lawn and garden battery (got it from Wal-mart on sale) It says it has 200 cold cranking amps but nothing about the capacity. What is the average of these things and is this a better alternative than the smaller 7.5Ah gel cels available? Should I just shell out and get the larger marine type batteries that have a capacity of 80-90Ah? Thanks!
jphong is offline Find More Posts by jphong
Old Oct 09, 2006, 02:15 AM
jphong is offline
BUILDnFLY
jphong's Avatar
Joined Apr 2006
Oh and I am also charging it with an old 12v 5amp charger that my friend had laying around...it has overcharge protection and I've measured a current draw of 2.5-2.6 amps when hooked up with the battery. Will this overcharge protection be useful for this type of battery? And also is the 5amp current supply just right or not? Thanks again!
Old Oct 09, 2006, 04:04 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
I did a quick Google and came up with 24 AHr
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Oct 09, 2006, 04:16 PM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
they are starter batteries - you cycle them once and they are damaged. They are not designed to be discharged - just spin the stater for 15 seconds. Marine batteries are hybreds, with thicker plates but are still not designed to be discharger <11.2V. You need a true deep cycle battery - designed to discharge to nil capacity and the charged back up to full.
ImaBiggles is offline Find More Posts by ImaBiggles
Old Oct 09, 2006, 05:54 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Best would be Optima Yellow top. Sealed, deep cycle. Auto Zone or Pep Boys or similar
Pinecone is offline Find More Posts by Pinecone
Old Oct 10, 2006, 10:30 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
I use the lawn and garden batteries almost exclusively for my field use. They will give excellent service and life if properly maintained. By that I mean, never NEVER never discharge below 11.7 volts under load. Recharge with the proper equipment (constant voltage, limited current charger) and do not leave it stored in a discharged state. Check out www.rcbatteryclinic.com for some good advice on the care of your batteries, all types.
Rodney is offline Find More Posts by Rodney
Old Oct 10, 2006, 07:32 PM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Lawn mower batts. work fine. No different than your car batt. just lower capacity. Been using a jumpstarter for the last couple of yrs. which is close to a mower batt.
flypaper 2 is offline Find More Posts by flypaper 2
Old Oct 11, 2006, 10:00 AM
truthunter is offline
Find More Posts by truthunter
MaxiR SE~E620SE
truthunter's Avatar
Campbell Hall, NY
Joined Jan 2005
Actually, the yellow top D34 and blue top D34M seem to be the same at 55Ah. The blue top D31M would be the best at 75Ah. They are all expensive though
truthunter is offline Find More Posts by truthunter
Old Oct 11, 2006, 10:22 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
get a FLOAT CHARGER for it from Harbor Freight tools to slow charge it and prevent it from SULPHATING maintaining the voltage at ~ 13.5V and then it will last longer than U think it can
hall woo is offline Find More Posts by hall woo
Old Oct 11, 2006, 02:32 PM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
Actually best thing is to get a Battery Tender or Battery Minder. These are microprocessor controlled to not harm the battery. Battery Minder even has a mode to try to bring a sulphated battery back. I would not trust a Harbor Frieght float charger on a good battery.
I use Battery Minders on competition cars that sit for long periods of time.
Help! Can I charge my Lead Acid lawn tractor battery? HIGHFLYER99 Batteries and Chargers 8 May 24, 2007 07:59 AM
Lawn mower Battery-work for charger? mefly2 Electric Plane Talk 22 Jul 06, 2005 02:24 AM
charging a lawn and garden battery w/triton electro Batteries and Chargers 4 Aug 19, 2003 11:06 AM
Lawn Mower Battery Amps Ghostbear Beginner Training Area (Aircraft-Electric) 5 May 25, 2002 08:57 AM
Lawn mower battery source? temacc Electric Plane Talk 3 Nov 10, 2001 11:30 PM
