Old Oct 05, 2006, 06:57 PM
mozmonkey is offline
Find More Posts by mozmonkey
mozmonkey's Avatar
San Jose, Ca
Joined Aug 2006
Foam-Safe Spray Paint
I've heard that several people use spray paint purchased from their local hardware store to paint their planes. Does anybody know which ones are foam safe, or which ones to avoid?
mozmonkey is offline Find More Posts by mozmonkey
Old Oct 05, 2006, 11:53 PM
ecologito is offline
Find More Posts by ecologito
Spring time, planes bloom
ecologito's Avatar
near UNC Charlotte, NC
Joined May 2003
I just painted my e-starter with Krylon spraypaint from Walmart.
http://www.krylon.com/sprayyourway/h2oproducts/
different colors and won't hurt the foam at all
ecologito is offline Find More Posts by ecologito
Old Oct 06, 2006, 12:43 AM
T_om is online now
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
I use water based latex and latex enamel (from several sources) and have not had a problem.
Tom
T_om is online now Find More Posts by T_om
Old Oct 09, 2006, 01:59 AM
mozmonkey's Avatar
San Jose, Ca
Joined Aug 2006
Tom
Do you know any brands off-hand? Where do you get these?
Old Oct 09, 2006, 11:21 AM
T_om is online now
The Junk Man
Joined Jul 2006
The paint I am using now is from Ace Hardware. It is called "Ace Royal 100% Acrylic Latex Enamel". I am using the Ace paint only because there is an Ace Hardware store within 2 miles of my house and they computer color mix anything I want.
I have also used latex paint from Home Depot and Lowes... both worked fine but I slightly prefer the "Behr" brand paints from Home Depot. The Behr metallics are VERY nice.
Tom
Old Oct 09, 2006, 04:36 PM
mozmonkey's Avatar
San Jose, Ca
Joined Aug 2006
Are these spray paints? If not, do you just apply them with a brush or sprayer of some kind?
Old Oct 09, 2006, 05:16 PM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Rustoleum!!!
Viper Pilot is offline Find More Posts by Viper Pilot
Old Oct 09, 2006, 05:17 PM
T_om is online now
The Junk Man
Joined Jul 2006
These are not 'spray paints' as in rattle can paint. They are regular old house paints.
I apply mine with airbrushes and a larger touch-up gun intended for automotive use.
Tom
Old Oct 09, 2006, 06:59 PM
mozmonkey's Avatar
San Jose, Ca
Joined Aug 2006
Originally Posted by Viper Pilot
Rustoleum!!!
Then I guess a better question is: "what type of spray paint is NOT foam safe"? I tried a couple cans I already had and they dissolved the test foam I sprayed them on.
Unfortunately I don't have an airbrush and am looking for a quick and cheap way to do it right now without investing in more equipment. I'll probably invest in an airbrush sometime in the next 6 months.
Old Oct 09, 2006, 08:05 PM
TrappedinNM is offline
Find More Posts by TrappedinNM
All posts Copyright '07
Joined Sep 2004
createx airbursh paints are great, even in a $5 harbor freight airbrush system. they cost about $3 per bottle at Michaels. no thinning needed. if you have a compressor (even a big one), you are good to go. just get a cheap regulator.
TrappedinNM is offline Find More Posts by TrappedinNM
Old Oct 11, 2006, 11:45 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
I just used Krylon Shortcuts for the first time on a Depron model. Many folks in the foamie section highly recommended it and it was pleasant to work with. Fast drying, easy to mask lines, decent color selection. Only downside is the cans are small like the Tamiya car paints so depending on model size you may need a couple cans. Found at Ace, True Value, and I heard Michaels but not 100% sure.
Your quest to find foam safe rattle can paints is going to be short. Most rattle-cans use solvents in their propellant like acetone. They are designed to evaporate quickly out of the paint and promote flow of the paint while it's present. Solvents eat foam and many plastics. Foam safe paints use special propellants and water based ingredients. Generally they are well marked that they are foam compatable since they are marketing the arts and crafts sector. They are usually a couple bucks more a can but worth it if you don't want to break out the air compressors and spray guns.
But, be careful of any 'ole brand of paint you suspect may be foam safe or the lady at Michaels says is foam safe. My buddy bought cans of paint at Michaels and started spraying his molded foamie (without testing) and 5 minutes later his plane looked like it took an acid bath!! The solvents can take a few minutes to eat through foam so be patient when testing.
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Oct 11, 2006, 12:59 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
So what is wrong with the quoted spray paint? I guess the question was answered with the first reply.
Ivan
ivanc is offline Find More Posts by ivanc
Old Oct 11, 2006, 04:01 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
There's nothing wrong with that...problem is sometimes it's tough to find a specific brand or style so it's good to know alternatives.
Old Oct 11, 2006, 05:33 PM
mozmonkey's Avatar
San Jose, Ca
Joined Aug 2006
There's nothing wrong with it, I'm just having trouble finding it. My local Walmart said they carried it, but when I got there they had only 2 colors in stock -- and you guessed it -- they weren't the colors I was looking for. I'm trying to find out my options so I can go anywhere and know what I can buy.
I'm going to try another Walmart tomorrow. So far the Krylon H2O looks good and is at a great price ($3.77) compared to the small cans they sell at the LHS for $5.
I've been testing every can on scrap foam first. It's pretty impressive watching it eat through the foam and relieving to know I tried it first.
Old Oct 29, 2006, 12:33 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
The Krylon H20 Flaked right off of th foam of my Megatech Stealth.
Do all of these acrylic paints have a problem with this?
Smokescreen38 is offline Find More Posts by Smokescreen38
FINALLY! An inexpensive foam safe spray paint Tom Frank Parkflyers 56 Dec 02, 2008 06:18 AM
Discussion Foam Safe Spray Paint? littleport2003 Electric Plane Talk 12 Jan 27, 2006 08:10 AM
Foam-safe spray paint? treelander Beginner Training Area (Aircraft-Electric) 5 Oct 09, 2005 11:08 PM
foam safe spray paint from wal-mart?? paul747 Parkflyers 4 Apr 09, 2005 05:00 AM
Foam Safe Spray Paint? acvar Foamies (Kits) 10 May 07, 2003 08:28 PM
