Old Oct 02, 2006, 02:17 PM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
Robotic simulator surface robotic project possible glue-ee
ORIGINAL START OF THREAD Oct 02, 2006,
scan down to find start position
Major progress report updates will be here or on this first page post 1 or at this position post 29 so as to save wading through the thread
also more evidence that dificult to do project in MS and might have to change to linux EEEEKKK
Special edit 17th nov info below is interesting to follow also
http://www.simgear.org/
this is a serious simulator tool kit add on for the flight gear which probably can accommadate surface use
also good thread for surface UAS pre UAV system at http://www.rcgroups.com/forums/showthread.php?t=596120
and flight gear build thread
http://www.flightgear.org/~curt/Mod...al/Rascal110_1/
http://www.flightgear.org/~curt/Mod...al/Rascal110_2/
this system with simgear probably would allow a way to not have to bother to use a CAD program such as blender and speed things up a lot for a lot of others who wish to progress in a faster or different route
(info tends to be very linux supported presently)
Special Edit 12th nov 2006
Edit 12th nov 2006
decided that term sticky was more for forum controller and glue-ee made better sense so will try out that
Also Blender hasd Export import for most all types of files so no need to make API for it
Having problems to find suitable open source electronic programs that can do electronic simulationns especialy for electric battery motors combos
Now dont say motor calc or e calc as that is not open source or free and my buget restraints dont reach to these costs and as my calculator gives me adaqate results or free online dymond site (again not open source ) will go that way for now
figure going to have to hang out in german forums to get good free open source electronic simulators
eeekkkk babalel fish time again
lucky I can mostly hack the french stuff direct
if you have ideas on electrionic simulators or similar PM is best and then after I sifted them through them all I can tack them to this semi sticky (new term semi glue thread ) so its tack them onto this glue thread and (semi glue as sticky is more for forum controller )
Sorta got myself involved with a project for evening computer course which will be robotic simulator
special edit 30oct
this forum link is for simulation forum and the post number 29 has the most up to date relevant info on a similar theme
http://www.rcgroups.com/forums/showt...66#post6211836
highlight if you dont want to look everthing up are
www.simgear.org
and www.flightgear.org
and www.blender.org
The site http://nehe.gamedev.net has tution on how to learn and make 3d objects in openGL
CAD blender from www.blender.org has also game section with physics engine and AI
Also micro soft MS flight simulator has a program to design senery and planes etc which might be able to do robot simulator stuff I think its called MSFD and knowing them they got other products mayby even robot simulator design and that dsolution might suit others with more funds than me to dio a similar but not free version
(I will stick to free open source wherever possible )
special edit 17th nov
(point of useful info is www.simgear.org combined with www.flightgear.org can probably do robot simulator faster solution than with CAD
special edit 16 oct
(point of useful info is www.blender.org for surface use alone already has game system and can probably do a surface robot staight from the box and it freeeeeee
so surface robot users can plug away straight away )
special edit 18 oct
http://forums.auran.com/trainz/forum/index.php
there seems to be a very useful train simulator might be useful to see what qualities it has (me no intrest in trains )
Money or lack of it is a issue so except its very cheap like YSFLIGHT site $15 free trialware I will tend to avoid expensive software and probably opt for free or super cheap software
special edit 16 oct
YS is less intersting than flight gear as there are some parts of the code not available
edit end
I opted to do a robot simulator enhancement project for next few months preferably surface type first and then with a view to later on flying types
There are lots of links on this subject a few supplied below
sorta figure might as well see what anybody knows about this or anybody want to join forces
any way if nobodies interested will post stuff up as it goes along
If somebody else wants to head up a full project that continues beyond mid 2007 be my guest and set up a full sticky thread
as I will finish this major input in April May 2007 to go fly my RC models and return in winter 2007
winter time projects
The general story is that most robot simulators and commersial types seem to use open source GNU OpenGL which is basicaly the graphics for background and graphics for robots planes tanks etc including sims like Aerofly
The purpose for the project in this section is to follow the theme make a robot in a simulator that in the future would be be put into a real robot
The enhancement I will look to make will be
I/ Real component inside chassis with real wiring in open source CAD that will go into real time simulator
2/ Real time physics of items like electric motor amps volts etc as robot traverses hilly or simulated muddy terrain and grafical output onto HUD or similar re pics below
3/ Real time window which shows the onboard computer code output so to see where time delays or loops etc exist so as to speed up code (HUD or window )
4/ Real time sensor output windows to show what sensors acualy recieve such as lazar or sonar
5/ Interface and couple program like CAD to simulator program such and similar with suitable code or API
