Old Aug 22, 2002, 01:54 PM
Zhack is offline
Find More Posts by Zhack
Zhack's Avatar
Kelowna, BC, Canada
Joined Jun 2001
Help with mixing please
I have a problem. I want to use my Hitec Flash 5 for a DLG glider in "glider" mode. L and R Ailerons are coupled as flaperons and these are mixed to elevator with camber control on the throttle stick. Rudder is as usual on ch4.
Throttle control is moved from throttle stick to a switch with 3 positions: -50%, 0, and +50% (used to give 0, 50, and 100% levels to ESC for a motor glider).
I want to use this throttle switch (ch3) as a preset switch to control the rudder (ch4) during launch, then flip the ch3 switch to neutral and use the left stick to control the rudder on ch4 as usual for flight.
Is there some kind of mixer I can use to accomplish this mix between ch3 and ch4?
Zhack is offline Find More Posts by Zhack
Old Aug 23, 2002, 08:22 AM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
I think you might need a fancier radio
Keven.
keven64 is offline Find More Posts by keven64
Old Aug 23, 2002, 01:56 PM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Unfortunately, there are no programmable mixes on the Flash 5, and what you're intending to do doesn't sound like a very common practice. At least, it's not common enough that there is likely to be a preset mix for it.
I'm thinking along the lines of an external mixer to get what you want without having to buy a fancier radio... Maybe an inexpensive Wattage elevon mixer with the servo reversing set properly would do what you want? The Wattage elevon mixer is less than $20. Just hook the mixer up to channels 3 and 4 on your receiver, and plug the rudder into one of the outputs.
mkirsch1 is offline Find More Posts by mkirsch1
help with smart please bpu6999 High Performance 12 Jul 11, 2003 02:25 AM
help with Wingo please sbaug Foamies (Kits) 25 Mar 24, 2003 11:10 AM
Help with motor please rorywquin Electric Plane Talk 3 Jun 12, 2002 04:02 AM
