Hello Ken,
I am in the process of building a "big brother' to the WindLord that I am calling "Bagheera" http://www.rcgroups.com/forums/showthread.php?t=536530 It is actually a re-vamp of the ZonZoecker that Roy Walton built, but it's heritage goes back to the WindLord, and I am using the WindLord's plans from RCM as the basic guide. I do plan to build the wing using all of the suggestions you've mentioned above. My question for you is, where along the wing chord would you suggest placing the spoiler, and how big would you make it? Most suggestions I've recieved so far say at the 50% chord mark and at least 1 and 1/4 inches deep. |
Here is my quite old, quite beat up Windlord.
It was flyable until about 15 years ago when the dog decided he wanted to look out the window it was sitting in front of, hence the holes in the wings. It looks even worse from the bottom. Lots of patches in some kind of black "Mack-Tack" shelving paper or something. What was I thinking! Maybe I was just too broke/cheap to spring for more Monokote. Either that or I was in a big hurry. A few things I want to do ( on top of stripping it down, recovering and painting it) - Remove the extra 8" span I built in 20 odd years ago. It must have seemed like a good idea at the time to add an extra rib bay, but it moves it up from Standard to Open, and right out of Sport Sailplane. - Seriously thinking of going electric. Then I can at least enter Sport Sailplane with a big enough plane to see after a 2 minute climb .I am of two minds here. Part of me would like to put this thing up on a high start again too. Perhaps I could build a new electric fuse, and share the wings. A lot of work in those big wing roots - Put the elevator servos in the wing. As Ken points out, my hand cut slots for the elevator rods were never up to snuff. I did a "fix" at the time with music wire rails, but the controls were never as smooth as I wanted them to be. - With the elevator servos already there, put the spoiler ones out there as well. Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
MI
Joined Nov 2003
I have made another change, sorry Ray. This one has no real recomendation behind it , I just don't have a good piece of balsa block at the moment, and I don't want to mail order. This method extends the bulkheads out to the 1/8 ply cap rib which is glued to them. Then a "shelf" of balsa is added to the inside, smaller by the thickness of the intended fillet sheeting (clear as mud?) The inside shape, next to the fuse side will have to wait untill further assembly as I cant quite visualise it acuratly now. I have used this method on my scale ships and it will work, but its much more time consuming than block. again this is not a recomended mod, just me!
The fine razor saw cuts in the triangle stock are to help the fuse sides bent to match the top view profile. flex the sides over the plans and you get an arc, not exactly what the shape needs to be, a few cuts in the triangle renoves a bit of wood allowing an easier bend there. Make a few, then flex and check! The template picture could be printed its 81/2 X11 at 75 DPI
