Go Back   RC Groups > Aircraft - Electric - Airplanes > Micro RTF
This thread is privately moderated by t00fatt, who may elect to delete unwanted replies.
Old Sep 27, 2006, 01:39 PM   #1
Is he really fat??
Send a message via AIM to t00fatt
Micro RTF Mod FAQs
Moderators please make this a sticky, so new comers can find mod tutorials with out having to sift through hundreds of pages. I am only getting started with this, and looking to get this nice and long. I hope this will help people looking to mod their AA without searching. Anyone please contribute with links I may have missed or not gotten to yet. I am going to keep the list up-to-date.
Note: I moved this from the other thread because of the bad title. It originally said Aero Ace Mod FAQs. I tried to change the name, but it worked for a day then went back to the original title.
Aero Ace/X-Twin
Parts & Maintenance
AA Stock & Mod Parts
Stock Batteries
Battery Upgrades
Possible Replacement Props
Soldering Tips
Repairing Antenna Wire
Balancing Props
Applying Oil
AA Won't Charge Fix
AA/X-Twin Replacment Tail Fabrication
Great Aero Ace Mod Tutorial & Plans
Mods
How to Remove Throttle Spring
AA Turn w/o Throttle Mod
X-Twin Speedster
9v TX Adapter Mod
9v TX Adapter Mod Explained
AA Changing TX Channels
AA Tailless Flying Wing Mod
AA X-Planck Mod PDF
AA Landing Gear
AA Lanyard and Flashing LED Mod (Not the best LED mod)
Good LED Tutorial
Four Motor Mod (German)
Defoaming AA 1
Defoaming AA 2
X-Twin Actuator Rudder Mod Schematic
X-Twin Actuator Rudder Mod Pic
AA Sailplane Mod
Three Step Steering Mod 1
Three Step Steering Mod 2
X-Twin Level Flight
Easy LED mod
Reduce Turning Radius of Monoplane
Slowing Down X-Twin or AA for Indoor Use 1
Slowing Down X-Twin or AA for Indoor Use 2
No Fuselage
16 Power Steps TX Mod
16 Power Steps TX Mod 2
PiccoZ
Parts & Maintenance
Stock Batteries
Stock LiPo Info.
Weight Data
Bent Flybar Fix
How to Take the Rotors off
Applying Oil
Great Picco Z Mod Tutorial & Plans
Ball Bearings for Bearing Shaft Mod
Fix Shaft Spinning Freely in Pinion Gear
Mods
Moving the LiPo Forward
Forward Motion with a Scoop
Forward Motion with Weight
Forward Motion with Wings
Fix for Low Throttle Glitching
Fix for Low Throttle Glitching 2
Fix too Much Spin to the Right
Fix too Much Spin to the Right Pic
Carbon Fiber Shaft Replacement
How to Change Channel on RX
Ball Bearing Shaft Mod
Unstable Flight Fix
Strengthen Tail Rotor
Make Your Own Airwolf
Micro Mosquito
Parts & Maintenance
Charging Tips
Mods
Various Must Read Mods
Keep Motor from Coming of Top Pinion Gear
Storm Launcher
Mods
General Mods and Info
t00fatt is offline Find More Posts by t00fatt   Reply With Quote
Old Sep 27, 2006, 04:35 PM   #2
SEFF Contest Director
rcjunkie's Avatar
Thank you for putting them in one easy to find thread. I just bought one and will try some of the mods.
Ernie S.
rcjunkie is offline Find More Posts by rcjunkie   Reply With Quote
Old Sep 28, 2006, 03:39 PM   #3
Dastrooper's Avatar
bump. this should be a sticky
Dastrooper is offline Find More Posts by Dastrooper   Reply With Quote
Old Sep 30, 2006, 03:34 AM   #4
Is he really fat??
Old thread can be found here. Also if you like what I've done, give the thread a bump so we can keep it on top. I don't know if this will ever become a sticky.
Old Sep 30, 2006, 02:26 PM   #5
PC guru and Heli NUT!
megaglow_Z's Avatar
YAY,its a sticky.
This is wonderfull,thank you so much for doing this.
megaglow_Z is offline Find More Posts by megaglow_Z   Reply With Quote
Old Sep 30, 2006, 02:34 PM   #6
Is he really fat??
Thank you, which ever moderator made this a sticky. Also I have been really busy with class, and work. I am taking two 8 week classes and they are four hours each. So a lot of my time is taken up with class and work, so if there any mods you guys have seen and would like added, just shoot me a PM or post it in this thread.
Old Sep 30, 2006, 11:13 PM   #7
Artiste Spontané
aspoon's Avatar
Thank you for the links! Saves me tons of trouble searching for mods for my X-Twin.
I think any AeroSoarer links should fit in here too. I'll do a little search and post links as I come across them.
aspoon is offline Find More Posts by aspoon   Reply With Quote
Old Oct 01, 2006, 03:41 PM   #8
Is he really fat??
Added a Micro Mosquito section, thanks micro_builder for the links.
