Old Aug 18, 2002, 10:16 PM
rc capo is offline
Find More Posts by rc capo
Isaiah 40:31
rc capo's Avatar
United States, FL, West Palm Beach
Joined Jun 2000
how do you calculate area and wing loading for eliptical wingspan
If there is a thread like this I couldn't find it...sorry.
How do you calculate the area and the wing loading for a wingspan that is eliptical? (sp?)
I have a Culver Cadet profile plans blown up to a 30" wingspan...the cord at the center/widest part is 7 11/16"
So now what do I do?
rc
rc capo is offline Find More Posts by rc capo
Old Aug 18, 2002, 10:37 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Unless you know the semi-major and semi-minor axes dimensions.. and I expect you won't, a reasonably accurate way is to break the area down into trapezoids, and measure each one.. and add the results..
Sparky Paul
http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff
http://home.earthlink.net/~pjburke1/aindex.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old Aug 18, 2002, 11:02 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
If you are luck enough to have CAD skills, you should be able to CAD the plan form, maybe from importing a 3-view drawing of the plane (wing). Most CAD programs will give you the area. Loading is derived from area.
Gary
Gary Warner is offline Find More Posts by Gary Warner
Old Aug 18, 2002, 11:21 PM
Dick Huang is offline
Find More Posts by Dick Huang
Dick Huang's Avatar
Dallas,TX, USA
Joined Mar 1999
rc capo,
If we assume you have an elliptical wing for the Culver Cadet then the area=Pi*a*b=3.14159*15*3.84375=181.13 sq in.=1.258 sq ft. If the all up weight is 10 oz then the wing loading would be=10/1.258=7.95 oz/ft^2.
Dick Huang
Dick Huang is offline Find More Posts by Dick Huang
Old Aug 19, 2002, 03:31 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Since wings are rarely true ellipses I always used to just trace the wing onto squared graph paper and count the squares. It's pretty easy to estimate the part complete squares. These days CAD will do it more accurately but it's still a pain setting the plan up unless you already have it in CAD format.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Aug 20, 2002, 12:18 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Read an article somewhere, sometime, where a guy said for an elliptical wing such as the Spitfire, take a piece of cardboard and make a rectangular section ( so it's easy to measure ). Then draw the wing planform on the same type of carboard. Cut out and WEIGH the cardboard wing . Then weigh the rectangular piece . Compare the weights and figure the percentage factor ( like the elliptical piece is 175% by weight of your rectangular piece). Then just multiply the area of your known piece by that factor to get the area of the elliptical wing. He claims it works but I never had use for it yet- hate hot wiring elliptical shapes. This is alot easier to do than to explain. It does make sense though as long as you stay with a consistent piece of carboard. Hope this helps.
J Morgan is offline Find More Posts by J Morgan
Old Aug 20, 2002, 03:24 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
J,
Good idea. Just another way to skin that kitty.
Gary
how do you calculate thrust for WeMoTec midi fan? gensis5280 Electric Ducted Fan Jet Talk 1 Dec 30, 2004 05:35 PM
How do you scale down the wing area? Frank B Modeling Science 2 Nov 18, 2004 07:13 AM
Question How do you prep a molded wing for horn? hbielich High Performance 2 Aug 20, 2004 01:33 AM
How do you put two batteries together for a higher cell battery? Balin Power Systems 3 Nov 09, 2001 11:09 AM
How do you time Graupner Speed 480 for pusher mode Brucie Foamies (Kits) 4 Sep 20, 2001 04:38 PM
