Old Jun 25, 2001, 02:38 PM
Jesper Reich is offline
Find More Posts by Jesper Reich
Alleroed - Denmark
Joined May 2001
How do you guys do it? Part II
Okay, now I have found out what batteries to use and how to charge them (interesting discussion in part 1), but now I have come across a new problem: How do I discharge 30 cells (36v. 2,4Ah.) at once? All regular discharges can only handle up to about 12 cells...... Can I discharge them using 3 car-headlamps in series? I know that I have to watch the voltage during this kind of discharge, or some of the cells will reverse (oh no! - here I go again...!)
/Jesper
Jesper Reich is offline Find More Posts by Jesper Reich
Old Jun 25, 2001, 04:09 PM
Fitz Walker is online now
Find More Posts by Fitz Walker
No "R" !!!!!!!
Fitz Walker's Avatar
United States, TX, Houston
Joined Jan 2000
Moved thread to Modeling Science forum as it seems more appropriate there.
-FTZ
Fitz Walker is online now Find More Posts by Fitz Walker
Old Jun 25, 2001, 04:15 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
Jesper-
That is exactly correct - use three 12V bulbs in series. Of course, if they are 1 amp bulbs at 12V, then it will take 2 hours to discharge.
The most fun way to discharge is to just go fly...
Shawn http://www.eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old Jun 25, 2001, 08:22 PM
rscamp is offline
Find More Posts by rscamp
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
The Orbit Microlader and Microlader Pro will discharge 30 and 32 cells at 25W and 35W dissipation respectively and taper the current for complete discharge down to 0.9V/cell. There must be other chargers that would discharge this many cells...
Rob
rscamp is offline Find More Posts by rscamp
Old Jun 26, 2001, 03:18 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
There are several chargers that will do that, the top end Schulzes for example. But the real question is WHY do you want to discharge 30 cells other than in the air with them connected to a motor ?
Unless you are doing it to measure the capacity of the cells you're just using up the cells for no purpose. They only have a lifetime of a finite number of charge/discharge cycles. Why use them up just to light bulbs ?
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jun 26, 2001, 10:17 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
To discharge a 30 cells pack, you can get it done in half an hour....let see..
36 volts(or so), 5 amp(or so) and V=IR, ....R=V/I.....36V/5A=7.2 ohm... and P=IV so 5 amp x 36=180 watt.
Sooo you will need a 6-7 ohm , 250-300 watt resistor to discharge the pack. I would put the resistor in a bucket of water to cool it. Monitor the voltage as it goes. Put the resistor off when the voltage gets to about 25 volts.
Brian
bhchan is offline Find More Posts by bhchan
Question How do you guys do color trim uniquewon 3D Flying 6 Jan 26, 2006 05:09 PM
How do you guys do it? jacob Electric Plane Talk 10 Feb 04, 2004 10:24 PM
How do you guys do it? Mr. Wiz Electric Plane Talk 15 Sep 15, 2003 08:11 AM
How do you guys do it? Part II Jesper Reich Electric Heli Talk 1 Jun 25, 2001 04:09 PM
How do you guys do it? Jesper Reich Electric Heli Talk 18 Jun 17, 2001 07:37 PM
