Old Sep 28, 2006, 10:48 AM
TommyB is offline
Find More Posts by TommyB
Central PA
Joined Dec 2005
Night flight with a slow stick...
I've done a bit of searching on this but have yet to find an easy, elegant, off the shelf solution.
I do have light tape setup that I bought at science surplus, but it runs on two double a's. I'd like to tap into the battery that's already on the plane. Maybe turn in on and off via the tx if thats possible. Not necessary though.
Links or suggestions welcome,
Tom
TommyB is offline Find More Posts by TommyB
Old Sep 28, 2006, 11:54 AM
N827TM is offline
Find More Posts by N827TM
Mansell Models
N827TM's Avatar
United States, UT, Layton
Joined May 2004
Here are a couple of Websites that provide the lights. CurteK lights are what I have and I like them better than MPI light. Curteks have Landing light's you can turn off and on. MPI Light's are basic cheap and work well. I have used them both.
http://www.curtek.com/store/customer...hp?productid=1
http://www.maxxprod.com/mpi/mpi-29b.html
Tom
N827TM is offline Find More Posts by N827TM
Old Sep 28, 2006, 12:11 PM
TommyB is offline
Central PA
Joined Dec 2005
Great, Thanks Tom.
How was ordering from curtek, as I notice they are in canada?
Do you know of any products that are more like a light string?
Thanks again.
Old Sep 28, 2006, 12:14 PM
TommyB is offline
Central PA
Joined Dec 2005
Did I read that right at curtek, the disclosure at the top says they are no longer filling orders?
Old Sep 28, 2006, 01:14 PM
Lt Crunch is offline
Find More Posts by Lt Crunch
"In Thrust We Trust"
Lt Crunch's Avatar
USA, CO, Arvada
Joined Aug 2006
Tom
Hi Tom, here's mine
http://imageevent.com/sipphoto/event...=0&w=4&s=0&z=3
That's a set of #3012 RC-Lights ($20 but they're out of stock I see)
http://www.rc-lights.com/products/pl...elis_boats.htm
And for the landing light a "Cyclops Atom" velcroed under the fuse tube
http://www.flashlightreviews.com/rev...clops_atom.htm
Make sure you drop your lights under the wing and tail, I let mine hang down about an inch. Otherwise they disappear when you turn.
have fun
Frank D
Lt Crunch is offline Find More Posts by Lt Crunch
Old Sep 29, 2006, 12:56 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
I have the MPI set on my Slow Stick. The Curtek set is a lot nicer, but the MPI set is cheap and gets the job done. I put white lights on the landing gear shining up at the underside of the wing, another white light shining forward through the prop (makes the orange GWS props glow), another shining up under the tail and red blinkers out at each wingtip. The light set plugs into any spare port on the receiver. It comes with JST connectors at the light module, so you can rig it up to where the wing unplugs easily for removal.
Tres Wright is offline Find More Posts by Tres Wright
Old Sep 29, 2006, 01:03 PM
toqer is offline
Find More Posts by toqer
Karaoke Pro, RC Noob
Joined Apr 2005
Hehe i just made this 2 days ago.
http://video.google.com/videoplay?do...65540398&hl=en
I'm good enough to fly by the LCD of my camera. You'll notice near the end there i'm using 2 light patterns (a shopping mall, and a school) as fly between points.
I use the MPI system. I think my method is different than what others use though... I use scotch tape (see through kind) and have a light at each corner of the wing. They extend beyond the wing edge (my reasoning for this is that at least 2 lights would be visable at all times this way) 2 of them are white, and are at the front of the wing, while 2 are at the back, red on right side, green on left.
I do use one blinker. I took a jumbo LED and stuffed it in the back tube.
toqer is offline Find More Posts by toqer
Discussion First night-flight with Slow-Stick - awesome!! robmoll Parkflyers 5 Oct 15, 2006 11:08 AM
First really high flight with Slow Stick Mattydiah Beginner Training Area (Aircraft-Electric) 3 Nov 03, 2004 05:50 PM
[Bad] AP flight with Slow Stick JoelRSails Aerial Photography 16 Aug 17, 2004 09:30 AM
First RC Flight with a Slow Stick BitTwist Beginner Training Area (Aircraft-Electric) 2 Aug 16, 2004 09:00 AM
Disappointing 1st Flight with Slow Stick llrelease Beginner Training Area (Aircraft-Electric) 18 Sep 13, 2003 01:46 PM