Old Oct 04, 2006, 01:26 PM   #9
build to fly, not to crash
micro_builder's Avatar
Send a message via Yahoo to micro_builder
knowing t00fatt is busy with school and what not, i figured i'd post these here for now and he can add them to the list later and then delete this post. some good links though:
micro mosquito mod thread: http://www.rcgroups.com/forums/showthread.php?t=573776
micro mosquito thread (multi rotor heli forum): http://www.rcgroups.com/forums/showthread.php?t=515376
aero soarer mods: http://www.rcgroups.com/forums/showthread.php?t=574602
aero soarer thread: http://www.rcgroups.com/forums/showthread.php?t=541490
aero soarer wont climb fixes: http://www.rcgroups.com/forums/showthread.php?t=575451
aero soarer general info: http://www.rcgroups.com/forums/showthread.php?t=578063
helix thread: http://www.rcgroups.com/forums/showthread.php?t=554518
spinblade heli thread: http://www.rcgroups.com/forums/showthread.php?t=429660
spinblade mod thread: http://www.rcgroups.com/forums/showthread.php?t=433516
AA wiki: http://www.eflightwiki.com/eflightwi...irhogs_AeroAce
AA mod site: http://www.falcon1.net/~ars/rcmodels.html
nick
micro_builder is offline Find More Posts by micro_builder   Reply With Quote
Old Oct 12, 2006, 08:40 PM   #10
Here are some things I've noticed/found out about the Picco Z in my 3 days of ownership. Please add to FAQ.
1: Warning about adding weight to the front with sharp objects like pins.
The LiPo battery is mounted in the front of the Picco Z copter. Be careful when inserting metal objects (tacks, nails, rods, paperclips etc) in the front nose of the Z. Puncturing a LiPo is bad. Results can be anything from no damage to dead battery to smoke to flames. So be careful. Here is someone else's picture showing the location of the battery.
http://www.rcgroups.com/forums/attac...hmentid=973724
2: Sudden severe wobble after crash.
See if the pin is sticking out of the top rotor. The pin is at the center and connects the rotor to the shaft. If so, push it back in. Make sure that both sides of the upper rotor are held by the pin. Get it as deep as you can where the top rotor is still free to flop forward and back.
3: Sudden lack of lift at full charge. Funny noise.
This happened to mine. The fix was to push the main rotor shaft straight down into the fuselage. Mine had come partially out and was allowing the spur (big) gear to spin without moving the shaft/rotor. With no load the prop still spun, but there was enough play that the copter would not lift off. Mine moved down a few mm.
Just some stuff I've noticed in my first week.
bholio is offline Find More Posts by bholio   Reply With Quote
Old Oct 13, 2006, 03:03 AM   #11
Is he really fat??
Whoa I have been really busy. I had midterms this week. I'm pretty tired now, but tomorrow I am going to add micro builders links, and check up on the piccoZ thread. I am in need of a replacement motor for my picco, I have yet to see someone find a good replacement.
Old Oct 13, 2006, 12:19 PM   #12
toofatt, last night i found that the AeroAce Jet motors are pretty much a drop in replacement. the resistence isnt exactly the same, but they're close. now its just a matter of finding that motor without having to gut the Jet!
Old Oct 18, 2006, 10:42 AM   #13
My backpack's got jets...
Corbin_Dallas's Avatar
Send a message via AIM to Corbin_Dallas Send a message via MSN to Corbin_Dallas Send a message via Yahoo to Corbin_Dallas
Thought you may want to throw this in there...
It seems every-other day someone needs a better picture of where to solder their broken off wire back to, so I added the wires into my 3D PiccoZ Receiver model, labeled them, then took a nice close-up screen-capture to hopefully get a view everyone can reference easily... here's the pic, I figure you can just copy it and let me know and I'll delete it from this page so it stays fairly uncluttered here
-(v)/\'|'|'-
  • Name: !!11.jpg
Corbin_Dallas is offline Find More Posts by Corbin_Dallas   Reply With Quote
Old Oct 18, 2006, 05:46 PM   #14
nice rendering, Matt
here's another, slightly more simple version as well. isnt mspaint great?!
  • Name: picco RX wiring.JPG
Old Dec 14, 2006, 10:54 AM   #15
Micro Shredder
Pouncer's Avatar
PM'ed T00fatt with suggestions. Alas no reply, so posting here for posterity.
1) PicooZ: can't see Alexander's recommended adjustment in the list:
PicooZ: improving stability
2) No Aero Soarer mod list??
Aero Soarer mod thread
Double decker variant here
..and here
PicooZ powered AeroSoarer
Pics of inside of IR transmitter
DIY voltage monitor
More tweaks
Square5.5 with AS electronics
Converting gearbox to tractor config
Cub style mod
Another tractor config
Rogallo wing mod
Charging tab removal
Replacement prop
Carbon fibre flying surfaces here
..and here
Projects
Landing gear
3 gram Aero Soarer, Aero Slower
Pouncer is offline Find More Posts by Pouncer   Reply With Quote
Discussion USB Machine Gun/Rocket Launcher mod shoots down RC Micro RTF Planes and Choppers Electronick Micro RTF 20 May 17, 2008 03:44 AM
Sold Housefly indoor micro RTF for sale... Snooptalian Aircraft - Electric - Airplanes (FS/W) 12 Jan 13, 2006 06:45 PM
Blade CP fully CCPM Micro RTF Helicopter jmc67 Micro Helis 13 Dec 02, 2005 10:33 AM
Two planes maidened, Auster and Nieuport11 (Gasparin Micro RTF) Zeroaltitude Scale Electric Planes 30 Sep 03, 2004 10:12 PM
Cool $18 Micro ! RTF mortonj69 Indoor and Micro Models 16 May 18, 2004 02:01 PM
Congratulations SimpleM!
