Old Oct 04, 2006, 03:20 AM
YellowB is offline
Find More Posts by YellowB
Joined Oct 2006
Mini-HowTo
Make Your Yellow Bee Rc Flyer Bullet Proof - Mod 1
THE cheap RC Yellow Bee is a BLAST but don't be surprised when you are in the air one minute and the next in pieces on the ground. Cheap means Cheap!
Here is what you do:
Buy 3M "SCOTCH Strapping" For Heavy Jobs. 2 in x 360 in (10yards)
(I bought mine at Target for $2.00)
This tape is fiber reinforced and is STRONG so you will need a razor blade to cut it. DO NOT worry about the extra weight... your yellow bee won't even know its there!
BEFORE ASSEMBLY and before you get ants in your pants and want to fly... Tape the wing on TOP and BOTTOM both directions (fiber tape one way, then the other) from the center of the wing to where the foam starts to bend.Do the SAME for the other side. This is the leading edge of the wing... so do a
good job and make sure there is no (or minimal) bubbles/wrinkles.
NEXT, Again tape the wing on TOP and BOTTOM both directions (fiber tape one way, then the other) from about 1/4" PAST THE PROPELLER tip to the center of the wing. Do the SAME for the other side. It is stronger if you choose to use one solid piece of tape all the way accross...just tape over the plastic top wing support and screw hole. You can posh a tooth pick through the hole later!
NOW, Put a single layer of tape (two strips just about fit) accross the length of the tail piece, before you bend it into a V. NOTE: LATER after a few crashes, add more tape as needed to prevent bending!
LAST, Cut out the tape that is in the way of the motors. I pushed the tape together, notched out the center, then melted the holes with a hot metal rod where the plastic posts poke up through the wing (4 small notches on each side).
This method works SO WELL that you will NOT BREAK A WING! You will however break the plastic fuselage/body since it is now the weak spot.
I am playing with clear epoxy to reinforce the weak spots (both sides of the cockpit AND the wing mounts inside that the screws go into)
FLY, CRASH, then FLY SOME MORE....
MORE....[/B]
Now if we could just figure out how to stop breaking those cheap props!
Hmmmmm
That will have to be my next MOD...posted here after I figure it out!
"MOD 2" - coming soon
Ho
YellowB is offline Find More Posts by YellowB
Old Oct 04, 2006, 11:20 AM
Skully is offline
Find More Posts by Skully
Bring a shovel
Skully's Avatar
New Caney, TX
Joined Jan 2006
[QUOTENow if we could just figure out how to stop breaking those cheap props![/QUOTE]
Use a prop saver YB. Breakage goes way down.
Skully is offline Find More Posts by Skully
Old Oct 04, 2006, 12:51 PM
mrodgers is offline
Find More Posts by mrodgers
United States, PA, Butler
Joined Jun 2006
I'm curious, I've never been able to find the Yellow Bee. This is the Harbor Freight one, right? Anyone have a link to it?
mrodgers is offline Find More Posts by mrodgers
Old Oct 04, 2006, 03:41 PM
YellowB is offline
Joined Oct 2006
More Yellow Bee INFO then you wanted
OPTION 1: $38.00
Raiden Technology, Inc.
City of Industry, CA
Phone: 626-968-9860 (NOT A FREE CALL)
Fax: 516-706-0421 (NOT A FREE CALL)
Email: Support@raidentech.com
Office hours are Monday through Friday, 12:00PM - 6:00PM PT
http://www.raidentech.com/
Buy 1.
http://www.raidentech.com/reracoaiyebe.html
Buy 6.
http://www.raidentech.com/whca6yebeerc.html
Spare Parts.
http://www.raidentech.com/3yebee2rcais.html
Shipping Example:
1 #3382 Yellow Bee 2-Channel RC Airplane Spare Parts:
Yellow Bee RC Plane Tail-Wing - Part # 3382
Subtotal: 4.00
Shipping: 6.05
Tax: 0.00
Total: 10.05
OPTION 2: $29.99
Harbor Freight Tools
Phone Orders 805-388-3000 (NOT A FREE CALL)
Customer Service 843-676-2603 (NOT A FREE CALL)
9:00am-5:30pm
Monday-Friday ET
http://www.harborfreight.com/cpi/ctaf/retail_stores.taf
Buy 1.
http://www.harborfreight.com/cpi/cta...unction=Search
or enter Part # 92304 ( OR 92304-1VGA )
Buy Spare Wing.
http://www.harborfreight.com/cpi/cta...emnumber=94028
or enter Part # 94028 ( OR 94028-0VGA )
Buy Spare Props.
Order by PHONE spare propellers.
Part # 28417 ( 1.95 Pair ) Not sure of price? Have not ordered any yet.
Note: This is a valid part # from a harbor freight TECH e-mail.
Note: If you try to order spare props online you will get this message:
"The Specifications for this item are not currently available online, or the item has been discontinued"
Shipping Chart:
* up to $14.99........$6.99
* $15.00 to $34.99....$7.99
* $35.00 to $69.99..$8.99
* $70.00 to $99.99..$9.99
* $100.00 to $129.99..$10.99
* $130.00 and up..$11.99
* Items marked "§Truck Item", subject to a $50.00 additional Freight Charge, per Truck Item.
Ho Styles
Old Jan 24, 2010, 02:49 AM
SJackson is offline
Find More Posts by SJackson
SJackson's Avatar
Queensland, Australia
Joined Jan 2010
Yellow Bee Mod, Taped Wings
Can you please show a pic for better understanding, i sort of get it, but not really
SJackson is offline Find More Posts by SJackson
Old May 16, 2010, 07:01 AM
fly boy 30 is offline
Find More Posts by fly boy 30
Joined May 2010
yellow bee
hay im new at the flying experience and i was wondering if the yellow bee is the right stater plane
fly boy 30 is offline Find More Posts by fly boy 30
Old May 16, 2010, 07:19 AM
Joined May 2010
'Yellow Bee' cheap RC - any good ? Flyfan Parkflyers 29 Jul 27, 2013 11:07 AM
Bullet Proof Tux your Hummingbird CP Mario Product Announcements 0 May 18, 2004 10:14 PM
Mini Max Mod's - bullet proof miltmerc Parkflyers 1 Aug 10, 2002 03:59 AM
Make your own 1/4 inch f3 equivelant Cass Foamies (Kits) 3 Mar 24, 2002 12:56 PM
mods to make sky scooter bullet-proof? opualuan Foamies (Kits) 22 Jan 14, 2002 08:04 AM