(probably electronic sim to blender CAD to flight gear sim)
but lots of possibilties exist that might be easier for others to try such as simgear to flightgear direct
6/ Later on when all other components work might look at AI or automonmous systems
7/ and all the other stuff I cant rememeber right now
Anyway i am at the early reasearch stage
I am opting to do project in windows first and later in MAC for my mac but if others want to do linux and other types feel free to make another thread to keep all of us informed
(nov 17th MS is not easy solutiion might have to do it in linux)
If any body want to join in probably best system is to respond with a link and set up seperate threads blogs web pages etc so this thread dosnt get blocked up too much
Special EDIT 16th OCT
The ultimate aim for me from this section is to take the material and plug it into other projects that lead to building a UAV
Its hopefully easier cheaper to make mock versions in computers first for testing them out
computer crashes are cheaper
(initialy I will try to make surface devices later avation )
one micro step at a time
I suspect to solve that problem will require the merging of sevaral open or non open source programs
all my preferences are for open source free types
(but due to my lesser linux mac abilties will probably stay with MS XP and after everthing works convert it to work on linux mac )
www.blender.org has as far as I can see the best CAD for open source access
[url]www.flightgear.org [url]has the best for open source access but the ccrm is a very intresting possibilty that might usurp flight gear
(ysflight has some source not accessable )
On that basis I will concentrate on merging these two into a more useful program for cad cam purposes
if somebody wants to try or join in feel free even if its with other programs
special edit 16 oct
Simulator seems to be most relevant sites relevant sites
Special edit 17th nov info below is interesting to follow also condences and reduces the work load of so many links
Open Source Free add on simulator Tool Kit for flight gear flight sim http://www.flightgear.org/
Open Source Free Simulator for flight aircraft hopefully suitable for surface use instead
www.blender.org
Open Source Free CAD with game simulator engine
Progress report 1 st oct : started thread
progress report ................................
special edit 16 oct
some extra edits included
Some few Links which I will add to as I go along at this location
Tutorial related
nehe.gamedev.net
lesson on openGL probably the most important site for simulators
robot sites of use
http://www.alsrobotics.co.uk/walker_1a.html
the guys no nonsence hand on how to build robot
www.leafproject.org
sterio vision project for pc robots looks realy good
(linux I think)
http://www.learn-c.com/
wild stuff window dosnt allow port access so needs a work
around eeeeekkkkkkkkk
Examples of some sites with Robot simulator components or open source GL programs are listed below
www.opengl.org/
The main site for open source graphics software
www.mesa3d.org
Realy important site seems to be OpenGl replacement site
http://lwjgl.org/index.php
light weight java game heavy on java
www.modsim.org/ good site simulator games graphics news source
www.animats.com
www.cs.uwm.edu grafix2.....
( approx mame needs google search) good site some heavy stuff
www.gameprogrammer.org useful info forums
player
http://playerstage.sourceforge.net/index.php?src=player
stage
http://playerstage.sourceforge.net/index.php?src=stage
Gazebo
http://playerstage.sourceforge.net/index.php?src=gazebo
http://cres.usc.edu/pubdb_html/files_upload/394.pdf.
One of the most important sites for a sim a robotic site a stage site and
3d robot type Gazebo(seems to be only linux unix)
www.exaflop.org/ good site but teckie stuff heavy
WWW.linuxdevices.com important site for real robots sensors(tend to be linux)
http://www.panoramix.pl
http://www.cs.utexas.edu/users/qr/robotics/flat/ simple 2d type
http://www.openscenegraph.org/ big site
http://sourceforge.net/projects/opensimulator
http://www.cours.polymtl.ca/roboop/ good potensial
http://www.aai.ca/
http://www.cyberbotics.com
http://rossum.sourceforge.net excellent information
http://ode.org/
http://www.devdept.com/
http://www.sd.nl/demogl/download.asp very good site
http://www.delphi3d.net/ very good site but over my head
www.binarybroz.com (good free game astroids etc )
Open source CAD sites are there to be found but some CAD are shareware and API
http://www.ribbonsoft.com/qcad.html
http://www.opencascade.org/
http://www.icivilengineer.com/Open_Source/
http://gaztelan.bi.ehu.es/~inigo/gcad/
http://www.opendwg.org/
http://www.eedesign.com/resources/opensourcelinks.html
http://www.staticfreesoft.com/
http://www.blender3d.com excellent 3d but hard slow work to learn
Some flight simulators that seem to OpenGL
(possible might be able use for surface robot )
www.flightgear.com open source
www.ysflight.com excellent seems to be open source still checking out site
www.FMS.ch not sure its open source code but might use API and it s free
Important program type sites
www.gnustep.com the open source to match mac XCODE for windows /linux pc
www.xcode.com
From apple mac the modeling program solution thats way out in front
www.microsoft.com
Virtual studio from micro soft(not very fimilar with the product so recheck my info) vitual studio c6 is free I think similar to xcode poduct c++ and few other lingos but more dumbed down
MS studio works is top software design product and cost big bucks and only sorta matches mac xcode which is free
www.nongnu.org/cvs/
cvs is the free software package whiuch programers use to update programs but other standards also exist
Ralf
treehog is offline Find More Posts by treehog
