Old Sep 25, 2006, 10:04 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Servo Operated DPDT Toggle Switch for Motor Reversing
If your speed control has no reverse feature, you can reverse motor battery polarity with a heavy duty double pole double throw toggle switch actuated by a servo with a pushrod though a hole in the handle using a servo saver
( two wheel collars and two springs with the toggle handle in the middle). The spring makes servo throw non-critical and prevents binding.The attached diagram shows how to wire the switch terminals, and input output wiring
Use a heavy duty truck type dpdt toggle switch with plastic handle rated for 10 amps and a standard servo.
E-Challenged is online now Find More Posts by E-Challenged
Old Sep 26, 2006, 12:15 AM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Like this? I use it for my homemade winch.
Don M.
MILLERTIME is online now Find More Posts by MILLERTIME
Old Sep 26, 2006, 12:57 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I use something similar to Millertime's configuration for simple F/R switches.
Two momentary single throw switches. Both with C, NC and NO contacts.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Sep 26, 2006, 12:23 PM
Joined Oct 2000
Good Ideas!
Some good ideas, I forgot how to wire a polarity reversing switch, found how-to info on a website. Ace R/C used to sell tapered egg-shaped cam things with set screws that fit on a servo operated pushrod. I used three of them to actuate microswitches to turn on/off three separate lighting circuits sequentially. I guess you could grind wheel collars or glue egg sinkers onto the pushrod in the right positions to do the same thing. A servo arm can push one or two microswitch buttons or arms in a compact installation. Boats seem to encourage ingenuity. Maybe somebody could set up a "sticky" on this forum ideas like this. Other ideas are motor and other sound systems, smoke systems. I made a little portable TV set with a GOW bulb inside and a piece of color slide film for a picture.
Old Mar 24, 2008, 03:01 AM
jackcharon is offline
Find More Posts by jackcharon
Spain
Joined Feb 2008
Does your DTDP switch have a central [neutral] position? If not the winch would either always be going up or down unless you had another switch in the system?
jackcharon is offline Find More Posts by jackcharon
Old Mar 24, 2008, 11:30 PM
MILLERTIME's Avatar
Joined Apr 2004
The DTDP switch I have is self centering.
Discussion wiring a switch for a motor for a fire monitor robster94gt Scale Boats 10 Jul 19, 2010 12:41 AM
Discussion Servo Tester vs. TX/RX for Motor Testing galloping gimp Electric Motor Design and Construction 18 Jun 07, 2007 11:27 AM
Wanted Toggle switch for JR transmitter djensen Aircraft - General - Radio Equipment (FS/W) 2 Feb 03, 2007 05:49 PM
Sold Graupner Mechanical Switch for motor control chrisc Boats (FS/W) 3 Dec 20, 2006 08:52 PM
Servo Tester ccts for motor control steve lewin Control Line 1 Apr 26, 2001 07:40 AM
