Espritmodel.com Heli Air
Old Sep 25, 2006, 12:03 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
Foamie Yf-23 Black Widdow II
hey guys, i found plans for this on some foamie web site, and sense its on my top 3 list of favorite jsets, i couldnt resist. im doing it EDF stlye, but it can be easily done pusher as well. its very close to a true scale outline, and the only big change i made was to the size of the tailerons, they were too small on the plans. also, no cg was noted, so i found it by making a few chucks. it only took about 1 sheet of depron, and about 2.5 hrs to build. i still need to add control surfaces, and i really want to do full flying stabs, because this is a "test bed" for a larger, twin EDF version some where in the future...so this is kinda the test rat. fan is a e-flite fan, motor will be a e-flite 4200kv inrunner...est weight RTf is about 14-15oz with a 2100 3s pack, and about 230-240 watts. should have 1-1 thrust ratio, if not a hair more. stay tuned! i want to put gear on it too...ny maybe a quick paint job.
i know in crazy! im not even done with the A-4 yet!
BTW, its 36" long, and has a 22" wingspan.
corsair nut is offline Find More Posts by corsair nut
Old Sep 25, 2006, 12:07 AM
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Yo CN,
I had a profile '23 a while ago from PARKJETS.com (edf 40)
As far as control surfaces go, I'd recommend going w. aileron/elevator.
Stay away from the *elevon* scene w. this bird... don't ask how I know.. lol.
Don't have any experience w. full flying stabs on this one but you never know!!
Good Luck,
Vic.
AceMigKiller is offline Find More Posts by AceMigKiller
Old Sep 25, 2006, 12:19 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
yeah, i was planning on doing flaperons, and ruddervators... just like the real deal. elevons wont work well on a v tail. only a "flat stab" i think it will be a good flyer.
Old Sep 25, 2006, 07:05 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
check out the maiden report!!!
http://www.rcgroups.com/forums/showt...00#post6124600
Old Sep 25, 2006, 09:27 PM
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
My understaing is that this bird only flies on the control from the tailerons???? That the le and te flaps change camber of the wing and thus only effect maneuvering and landing, etc. But then again, i never flew one let alone seen one in person!!!! Great model though. I left a message on the EFD board on this model.
OhioMike is offline Find More Posts by OhioMike
Old Sep 25, 2006, 09:34 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
no, the ailerons accually work great! rolls very nice. it has "ruddervators"..and like i said in the edf post, they make it do some crazy stuff.
Old Sep 25, 2006, 09:35 PM
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
One other question i forgot to ask, where did you get your Thunder tiger Prolite batteries at? Is it an online source that would be available to us. Thanks again.
The Start of my YF-23 Black Widow II Project RCWorks Foamies (Kits) 39 Jul 14, 2009 07:24 PM
Discussion Foamie Yf-23 Black Widdow II corsair nut Foamy EDFs 36 Oct 29, 2006 12:42 PM
Discussion YF 23 Black Widow Eaglehawk752 Pusher Prop Jet Models 2 Sep 28, 2006 01:50 AM
Northrop/McDonnell Douglas YF-23 Black Widow II Esprit440 Pusher Prop Jet Models 12 Jul 31, 2006 12:47 AM
Yf-23 Black Widow Twin Midi Plane Crazy Electric Ducted Fan Jet Talk 23 Feb 08, 2005 03:25 PM
