Old Sep 23, 2006, 09:13 PM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
NEsail Diablo 3D build thread
Ok, this is my first build thread. It takes enought time to build them, takes even more time to make a thread about it, but I love sharing with my fellow modelers, and reading their contributions as well.
disclaimer-I do not like the name diablo. What is funny is that there is the name diablo, and opposite the diablo are veggie tales, Christian cartoons. Too funny, like the angel and the devil on your shoulder. But it's just a name, and that is life, so on I go. Someone had a sense of humor when they made this.
First, order of business, install the airelon servos, well they were already installed for me, but no surprises here. I got this plane in a trade at the NEAT fair. Using hitec hs-85mg's all around. I hope they are good enough. The cutouts require small servos, so I am going with it.
antslake is offline Find More Posts by antslake
Old Sep 23, 2006, 09:16 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
motor mount
Ok, on to the motor mount. For power we are using an AXI4120/14 with thunder power 60003s3p, and a jeti 70 amp
I had to bring the motor out further to meet with the front of the cowl. Being a sheet metal worker, I fashioned one out of 0.50 aluminum. Hand bent in a vise, as I do not have any sheet metal machines here.
Old Sep 23, 2006, 09:18 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
break
Whew, that was like work!
Old Sep 23, 2006, 09:19 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Next will be glueing the tail together, be back in a few. That will probably be all I can manage tonight.
Latest blog entry: FAA registration
Old Sep 23, 2006, 10:04 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Tail feahers (horizontal fins)
Seems my friend glued in the vertical stab, and works freely, so on to the horizontal fins.
I made my first mistake. See if someone can figure out from the pictures, you can have a beer on me if you do.
I corrected it and moved on. Hey first mistake of the year!! lol
Used a square to get everything even. Let the pictures do the talking:
I was going to impress everyone with my mad epoxying skillz, but the stab was so tight, I just used ca. I use a combination of medium, and fine, to get in the cracks, and fill the voids.
Overall this is a very well made arf, nice quality.
Old Sep 23, 2006, 10:15 PM
renerc is offline
Find More Posts by renerc
springfield,ma
Joined May 2005
I'm not sure did you join the two elevators before putting them into the fuse? That is a huge batt. Is it asking for that?
renerc is offline Find More Posts by renerc
Old Sep 23, 2006, 10:18 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
yep, I forgot to put the hinge wire that goes between the two elevators, before gluing the stab. I had to make another one, and bend it once it was in there.
Old Sep 23, 2006, 10:22 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Is there such a thing as too much battery or power?
Honestly, I wasn't the one who sized this all up, my friend did, and I think they sold him something a little overboard, but thats fine with me. It won't go to waste
It does have a 50" wingspan, and is a .46 size plane.
Old Sep 23, 2006, 10:28 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Feel free to give advice along the way, and help me build it!
I ain't no master builder, but built about a dozen planes, and helped build a couple dozen more.
I sponser a building group in my shop, and we meet all winter, and work on stuff together, and eat pizza.
Old Sep 23, 2006, 10:44 PM
renerc is offline
springfield,ma
Joined May 2005
I made the same mistake on my plane. I was making such good progress that I forgot to put the wire in. That is a big plane for electric. That batt should be good. cant wait to see it done. How is the landing gear mount in the plane. I seem to be reinforce mine when I build.
Old Sep 23, 2006, 10:55 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Solid wire gear, not sure how it goes, but at the rate I do harrier landings, like my magic it shouldn't last to long, lol
I have some heavy duty landing gear, I can put on, but at the expense of wieght. So I will either have to limit my harrier landings (yea right) or deal with it.
I will video the maiden at the end.
Old Sep 23, 2006, 11:04 PM
rsasaki is offline
Find More Posts by rsasaki
They will soar on wings..
rsasaki's Avatar
USA, CA, Danville
Joined Aug 2004
The wire gear works fine. My Diablo weighs 3.2lbs. AUW and lands at a very slow speed. I'm running a Himax 3522-990, APC 13x6.5E, TP 3s2p 4200mAh (two 3s-2100mAh PL in parallel), about 500watts. Thread here:
http://www.rcgroups.com/forums/showthread.php?t=564501
Ron
p.s. Of course, I didn't try a harrier flop-it-down type of landing...
rsasaki is offline Find More Posts by rsasaki
Old Sep 23, 2006, 11:53 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Thanks rasaki!
Ok, I said I would quit, but who quits building when they say they are?
I went on to add servo extensions, snake them through, mount the servos, and got the rudder working.
I had a little problem with the hitec fitting, there was a gap, so I glued some plywood behind to fill the gap, see the pictures.
I also bent one of the control rods too aggresively, and snapped it. Luckily it was the longer one going to the rudder, and now I can just use it on the elevator, which doesn't need ot be as long.
Old Sep 24, 2006, 11:20 AM
RickC2009 is offline
Find More Posts by RickC2009
RickC2009's Avatar
USA, NY, Brookhaven
Joined Mar 2003
Antslake,
Great thread, I was at the neat fair and was looking at one of these kits form americanpioneerhobbies. Then later in the day on Sunday I saw one fly. It flew very well but it seem to be heavy. I should of asked the guy flying it some question but I was busy at the time. I am very interested in how you plane comes out and the all up weight. Thanks again for the great thread.
Rickc
RickC2009 is offline Find More Posts by RickC2009
Discussion EVA Sport/3D Build Thread mccrohan Parkflyers 135 Jun 09, 2010 10:26 PM
3DFoamy SuperCap 3D Build Thread toxjar 3D Flying 112 Jul 10, 2006 06:50 PM
Balsa 3D build thread, 25" WS, No carbon in sight! SargeNZ 3D Flying 9 Mar 17, 2006 03:46 PM
The Official Evelox 3D Build Thread by Josh G. and Trent S. JoshFlies3d 3D Flying 120 Mar 10, 2006 08:49 AM
Yippee! Straight Edge 3D build thread bcripe1 3D Flying 99 Mar 30, 2005 12:20 AM
