Old Aug 22, 2002, 09:23 PM
jayd is offline
Find More Posts by jayd
Joined Jun 2002
Fokker Dr 1, Albatros D. V, Spirit of St. Louis, TM Videos
The link below will take you to a site where you can view 4 different planes in flight. You will need to have RealMedia Player installed to view these vidoes, there is a link on the page that will take you to RealMedia'a site where you can install their free player. The video sizes ranges from 650k to 1.2 meg, download times vary depending on what speed connection you may have.
http://members.cox.net/jay.driggars/
jayd is offline Find More Posts by jayd
Old Aug 23, 2002, 12:37 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Nice videos! That Spirit of St Louis looks GREAT in flight. Does she fly as well as she looks?
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Aug 23, 2002, 01:08 AM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
Any info on the power unit used in the Dr 1? It looks faster then others I have seen from Kavan. Mike Heer
Old Aug 23, 2002, 01:13 AM
jayd is offline
Joined Jun 2002
Spirit of St. Louis
Yes it does fly very well, the only problem I had was that the stock battery box placement and battery type made it to tail heavy to fly, it required to much added weight on the nose. I made a new battery box that uses an 8 cell flat pack which allowed for proper CG without any additional weight.
Old Aug 23, 2002, 01:21 AM
jayd is offline
Joined Jun 2002
Fokker Dr 1
Yes it was under powered with the stock motor/gearbox, and the stock motor only lasted about 10 flights. I replaced the motor with a GWS 370 from a Zero, it has the same shaft diameter and mounting holes as the stock motor. All I had to do was swap the pinion gear. It will fly at less than half throttle with a 10x4.7 prop.
Old Aug 23, 2002, 06:41 AM
uncled is offline
Find More Posts by uncled
Iron Mountain,MI
Joined May 2002
jayd
Those were very nice videos !! I liked them all - - - - I noticed the Moth doesn't look so pigeon winged as most Wish all would use the Real Player format also, there are so many videos I can never seem to open Good looking flying and landing Thanks for the show , Don
uncled is offline Find More Posts by uncled
1/12th scale Fokker Dr.1 and Sparrow II Free Flight and 1/14th scale Albatros DII AerodromeRC Scale Kit/Scratch Built 3 Aug 29, 2005 03:22 PM
1/12th scale Fokker Dr.1 and Sparrow II Free Flight and 1/14th scale Albatros DII AerodromeRC Scratchbuilt Indoor and Micro Models 0 Aug 28, 2005 06:26 PM
Dare Dr-I and Spirit of St. Louis Erinair Scale Kit/Scratch Built 3 May 15, 2002 11:56 PM
Fokker DR 1 Ron Scale Kit/Scratch Built 24 Jul 10, 2001 10:26 PM
Fokker DR 1 Ron Scale Kit/Scratch Built 19 May 28, 2001 08:30 PM
