Old Feb 12, 2010, 08:32 AM
alfoot is offline
Find More Posts by alfoot
Keep it simple
alfoot's Avatar
Salisbury,England
Joined Jan 2005
Adrian,
Your wish is my command All of the Monotwirl movies are nowon the thread in Youtube. It was so frustrating when Putfile caved in, I must have about 100 movies that need re-uploading to Youtube now.
Here are a couple of movies of the micro ( 1/3 size) version of the Monotwirl that I haven't previously posted here:-
Micromonotwirl 14 Oct 07 (2 min 2 sec)
Indoor movie here:-
Micro Monotwirl Autogyro Indoors 13 Oct 07 (2 min 28 sec)
Al
alfoot is offline Find More Posts by alfoot
Old Feb 13, 2010, 06:06 AM
mustangsforme is offline
Find More Posts by mustangsforme
Monash, S.Aust.
Joined Apr 2004
Thanks for doing that Al, your effort is much appreciated.
With your production rate, you are set to replace the fine gentleman who ran Gyronuts for a while with the plans, tips & info that you make available.
I'll be back!
Cheers,
Adrian
mustangsforme is offline Find More Posts by mustangsforme
Old Feb 13, 2010, 08:03 AM
tashley is offline
Find More Posts by tashley
Aerial Images of Texas
tashley's Avatar
The Texas Gulf Coast where hurricanes come to play
Joined Aug 2003
Yes, thanks Al.
tashley is offline Find More Posts by tashley
Old Mar 08, 2010, 08:47 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by alfoot View Post
...Here's my latest version of this aircraft - the MiniMonoTwirl, with a 12 inch diameter rotor (about 50% of the original).
I've done a micro version powered by a 7mm pager which weighed 10 grams, but this one has a 5 gram brushless motor, Musclewire servos for rudder and elevator and a 3.7 gram servo for lateral rotor tilt. Microinvent receiver and a 2 cell 250mAh battery. Total weight 50 grams.
I know it has been awhile, but I was wondering how to do a scaledown of
the monotwirl plans to the mini and micro versions.
From the photos (post #32), the rotor likes the same 1.5 inch wide 3mm depron blades attached in the same way. The only difference is that as
you make the smaller versions, the blades get shorter:
~6 inches each for the mini version, ? for the micro version.
The weights for the mini and micro versions are mentioned above,
as is the length (~50% of the original) of the mini version.
I am wondering what the length of the micro version is.
Thanks.
flying-llama is offline Find More Posts by flying-llama
Old Mar 09, 2010, 02:28 AM
alfoot is offline
Keep it simple
alfoot's Avatar
Salisbury,England
Joined Jan 2005
Hi,
The MicroMonotwirl is 22.5 cm long from the back of the rudder to the front of the fuselage. I used 1 inch chord rotor blades with a rotor diameter of 8 1/4 inches. As the lift/drag was not good, I also used stub wings to get better performance. Everything was made from 2mm depron.
Al
Old Mar 09, 2010, 05:28 PM
Joined Mar 2006
... I also used stub wings to get better performance. ...
Thanks for the size information.
I am new to autogyros, so I may use stub wings as "training gear"
for any autogyro that I build.
One thing that I am learning from reading about auto-gyros is that when scaling up or down,
not only does one need to worry about scaling lengths, areas (wing & disc loading) and weights,
one also needs to worry about scaling the amount of flexing done by the rotor blades.
Old Jul 22, 2010, 06:25 PM
wriggs is offline
Find More Posts by wriggs
Factorywriggs
Joined Jun 2009
Monotwirl plan
Originally Posted by SafeLandings View Post
Hi All,
Does anyone know where the Monotwirl plan can be obtained from?
