Old Oct 08, 2006, 08:49 PM
bryadelm is offline
Find More Posts by bryadelm
United States, PA, West Chester
Joined Mar 2006
Need Help with Kill Switch on Zenoah G-38
I need help with installing a Kill Switch on a new (late model) Zenoah G-38, which is not generating any spark when I rotate the prop. I purchased the Zenoah Starter Kit that included a kill switch.
The instruction for this kill switch include "locate the black lead from the coil with the open female connector. Connect this lead to the bullet end of kill switch and the attach the other switch lead to the motor mount bolt or crankcase bolt."
I cut the black wire at the forward end of the Zenoah G-38 magneto attached this black wire to the bullet end of kill switch. I attach the other switch lead to the motor mount bolt or crankcase bolt. No spark is observed.
I have pictures that I can later attach here.
On page 4 of the Zenoah owners manual is a diagram showing the black lead going to the kill switch and the red lead going to the base of the spark lead. However, I could not figure what is the red lead and where would it go to the base of the spark lead?
Should I have rather attached the female (square solderd metal tab) which was connected to this black wire to the bullet end of kill switch?
bryadelm is offline Find More Posts by bryadelm
Old Oct 09, 2006, 08:34 AM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
kill switch
Cutting the black wire off the mag is your problem of "no" spark.. You leave that black wire attached and solder "to the connection" to hook up your switch.. At least that is how I'm operating my G38s...Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Oct 09, 2006, 08:58 PM
bryadelm is offline
Joined Mar 2006
This is exactly what I was told today by Horizon Hobby Support. Why don't they say this in the instruction manual for the kill switch with their Zenoah starter kit?
We have ignition - well at least a spark!
Thank you!
Old Oct 09, 2006, 10:04 PM
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
Spark..
Spark is good !!! K@@L... Brian
Thank you!
I need help with Mosfet identification on my Jeti esc WickedFunRC Power Systems 35 Sep 24, 2013 02:13 PM
Need help with charging difficulties on NIMH..... matchlessaero Parkflyers 4 Jan 06, 2003 09:05 PM
need help with elevon mixing on a Futaba FP-T7UAP epkoncept Electric Plane Talk 2 Jul 22, 2002 08:07 PM
need help with elevon mixing on a Futaba FT-T7UAP epkoncept Foamies (Kits) 0 Jul 21, 2002 11:23 PM
Need help with location of esc on brushless T-33 dom Electric Ducted Fan Jet Talk 1 Apr 25, 2002 01:34 PM
