Old Sep 21, 2006, 04:22 PM
mndsw is offline
Find More Posts by mndsw
Northwich, England
Joined Oct 2005
launching aids
Someone, somewhere out there must have the ideal launching system for a four foot long, 18lb boat, that wont break my back each time I bend down to launch it. I've tried motor fan belts but they damage the rails/stanchions on the boat. There must a myriad of differant systems being used. Please share your ideas. Thanks.
mndsw is offline Find More Posts by mndsw
Old Sep 21, 2006, 04:32 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
what I tend to use is along the same lines, but consists of two lengths of 5100lb breaking strain ratchet strap webbing stapled to two lengths of timber about 12" long, then gaffa tape wrapped around the wood to prevent splinters.
I have used them for my yamato, and they have done NO damage. they are also long enough so the straps when lifted at waist height mean the model is just above the floor, ideal for lifting down to a canal
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Sep 21, 2006, 04:33 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Look under "sailboats" and "square rigger kit". Down a few posts it shows a launch cart, kind of like a small hand truck. Something like that may work.
420TEE is offline Find More Posts by 420TEE
Old Sep 22, 2006, 09:53 AM
tim slocum is offline
Find More Posts by tim slocum
tim slocum's Avatar
Central Missouri,USA Along the banks of the Missouri River
Joined Jun 2005
Mndsw, I've seen alot of systems over the 7 years I've attended regattas.I've seen the pvc pipe with pipe insulation for a cushion method.I've seen small carts with wheels.I have a 6ft long battleship (41lbs)and I usually find a helper and we each grab an end and set it in.I guess it partically depends on where you will most likely be launching you boat.A ramp launch is different than one straight into deep water.A launch into deep water(like from a dock)shouldnt be too hard with a boat your size.I had back surgery a few months back and they showed my how to lift properly.You should always use proper form when lifting (or launching) back surgery is NOT FUN!!
tim slocum is offline Find More Posts by tim slocum
Old Sep 22, 2006, 11:16 AM
excotec is offline
Find More Posts by excotec
Lima, Ohio
Joined Jan 2004
Tim,
I agree about the back surgery. I will never do it again. As for the launch methods I have a RC Boat Modler Mag that has a entire article devoted to this topic. How many rules, Laws would I break if I copied it and posted it here?
excotec is offline Find More Posts by excotec
Old Sep 22, 2006, 12:55 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Marine Rail System
It lifts the boat up to three feet above grade, to work on, and then lowers the ship down to the water level.
[edit]
I knew this mignt show up somewhere in the background at Bellevue.
Here are a couple shots of a typical launching rig. This one is threaded rod and wood, but it typical of the style that people build using pvc pipe.
The cross bars, or plastic grate across the bottom cradle the boat till it is down on the water.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Sep 22, 2006, 01:41 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Something like this?
Kmot is online now Find More Posts by Kmot
Old Sep 22, 2006, 02:26 PM
johnmca72 is offline
Find More Posts by johnmca72
Hunt County, Texas
Joined Sep 2005
NTXBG Launch Crane
Here's another:
JM
johnmca72 is offline Find More Posts by johnmca72
Old Sep 22, 2006, 05:24 PM
tsenecal is offline
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
This was the boat lift at the Subcommittee subregatta, i think it is actually owned/built by the indianapolis admirals
tsenecal is offline Find More Posts by tsenecal
Old Sep 22, 2006, 05:35 PM
Hunt County, Texas
Joined Sep 2005
We've also considered building a mini lock system, so that ships can sail into a "canal" & be raised up to a convenient "workbench" height. Also, a mini "Falkirk Wheel" would be cool. Both need a good supply of water at a higher level, though.
A trebuchet may also be used to launch ships, but not so good for retrieval - if there's anything left to retrieve, that is! ;-)
JM
Old Sep 22, 2006, 10:10 PM
tim slocum's Avatar
Joined Jun 2005
The St Louis Admirals RC Boat Club has a smaller version of what Johnmca72 posted.Its portable.
Old Sep 22, 2006, 10:36 PM
steveciambrone is offline
Find More Posts by steveciambrone
steveciambrone's Avatar
United States, CA, Santa Clarita
Joined Dec 2005
Everything is bigger in Texas.
Steve
Originally Posted by johnmca72
Here's another:
JM
steveciambrone is offline Find More Posts by steveciambrone
Old Sep 25, 2006, 01:41 PM
qbxb is offline
Find More Posts by qbxb
QBXB
Kissimmee, Florida
Joined May 2004
Over the weekend I photographed this launcher at a Tampa,Fl. area fun float.
qbxb is offline Find More Posts by qbxb
Old Sep 25, 2006, 02:42 PM
Shaun Hendricks is offline
Find More Posts by Shaun Hendricks
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
I don't think any of those lifts would work well with sailboats and their nice long skegs. The side slip launch could probably be modified to launch the boat perpendicular to the shore/dock and work with all boats.
I would think a floating, made of styrofoam, single lock with a battery/solar powered pump would be workable. Steer the ship into the lock. Close the gate, fast fill, pull ship out at 'okay for the back' height and put next ship in, fast drain and out she goes. Probably could be built in a day and for fairly cheap.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Sep 25, 2006, 03:00 PM
Joined Dec 2005
Sail boats are easily launched by lowering them into the water buy holding the main mast, don't even have to bend over. I still like the Texas solution.
Steve
