Old Sep 28, 2006, 10:50 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
R/C Systems for Scale Boats
I've gotten interested (again) in scale model boats, in addition to my electric and glow model airplane projects. I have an old Cirrus 900XLC 7 channel FM system in 75mhz that is on its last legs. I like the transmitter because it has toggle switches and levers for three auxiliary channels in additon to the right and left airplane style sticks. My new Spektrum DX6 system would be ideal for boat use except for lack of levers for auxiliary channels. Ace R/C used to sell transmitters with levers, etc., that catered to model boat hobbyists with levers etc. Does anybody currently make a state of the art boat oriented R/C system?
E-Challenged is offline Find More Posts by E-Challenged
Old Sep 28, 2006, 11:07 AM
steveciambrone's Avatar
Castaic, CA
Joined Dec 2005
The Robbe Futaba system has the dual sticks for throttle, and it is a computer radio. i have an Ace Nautical commander which has the two sticks and it is OK, but once you have used a computer radio it is hard to go back to an analog radio. If I would do it over again I would pass on the Nautical commander and get the Robbe Futaba system.
If you do not want the dual stick throttle the Futaba 9 channel is a good value for the money. It has knobs but no levers.
Steve
Steve
steveciambrone is offline Find More Posts by steveciambrone
Old Sep 28, 2006, 12:17 PM
Joined Oct 2000
Current Nautical Commander
The current Nautical Commander system looks pretty good but it's not a computer transmitter outfit, no multiple boat memories, etc., and no way to quick change frequencies. That said, it may be the best thing currently available for scale boats needing lever and switch controls.
http://www.acehobby.com/ace/ACE8701.htm
Old Sep 28, 2006, 05:57 PM
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Ace announced their new Nautical Commander almost a year ago. As far as I know, it's not available yet. I sent Ace an e-mail in the spring, and their response was that it should be available in the late fall. Since we just entered early fall, I don't think we'll see the Nautical Commander until Christmas. If the "new" Nauctical Commander is anything like the "old" version, you get the transmitter, receivers, NiCd batteries for the radio system and a charger - no servos or ESC.
I have an older Nauctical Commander; IIRC, I paid about $200 for it new. Looking back, it wasn't such a good deal, as the receiver was set for Deans 3-pin connectors. This was the same time that the Futaba "J" connector became the "standard" for all other radio systems.
CG Bob is offline Find More Posts by CG Bob
Old Oct 01, 2006, 10:32 AM
Joined Oct 2000
Old Connectors.
I have an old 90's Cirrus/Hobby Shack 7 channel 900XLC FM system with it's own oddball connectors. Luckily the receiver has wires with male connectors to connect to servos, etc. If I want to interchange the receiver with other model boats, I'll have to change to common modern connectors or find a source of old type Cirrus connectors.
Old Oct 01, 2006, 10:50 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Are you sure it is on 75Mhz? I also have a 900XLC from the late 70's - early 80's (forget exactly when I bought it) and IIRC they only came in aircraft freq's which are on 72Mhz and if yours is also on 72Mhz and not 75Mhz than you should not use it for surface craft. Just a FYI.
Kmot is offline Find More Posts by Kmot
Old Oct 01, 2006, 03:47 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
During that time frame, there were 7 channels in 72-75 MHz, four were aircraft only, and the other three were shared by aircraft and surface models. We also had the 5 frequencies in the 27MHz band, as well as Ham frequencies in 53 MHz. The aircraft only frequencies were 72.080, 72.240, 72.400, and 75.640 MHz. The shared frequencies were 72.160, 72.320, and 72.960. A radio dating from that time period is a wide band model, and is not suppposed to be used anymore.
Old Oct 01, 2006, 05:16 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Bob, I was referring specifically to the Cirrus 900XLC line that was made by Futaba and carried and sold exclusively by Hobby Shack (now Hobby People) stores. I do not recall them being available in surface freq's but that does not mean they were not.
BTW, my 900XLC, from that time period, is on 72.870, or Channel 54. Still legal.
Old Oct 01, 2006, 05:18 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I think my first aircraft radio was on 75.640.......... was that Green & White?
Old Oct 01, 2006, 07:35 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
Channel 54 is still a legal channel. During that time period, the spacing between channels was different, 40 KHz. In 1988 or 89, the radio manufacturers started making the "new" narrow band equipment, with channel spacing at 20 KHz. If your radio doesn't have an AMA "Gold Sticker" on the back, the unit is a wide band unit and is illegal to use. We didin't get the "New" odd channels (55, 57, 61, 63, etc) until 1991 or 92. The specific FCC regulation is Section 95.623, R/C transmitter channel frequencies. Your older radio on Channel 54, unless it has the gold sticker, is causing interference on channels 53 and 55.
The older frequencies in the 72-76 MHz band were:
72.080 White/Brown flags (aircraft only)
72.160 White/Blue
72.240 White/Red (aircraft only)
72.320 White/Purple
72.400 White/Orange (aircraft only)
72.960 White/Yellow
75.640 White/Green (aircraft only)
The attached file has the "authorized" frequencies over the years, from 1973 to 1991. Tha Ham frequencies in the 53 MHz band are still legal, but finding equipment in that band is rare.
Old Oct 02, 2006, 04:45 PM
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
for ALL of my models I use a Futaba 6EXA on 40MHz (UK Surface band), and it does everything I ask of it
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Oct 02, 2006, 04:58 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
40Mhz? I think that is what we in the USA use for dog collars or something.
Old Oct 02, 2006, 06:01 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
my current radio is a futaba 9c on channel 88.
it replaced 2 ace nautical commanders and one futaba 6y.
i will never buy a non computer radio for my high end stuff again.
tsenecal is offline Find More Posts by tsenecal
Old Oct 02, 2006, 06:40 PM
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
I don't think the dogs would appreciate a UK person bringing their radios over the pond then... I know they bark at passing sirens but the yelping at a passing radio...
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Oct 07, 2006, 10:57 AM
Joined Oct 2000
Had it converted to 75mhz surface freq and silver stickered long ago. Just saw an original NIB 72 mhz 900XLC on Ebay. Don't know if there's anybody who can convert these systems anymore.
Discussion Best R/C setup for peanut scale? misfitsailor Indoor and Micro Models 2 Aug 05, 2007 09:41 AM
r/c truck for sale petn7 Life, The Universe, and Politics 3 Mar 01, 2002 07:49 AM
R/C stuff for sale airdevil85 Aircraft - Electric - Airplanes (FS/W) 5 Feb 17, 2002 12:50 PM
CSM v10 3-in-1 R/C Sim for PC BioHazard Aircraft - Electric - Airplanes (FS/W) 0 Oct 29, 2001 12:48 PM
