Sep 21, 2006, 10:34 PM
Chattanooga, Tennessee, United States
Joined May 2003
Sensible move - aside from other advantages, such as holding voltage under load better, Lipos are so much lighter.
I realized you were going to use a gearbox - this may enable you to swing a larger prop on lower amp draw than you could manage with an outrunner. With that 2.3:1 ratio though, at 3200Kv you are going to be drawing serious amps with a 9x5, aren't you?
Probably no use trying this as a comparable example - apples versus oranges perhaps, but a Walkera 3200Kv I tested drew 19.6A with an 8x6 and that was at 3:1. (sometimes it is obvious one needs to be leery of Motocalc - my real world measurement was fully 60% higher than their estimate of only 12.4A).
Putting 2.3:1 and a 9x5 for the Walkera leads Motocalc to suggest 21.6A - but if that estimate is way low as was the 8x6 - you might need to prepare for 1.6 x 21.6 = 34A - whoa!
Edit - looks as if I'm way out - the Aussie Modelflight site suggests that at 3:1 with a 9x6 your D/13/32 is not going to exceed 120W (say, 12A). Maybe 2.33:1 and a 9x5 will come in under the rated 160W max.
Cheers, Phil
