Old Sep 21, 2006, 07:36 AM
liltbrockie is offline
Find More Posts by liltbrockie
Joined Sep 2006
Question
Somone explain maH to me please... i think ive got it..
So we have an 8 pack which is 9.6V and the maH ranges from say 1800-3600maH
What does this mAh mean? Ive heard an analogy that its like gallons of fuel?
So am i right in saying the Mah value just tells us how long that battery can last for???
liltbrockie is offline Find More Posts by liltbrockie
Old Sep 21, 2006, 07:42 AM
Ace in the hole is offline
Find More Posts by Ace in the hole
RC Ace wannabe
Ace in the hole's Avatar
MICHIGAN, USA
Joined Sep 2004
Correct, mAh is the capacity of the pack.
A 3600 mAh pack will last aprox. twice as long as an 1800 mAh pack in any given application.
Ace in the hole is offline Find More Posts by Ace in the hole
Old Sep 21, 2006, 07:48 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
MAH is the slow discharge rate of a battery spec not at a hi-discharge rate spec
U can expect a 2200 mah rechargeable NMHie to give U 2.2 amps for an hour if your digital camera only only uses 2.2 amps or less
don't expect any 2200 mah battery to put out 22 amps for 10 minutes, why , the hi-discharge curve is different due to its hi Ri ( internal resistance )
hall woo is offline Find More Posts by hall woo
Old Sep 21, 2006, 08:29 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Because 10 times the current only gives you 1/10th of an hour which is 6 minutes not 10 .
Yes liltbrockie, mAh is the capacity. Greater capacity = longer run time.
BTW the correct "spelling" is mAh (capital A, lower case m and h) but it doesn't much matter. We understand most variations, but it is a bit odd to see 3 different versions used in one short message .
Steve
slipstick is offline Find More Posts by slipstick
Old Sep 21, 2006, 09:16 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Allthrough it is not exact, assuming that liltbrockie is not familiar with electronics, I should say that:
Double capacity means allmost double run time. A bulb taking 1.8A will light 1 hour on 1800mAh , but two hours on 3600mAh pack.
Running twice / triple... harder (current in A amperes) lasts allmost one half , 1/3 .... and so on.
With equal pack type, the power for which is pack suitable is adequate to its capacity.
Warning posted in previous posts are saying that it is not exact and pack types are very different. For example AA cell 2500mAh is often hardly suitable for 2.5A, but high current type 1000mAh cell is suitable for 20A without troubles.
You should know that load suitable for 3600mAh pack will probably overload and destroy 1800mAh one ( if power was near rated maximum)
"C" is commonly used to determine possible load. If pack is "6C", it means that it can deliver six times higher current thant is its capacity. 3600mAh and 6C means 21.6A , it will last 10 minutes (1/6hour). However, the same motor with 1800mAh pack will draw the same power and it means 21.6A / 1800mAh = 12C, Time of run is 5 minutes, but if this pack is not capable of 12C load, it will overheat and die.
coro is offline Find More Posts by coro
Old Sep 21, 2006, 09:17 PM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
This might be helpful to you.
If you know what your amp draw for motor is use this Calculator to
see how long your pack might last.
http://www.lcrcc.net/electric_calcs.htm
BlazerB52 is offline Find More Posts by BlazerB52
YES!!! I Think Ive Got It :D McDanger Micro Helis 2 Nov 18, 2005 07:28 PM
Explain This For Me, Please. Rogerdoger Aerial Photography 35 Mar 06, 2004 03:08 PM
Question Explain this to me? Please!!! gbarc Micro Helis 4 Jan 08, 2004 03:56 PM
I think ive got it a320az Scale Kit/Scratch Built 8 Aug 09, 2003 07:03 AM
Please explain mah, volts Sgt Rock Modeling Science 2 Sep 04, 2002 10:07 PM