It looks a great little design and flies well
Regards Rich
As i could not find a monotwirl plan download, i am using the twirl plan for profiles and scale and then scaling up to 40 inch length using tileprint software.I am going to build it as two sides as this gives a proper fuselage with 6mm inner platform spine and formers with 3mm sides. I will hide everything inside but this method gives more variation and additions to the design. The cockpit will house the two servos for elevator and rudder covered with a platform with pilot. All other areas of the monotwirl will be hand scaled and added to the drawing as we go.
I feel enthusiastic and excited about this new project because the original twirl flew so well and i had a lot of fun with it, just have to try the other one, but bigger. I will keep everyone posted with photo's as we progress and one day the eventful first flight. Watch this space...
wriggs is offline Find More Posts by wriggs
Old Jul 23, 2010, 12:40 AM
chippypilot is offline
Find More Posts by chippypilot
Joined May 2009
The plans for the MonoTwirl can be found at Post 54 in this thread.
chippypilot is offline Find More Posts by chippypilot
Old Jul 23, 2010, 06:03 AM
flying scrap is offline
Find More Posts by flying scrap
flying scrap's Avatar
blackpool, lancashire, UK
Joined Feb 2005
hi al, just want to say thanks for the plans, it flies great
i did modify it a bit ok quite alot really
as i only had enough depron for 2 sets of rotors and a cut down
tail i used carbon tubes for the rest
because my field is very rough i broke the blades alot on landings
so i changed them for a couple of rotorshape blades
that worked a treat
heres a couple of photos of my efforts
Name: little wallis 092.jpg
Description: Name: little wallis 093.jpg
Description:
pete
flying scrap is offline Find More Posts by flying scrap
Old Jul 24, 2010, 01:00 PM
Joined May 2009
maiden flight.
It was flying nice and straight from the hand launch until the prop saver band came off! and then autogyroed down. I'm really pleased with the model. thanks for the plan.
Now to work out a better prop. mount and strengthen the landing gear.
Steve
Old Jul 24, 2010, 02:13 PM
Jockadopolus is online now
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Videos Steve?
Joe
Jockadopolus is online now Find More Posts by Jockadopolus
Old Jul 24, 2010, 02:32 PM
Joined May 2009
not yet, Joe. No cameraman!
Old Jul 25, 2010, 03:46 PM
Joined May 2009
So here is some video of two very short "flights". Any tips on how to make the longer greatfully received.
MonoTwirl250710_0002.wmv (0 min 49 sec)
Old Jul 26, 2010, 03:57 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Steve,
I'm sure AL will be able to point you in the right direction, to me it looks tail heavy?
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Jul 26, 2010, 01:51 PM
alfoot is offline
Keep it simple
alfoot's Avatar
Salisbury,England
Joined Jan 2005
Steve,
The launch technique seemed pretty good.
As Rich says, it is worth checking the CG.
You said that it went off straight the first time you tried it (before the prop came off).
For the launches that you filmed, was it exactly into wind? It looked from the movie that it yawed off left pretty much instantly, and you would need to be quick to get it back into wind using the rudder. Was the rotor trimmed level?
Something you could try would be to hold it into wind like you did in the movie, with the power off, and move the rotor control to feel what this control is doing. You may also be able to feel if the autogyro wants to tilt left, and, if so, pre-apply some trim. Repeat the exercise with the motor at take-off power and repeat, so that it feels as if it will stay level when you launch.
A final thought might be that the rotor blades are not flapping enough. If you used UHU Por to glue the blades then they should flex enough.
Hope this helps,
Al
Stevens G480 Video now up! skyyking Parkflyers 24 Apr 21, 2004 09:25 PM
The EdgeRC Pocket Combat Twin video is now up!!! birdofprey Parkflyers 6 Jul 31, 2003 09:31 PM
Interesting site with early bird video clips Ian Easton Scale Kit/Scratch Built 0 Jul 25, 2002 01:19 PM
Tomcat video now ready to view bipeflyer Electric Ducted Fan Jet Talk 43 Jul 24, 2002 08:04 PM
