| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
Thread Tools |
| This thread is privately moderated by tribologist, who may elect to delete unwanted replies. |
#1 |
Simple "free" dual motor solution for Blade CP
This is a solution for dual tail motors for the Blade CP that I got inspired to by the way motors are soldered to the chassi in allmost all 1:24 slot cars. It worked out great and is a much lighter solution than the milled aluminum mounts that you can find on the web.
Good luck, let us know if it works out for you or if you have suggestions for improvements. Ulf Last edited by tribologist; Oct 01, 2006 at 06:31 PM. |
#2 |
great piece of work, love the pics.
thank you! |
#3 |
it's just plane fun
What a Great Idea!!
#4 |
Borderline Genius!
#5 |
with the 2 negative sides in the middle, are you not having the both motors spin opposite instead of same direction?
#6 |
It works!!! You just saved me $24. Thanks!
#7 |
oh thats a parralel wiring setup.. DUH
Thats why mine doesnt work, I did series and didnt have enough strength |
#8 |
I guess ther acid flux is a MUST, as It wont solder at all without it.. just lumps up
![]() Time to get flux |
#9 |
Skip the solder, Try to glue them together and let us know how it works.
Ulf Last edited by tribologist; Oct 15, 2006 at 04:50 PM. |
#10 |
I tried super glue.. but vibrations separates it over time.
and then you need solder another wire for (-) |
#11 |
there is not enough surface for the glue to make contact. I can see why solder is a much better option
#12 |
Thanks for the update, That is a good point. I have NEVER seen a slot car motor come loose as long as you get the solder to wet the can. I think tin-lead eutecticum has pretty food fatigue properties. It is used all the time to solder stuff that keep us alive in airplanes....
#13 |
I am waiting for a new soldering iron to arrive (my 15 amp wont do it)
#14 |
Airplane Pimp
A dot of JB Weld and a second wire for "-"?
Otherwise, I'm sure I have some flux around here somewhere... I love simple solutions like this. Great post! |
#15 |
Thanks for an absolutely brilliant solution! It was right on time for me, since I googled onto your topic this afternoon, and right after starting a session, my tail motor started dying. After trip to the LHS & about 20 minutes of geekin', it works! I still need to muck with some adjustments for the gyro and balance, but I'm hoping that these motors will last a lot longer than the 3 or so hours the last one gave me.
Again, thanks a lot! Jim |
| Thread Tools | |
| Discussion What brushless tail motor for Blade CP? | Jerry Brown | Micro Helis | 10 | Feb 28, 2008 07:50 PM |
| Discussion Brushless motor upgrade for Blade CP | Tyler F | Micro Helis | 1 | Apr 24, 2007 10:34 PM |
| Discussion Brushed motor upgrade for Blade cp? | Jkirch86 | Micro Helis | 7 | Mar 12, 2007 09:59 AM |
| Question Brushless Motor for Blade CP? | Rare Bear | Micro Helis | 10 | May 27, 2006 12:26 AM |
| Motor for Blade CP | remoteav8r | Micro Helis | 10 | Dec 15, 2005 06:31 PM |
