Old Jun 29, 2001, 01:05 PM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Yes, it will work fine.
Good luck,
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Jun 29, 2001, 01:07 PM
member73 is offline
Find More Posts by member73
member73's Avatar
Wakefield, MA
Joined Feb 2001
yes, the Y cable will work fine, just pay attention to the direction of travel for each servo before you install them.
member73 is offline Find More Posts by member73
Old Jun 29, 2001, 04:09 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Ditto - since the servo's are connected with a Y-harness sharing one rx outlet they are in parallell which the rx do not take notice of how many servo's there actually are. Tge rx will only see "one" and both will behave as one.
Haldor is offline Find More Posts by Haldor
Old Jun 29, 2001, 05:20 PM
John E is offline
Find More Posts by John E
Bristol, England
Joined Aug 2000
Hi Al,
Yes, and if identical servos are fitted to each aileron as a mirror image of each other, then the orientation is fine.
Good luck with the Mad Dog,
John
John E is offline Find More Posts by John E
Old Jun 30, 2001, 12:54 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
Can we run two ail. servos and elev. on 3 chan. receiver ?
Can we use two servos for ailerons and one servo for elevator on a Hitec HS-3mb 3 channel receiver ?
Will this work with a y-adaptor for the two aileron servos so we still have channel 3 for throttle/esc ?
We are trying to use my son's 3 channel hitec SS 3 radio to fly his mad dog on ailerons, elevator, and throttle.
Any help is appreciated. Thanks
Al
Al P is offline Find More Posts by Al P
can I run two battery packs on one plane, at the same time? e-sailpilot86 Power Systems 8 Mar 08, 2008 07:36 PM
Discussion Can you run a "3cell" motor on 4 cells midrian Power Systems 6 Apr 23, 2007 10:46 AM
Can't run two Hackers off one controller? dom Power Systems 2 Apr 25, 2002 09:13 AM
RX and Servos on 3.6v? Moss Electric Sailplanes 0 Aug 05, 2001 07:01 PM
Can we start a thread on Lithium battery capabilities? watersharer Electric Plane Talk 32 Aug 04, 2001 05:02 AM
