Old Aug 19, 2002, 03:55 PM
The Other Dave is offline
Find More Posts by The Other Dave
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
Hobby lobby skimmer washout question.
I am getting ready to build up the wing
for my HL skimmer 400 kit.
I have read in all the posts that 1/4 inch
of washout is desireable for this wing.
My question is did you build it flat
and then get the washout while shrinking
the cover or did you build a jig to use during
wing construction and just raise the rear
corner of the wing 1/4 of an inch.
Dave
The Other Dave is offline Find More Posts by The Other Dave
Old Aug 19, 2002, 04:09 PM
S Schneider is offline
Find More Posts by S Schneider
northern calif. USA
Joined May 2002
I just set up mine that had wing built flat and covered flat. @ 5/16 wedge under trailing edge and reshrink covering get a little spring back and settled in at @ 1/4" Very easy to do this way than to build up with wash out, spar alignment very hard to keep consistant . Scott
S Schneider is offline Find More Posts by S Schneider
Old Aug 19, 2002, 09:40 PM
Joined Nov 2001
Thanks for the info.
I will build it flat and then shrink the dihedral in.
Dave
Old Aug 19, 2002, 10:50 PM
GYROGEARLOOSE is offline
Find More Posts by GYROGEARLOOSE
Sometimes it works!
GYROGEARLOOSE's Avatar
Caldera, Costa Rica
Joined May 2000
Dave
WHAOH! wait a minute! Something got lost in translation!
You must build in the dihedral, and shrink in the wash-out!
Build the two wing panels flat, carefuly join the two panels with the supplied dihedral brace, one panel flat on the table, the other panel tip blocked up the prescribed amount.
After you cover the completed wing nice and smooth, THEN you shrink in the wash out. When you reach that point, if you think you need any help, give a yell!
GYROGEARLOOSE is offline Find More Posts by GYROGEARLOOSE
Old Aug 20, 2002, 04:29 PM
Joined Nov 2001
No loss in the translation -> loss between the ears
I ment what I thought not what I typed.
I will build in the dihedral and then shrink in the
washout.
Man wouldn't that be a picture.
"I used my 40000 watt blow dryer to shrink in 2 inches
of dihedral, gee I wonder what that sound of cracking
balsa was, !#$@ I just trashed it (insert sound of me smacking
head against wall)".
Old Aug 21, 2002, 12:04 AM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
would dihedral and washout be needed if I add ailerons to it?
Stephen
Steph280 is online now Find More Posts by Steph280
Old Aug 21, 2002, 12:11 AM
Joined Nov 2001
I think you still need the washout.
Washout is to combat tip stall problems at low speed.
Ailerons don't help there.
Dave
Will an 8x800ar bat pack fit in a Hobby lobby skimmer 400. The Other Dave Electric Sailplanes 11 Oct 18, 2002 10:25 PM
Question on trimming out Hobby Lobby Skimmer 400 The Other Dave Electric Sailplanes 2 Sep 24, 2002 01:06 PM
Hobby Lobby Skimmer? RCFlybry Electric Sailplanes 2 May 10, 2002 03:26 PM
Hobby Lobby Lightweight Wheel Question janitor13 Parkflyers 9 Jan 21, 2002 01:12 PM
Hobby Lobby Miss 2 Question xjohnx Parkflyers 7 Nov 23, 2001 02:02 AM
